Like Tree23Likes
Old 12-11-2011, 11:22 PM   #2656
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Originally Posted by KyJoe340 View Post
Pushed terrible, very wide on the turns. Inline turns on a dime.
nice, thats the problem i am having! will go back to zero for this weekend!
MantisWorx is offline   Reply With Quote
Old 12-12-2011, 02:05 AM   #2657
spiro's Avatar
Default Jconcepts Rulux wheels
Greetings 'rango boys!
I'm expecting my 210 any day now, but I have one concern after reading the manual in regards to the front wheels. I currently have a c#¤pload of tires race-ready glued to the Jconcepts Rulux wheels for my B4.1. Are there any aftermarket parts that makes it possible to use these wheels on the 210? I know that the rear is easy enough with the old 410 mod, but the front puzzles me.
Please advice!
-S-
[ DEX210 ]|[ DEX410 ]|¤|[ Futaba 4PK ]
spiro is offline   Reply With Quote
Old 12-12-2011, 02:44 AM   #2658
triplesix's Avatar
I only know these parts from a german shop, but they're available, at least.
http://modellbau-langenfeld.de/shop/...9%26aid%3D1%26
MBX6R
B5M Lowrider
DEX410
Supastox GT
triplesix is offline   Reply With Quote
Old 12-12-2011, 05:40 AM   #2659
spiro's Avatar
Thanks! Spot on!
Old 12-12-2011, 05:42 AM   #2660
kwilke's Avatar
Trader Rating: 172 (100%+)
Send a message via AIM to kwilke
whats the old 410 mod ? im looking for some 12 mm hexes to put on
Bluegrass Hobbies
www.bluegrasshobbies.com.
kwilke is offline   Reply With Quote
Old 12-12-2011, 05:44 AM   #2661
spiro's Avatar
The new 410 V3 has 14mm hexes front and rear. The old one had the same setup stock as the B44 with the 12mm hex in the front and cone/pin on the back. Hence, my huge stock of AE style wheels would bolt directly on the "old" 410's.
The mod is simply buy the old bits and put them on the V3 and on the rear of the 210.
Old 12-12-2011, 06:50 AM   #2662
Jmuck69's Avatar
Has anyone noticed the front end of the 210 is a little light? Is anyone adding additional weight to the front?
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 12-12-2011, 07:05 AM   #2663
sparkwraps's Avatar
Trader Rating: 34 (100%+)
um... Y E S!
I have 3/4 oz in the front of the front bulkhead (the front bumper is holding it in there) and an addition 1/4 oz on the chassis under the steering components. Made things allot better. I also run my fullsize battery up against the servo. If you can't tell, I like steering...
sparkwraps is offline   Reply With Quote
Old 12-12-2011, 07:09 AM   #2664
Jmuck69's Avatar
Originally Posted by sparkwraps View Post
um... Y E S!
This past weekends race, the front end was bouncing up and down the straight and was a little nose high in the air. Are you putting the weight in the front a-arm pocket?
B6D | B64D
Old 12-12-2011, 07:17 AM   #2665
sparkwraps's Avatar
Was that due to traction (traction wheelies)? Not sure what you mean about the pocket...
I was adding weight to get more steering, not to keep the front end on the ground down the straight.
Old 12-12-2011, 07:36 AM   #2666
Atomicsickness's Avatar
Trader Rating: 26 (100%+)
It could be the 4 gear rear motor setup. From what I read it does make the car pop a wheelie happy.
☆http://www.loganvillerc.com☆
☆http://hotshotrc.com/☆
Atomicsickness is offline   Reply With Quote
Old 12-12-2011, 07:37 AM   #2667
Dog Runner's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to Dog Runner
So, if I get these pins and these hexes (and maybe some shims?), can I fit my 12mm rear wheels from my Losi 22 on the 210?
JR
Need a real estate agent? I can help.
Dog Runner is offline   Reply With Quote
Old 12-12-2011, 07:39 AM   #2668
Jmuck69's Avatar
That could be it. I might move the battery forward to the mid-motor battery location and see what happens.
B6D | B64D
Old 12-12-2011, 08:11 AM   #2669
sparkwraps's Avatar
I think those hexes are 14mm and you are wanting to do 12mm for 22 wheels.
I posted a while back how I got my 22 wheels to work, but the offsets are pretty different. Once I found some hexes of the right width (SC10 hex adapters for the front) I had maybe three threads showing on the axle with the wheel on. This seemed to work out just fine, but I did break an axle pin since it was not fully support with that hex. Had I back that pin with a spacer that was the same height as the pin, or the hex surrounded the pin completely it would have worked better. It was all the lhs had that seemed like it would work. Now I know I need to look harder and what to look harder for.
I did buy the HPI battery hold down screws and they are GREAT. (HPI Part number HPI86969)
Old 12-12-2011, 08:25 AM   #2670
FRONTI3R's Avatar
Here's some good info. I just found about it.
RC Tuning – Axle, Trailing
http://www.competitionx.com/rc-racin...axle-trailing/
What is a Trailing Axle?
Most vehicles come standard with Trailing Axles. This puts the Axle BEHIND the kingpin, making the car easier to drive.
Tuning with a Trailing Axle
Trailing Axles are standard on most vehicles. They provide the best overall steering feeling. Trailing Axles are much less aggressive than Inline Axles, and that is the reason they should be used on high-grip or ‘blue groove’ tracks.
In addition, some vehicles use spacers to move the steering block/caster block assembly forward or rearward. With the Trailing Axles, the steering block/caster block should be forward.
RC Tuning – Axle, Inline
http://www.competitionx.com/rc-racin...g-axle-inline/
What is an Inline Axle?
Inline Axles are just what the term implies…the Axle is Inline with the Kingpin.
This is usually an optional steering setup and requires the use of a different Axles (in most cases) and different steering blocks.
Tuning with an Inline Axle
Inline Axles are optional on most offroad vehicles. When used, they provide a much more aggressive steering feeling into and out of corners.
As with the Trailing Axles, some vehicles use spacers to move the steering block/caster block assembly forward or rearward. While using Inline Axles, you will need to space the steering block/caster block assembly rearward.
Sponsors: Tekno RC, GFX Designs, RCOttawa.com/forum/
www.teknorc.com
FRONTI3R is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
