Like Tree24Likes
Old 12-12-2011, 08:27 AM   #2671
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
^^^^^^That's cool.
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 12-12-2011, 09:50 AM   #2672
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by Jmuck69 View Post
Has anyone noticed the front end of the 210 is a little light? Is anyone adding additional weight to the front?
I don't think the front end is a little light, I think the rear end is a little heavy. The B4's front end is MUCH lighter, and it steers like its on a track.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 12-12-2011, 09:54 AM   #2673
jurquhart's Avatar
Trader Rating: 22 (100%+)
I'm in the process of trying to pick up some spares for my buggy when it comes and I was wondering if anyone is running the 69 tooth spur gear or the 75 tooth spur gear.
I run on a medium large track and I'll be using a Tekin 8.5 with RS pro. Would either of the aforementioned spur gears be good choices to run?
Also out of curiousity does anyone make a 14mm hex wheel or do we have to use the Durango wheels?
John Urquhart
Sponsors include Caster Racing USA, Radiopost, and Trick-parts.com
Caster F8T e-Truggy with Tekin RX8 & 2000 motor Radiopost radio & servos
jurquhart is offline   Reply With Quote
Old 12-12-2011, 10:22 AM   #2674
hopsing's Avatar
Trader Rating: 13 (93%+)
75t would be the better spur of the two..
DE Racing makes wheels, both front and rear for the DEX210 buggy.
Steve Butts
AKA, TrakPower, Serpent America/Desoto Racing, TrackStar, Futaba, EKD Paints
hopsing is offline   Reply With Quote
Old 12-12-2011, 10:29 AM   #2675
Super Moderator
If you are running an 8.5, get the RW 81 tooth spur. You will run that with a 25 pinion or so. Use the 75 for a 17.5.
- RCSpecialties -
Old 12-12-2011, 10:34 AM   #2676
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
I'm running 81/24 with an 8.5 right now. So try 75/23
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,KoPropUSA,JConcepts,Avid RC,MIP,SikLidz,ImagineItGraphx, FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 12-12-2011, 11:04 AM   #2677
Jmuck69's Avatar
The 210 could use a little weight loss. I was thinking Ti screws and the lightened motor plate when it is released.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 12-12-2011, 11:12 AM   #2678
Trader Rating: 25 (100%+)
What is everyone running for motors? I plan on running a Tekin RS 13.5, or 10.5. I run on a medium - large indoor clay track. My buddy had a 13.5 in his 22, and that felt pretty good. I've never driven a 10.5.. So I'm not sure what to expect
GaRsNoW is offline   Reply With Quote
Old 12-12-2011, 11:20 AM   #2679
tomdav's Avatar
Trader Rating: 42 (100%+)
Found some outdrives. Never heard of the shop before but will take a chance as I want to race this weekend.
http://www.mammothhobbies.com/BALL-D.../tdr310264.htm
Tom
The Couve, WA
davesrctracks.net
tomdav is offline   Reply With Quote
Old 12-12-2011, 11:47 AM   #2680
lockmouth's Avatar
Trader Rating: 33 (100%+)
Does anyone know where I can find a gear cover?? I hope some one makes one out of lexan or good plastic. The stock unit is so brittle, I have crack 2 of them.
The Dex210 is bad azz... BTW
MARIO KNOX
HOTBODIES RACING / FULL THROTTLE RACEWAY (OWNER / OPERATOR)
lockmouth is offline   Reply With Quote
Old 12-12-2011, 11:50 AM   #2681
Jmuck69's Avatar
I'm sure RPM will be coming out with one in 3...2...1...
B6D | B64D
Old 12-12-2011, 11:54 AM   #2682
Jmuck69's Avatar
Speaking of RPM, I emailed them when the 210 was hitting the shores. I informed them of problems some where having with the stock ballcups and suggested RPM to make replacement units. They should fit the standard Durango ballstuds and have the hole in the cup. They said they were unaware of this issue and would look into it. Currently am using the RPM longshank cups throughout and work flawlessly.
B6D | B64D
Old 12-12-2011, 12:56 PM   #2683
CHIZZLE's Avatar
Trader Rating: 37 (100%+)
Are you using those with the stock balls?
Chance Renstrom
Repeat after me......"toy cars"
CHIZZLE is offline   Reply With Quote
Old 12-12-2011, 01:07 PM   #2684
Jmuck69's Avatar
No, I am using the nitride coated TC5 ballstuds from AE. I kept the stock Durango link that connects the servo horn to the bellcrank, but all others are RPM. The stock Durango turnbuckles work well but will switch to Lundsford Ti units soon.
B6D | B64D
Old 12-12-2011, 02:54 PM   #2685
jimkoimanis's Avatar
im using lundsford 1070 ti they come with ballcups just need to change ballstuds
tamiya tao2 gt4,fav,bear hawk,team associated sc10, b4.1, sc18, tc5r,t4 j82. cougar sv pro dirt spec durango dex210 cat sx3 Schumacher k1 tekin gen2 d3.5 17.5 X-ray 808e xray xb9 13 spec os speed 21xz-b spec2
durango 410darc spec orion r10 pro orion vst
sponsored by habib's bodies
jimkoimanis is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
05PSD
