Like Tree32Likes
Old 12-10-2011, 03:29 PM   #2626
Trader Rating: 29 (100%+)
They are a tight fit. Just press it on and the piston and screw will seat it when tightening..
Yzlvr is offline   Reply With Quote
Old 12-10-2011, 03:31 PM   #2627
Trader Rating: 63 (100%+)
Default thank you
Got it thanks on the shock help.
Tekno NT48.3, Tekno NB48.4, BLOK Engines, VP Fuels, Tekin Rx8, Futaba, Proline
paposwing14 is offline   Reply With Quote
Old 12-10-2011, 04:32 PM   #2628
sparkwraps's Avatar
Trader Rating: 34 (100%+)
Originally Posted by paposwing14 View Post
Just got it all together and working on shocks. Anyone have issues with SHIM2 6x5x.5mm not fitting on shock shaft so I can put on 330157 and screw to shaft? need help. Washer is chrome in color and I went thru all my parts. Help most appreciated!
The shims that go on the shaft are tight. I started mine and put the pistons on, then started to screw them in and the piston pushed it down just fine. It is a tight fit for sure.
Last edited by sparkwraps; 12-10-2011 at 04:33 PM. Reason: Haha - I was a minute or two too late in responding!
sparkwraps is offline   Reply With Quote
Old 12-10-2011, 09:58 PM   #2629
Trader Rating: 520 (100%+)
Originally Posted by CHIZZLE View Post
What's up guys? I'm in dire need for some a-arm pivot balls. If you have any you can spare I'd be glad to pay you a couple bucks a piece to mail them to me. Can't seem to find any in stock anywhere and would like to race next weekend. Please help!
Here's the part I'm in need of.......
http://www.amainhobbies.com/product_...vot-Ball-Set-8
YGPM
flame56mx is offline   Reply With Quote
Old 12-11-2011, 04:34 AM   #2630
1armed1's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to 1armed1
Yeti,
I'm in for a pivot block also.
Dayton
1armed1 is offline   Reply With Quote
Old 12-11-2011, 04:43 AM   #2631
mjealey's Avatar
Hey guys help me out with a setup. I am running the box stock setup and the buggy was pretty decent. Would like a little more turning to it as the buggy wanted to push a little bit. I am running stock pistons, springs, with 27.5 oil in front, 25 oil in rear. I just want to work on the shocks right now as I could tell they were too soft. What are you guys running for springs and oil, pistons? I can tell for sure it needs stiffer springs.
Kyosho Inferno MP9 TKI 3 - OS Speed .19 & .21 - KO Propo
WinterBlast 2012 - Knoxville, TN - Chilhowee Park
10/27, 11/10, 12/8, 01/05, 02/02, 03/09*
mjealey is offline   Reply With Quote
Old 12-11-2011, 05:26 AM   #2632
kwiksi's Avatar
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Originally Posted by kwiksi View Post
Try it out. You have nothing to lose. I have 3-1/4 oz. squares that fit perfect. 2 in the bulkhead and 1 under the pivot block.
What he said. ^^
Thanks in 2017 to
Xray/RC America - JConcepts - Trinity - Sanwa - Hobbywing - Exotek - PT Racing Oils -Schelle
kwiksi is offline   Reply With Quote
Old 12-11-2011, 07:11 AM   #2633
MantisWorx's Avatar
Trader Rating: 28 (97%+)
DEX210 domination at the houston toys for tots event!! i will do a race report this afternoon and i have a video i am about to DL in a few hours. but my 210 was DOMINANT!! i took Tq by a lap and had the quckest lap time by almost 2 seconds!! Chris jones' qualified second with his and actually ended up with the win (more on that later....). when i post the vid you will notice that it is a big track with some monster triples, i was the only one that could clear them consistantly (pistons baby, pistons). only failure the entire day was Chris broke a rear shock tower trying to clear the triples, no failures on my car!
Larry rollins did not get 9 laps, one of his laps was 5.4 seconds....
hard to see but my fast lap was 34.0?? i dont think anyone else even got into the 36's!!
MantisWorx is offline   Reply With Quote
Old 12-11-2011, 07:32 AM   #2634
I am running the front 35 - 1.3x4 hole pistons, with the stock springs
rear 30 - 1.2x6 hole pistons, with the stock springs. The shocks feel great, my car has a little on power push, but it's manageable and our track is extremely tight. My car out of the box handled like the box it came in, my build set-up was, well, off. We first tried pushing the front axles from full trailing to inline, and the car had steering, but was on crack twitchy, but still had an on power push, and when you only have a 5 foot lane it was not ideal. Next we raised the roll center front and rear, and it started coming around much better, and finally went to the above mentioned shock settings, and its really easy to drive, and I actually put the front hubs back to full trailing, and its much smoother.. I can work up a set-up sheet if anyone would like, pm me an email addy
Old 12-11-2011, 08:10 AM   #2635
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
Can't wait to see the video(s).
Thanks!!!!
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 12-11-2011, 09:29 AM   #2636
Trader Rating: 14 (100%+)
Originally Posted by stavman View Post
My NEW toy
Gotta head to my shop and swap the Mamba Max out for a Tekin RS... mamba TOOOOOO big
Should be all dialed by Noon or so
Hey Stav....why the orange and black paint job??!?!?!...you have any more RS's in stock??....Crystal and I have gotten bit by this 1/10 bug...I need to finish her 410 and I need an RS...everything else is pretty much too big!!!
P.S. I saw the other day the "high" for Phoenix was about 55 degrees??...are you doing ok, do I need to send you a parka!?!?!
TEAM DURANGO
Lunsford Racing
Durango DNX408, DEX408, DNX408T, DEX410, DEX210, DESC410
Houstons Engine Service-H.E.S.
rpmhobbies is offline   Reply With Quote
Old 12-11-2011, 09:41 AM   #2637
Jerad8's Avatar
Trader Rating: 104 (100%+)
Has anyone ordered shock orings through Mcmaster Carr, looking to order some shock orings for my dex210 and shock orings and diff orings for my desc410r. Just looking if anyone had the size or parts #'s before i tear them down to measure?
Jerad8 is offline   Reply With Quote
Old 12-11-2011, 10:03 AM   #2638
tomdav's Avatar
Trader Rating: 42 (100%+)
Well four races in and no broken parts. Heck I had some nasty tumbles and did not even pop a ballcup last race. The only issue is a messed up outdrive. Its only one side and even after flipping it the same outdrive has just hogged out. Its not like our track has massive traction and I'm not landing off any jumps with the throttle pegged.
Patiently waiting for the spare parts shipment.
Oh yeah, BEST DIFF EVER!
Tom
The Couve, WA
davesrctracks.net
tomdav is offline   Reply With Quote
Old 12-11-2011, 11:35 AM   #2639
MantisWorx's Avatar
ok so i am checking out in the mains and then my car stops, for some reason my radio went dead, sucks because i would have had a double win as i also won the A main in SC..... so now for my excuses, it was very cold and it always takes me a lap or two to get used to the car since its soooo much different than 4wd SC! oh and the barometric pressure was out of my normal range so my eyes were blurry
http://www.youtube.com/user/Mantisworx?feature=mhee
here is the setup
FRONT:
vector soft fronts
-4 trailing
0 toe
-1.5 camber
23mm ride height
30caster
outside arms.middle towers
TSR bladders with bleed screws left out
RCshox 6hole 1.2compression 1.3 rebound 20wt
REAR:
went between soft rebars and supersoft impacts
3.5 toe
3 kickup
-1 camber
24mm ride height
inside arms,#4 hole on RCshox tower (its inbetween middle and inside on stock tower)
TSR bladders with bleed screw removed
RCshox 6hole 1.2compression 1.3 rebound 20wt (could have easily went to 17.5 but it was cold and i got lazy!)
SC10 gear dif with 2k fluid (1k would be much better)
RM4 tranny
MMP with 14* of boost
Murfdogg 8.5 83/28
RCshox garodisc
battery in the back
Old 12-11-2011, 12:37 PM   #2640
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Does anybody have any idea when Durango is going to release differential outdrive spare parts? Mine have really started to gouge, and will soon be undriveable.... I don't want to have to wire up the B4 while I wait for outdrives. ugh. I only got about 5 race days on them and have about a 1mm gouge already.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
