Like Tree43Likes
Old 12-08-2011, 08:20 PM   #2581
hopsing's Avatar
Trader Rating: 13 (93%+)
Originally Posted by Hi-LowBlow View Post
sorry, "heavy" means that the feel of the diff when I spin either side of tire. It feels really weird when it's tighten as much as it needs to be.
And again, I really don't think I did anything wrong.
Whats weird? Does it feel tight? Is it smooth throughout the entire rotation of the diff? How many runs on it? If it feels on the tight side, it should loosen up some after several runs. Its taken quite a few runs for mine to loosen up some and it may still be a touch tight but its smooth.
Also, did you use the stock balls and thrusts or did you replace them with ceramics? I'm still on stock balls and thrusts with 30+ runs and my diff is still smooth.
Steve Butts
AKA, TrakPower, Serpent America/Desoto Racing, TrackStar, Futaba, EKD Paints
hopsing is offline   Reply With Quote
Old 12-08-2011, 09:27 PM   #2582
tom235's Avatar
well i had my first night on the car. at the start of the night the car was not very good. but as the night went on the car got better still off the pace but getting better. i am having a hard time getting the car to turn and rotate on power.
i was waiting to brake a rear tower or have the ball cups pop off but the car is tough WOW i had a couple of hits and spills that i thought took the front off the car and it was good
all an all not a bad first time out
tom235 is offline   Reply With Quote
Old 12-08-2011, 09:37 PM   #2583
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Did you break the diff in? Have you run it yet?
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 12-08-2011, 09:39 PM   #2584
Super Moderator
Originally Posted by MantisWorx View Post
Shocks, i have been playing with RCshox 2 stage pistons and ended up with 4 hole 1.2 compression,1.3 rebound and 20wt in the front. and 6 hole 1.3/1.4 22.5 wt in the rear. 4 hole in the back just had entirely too much pack even with 15wt oil!!
What behavior did you see that makes you think you had too much pack?
- RCSpecialties -
Old 12-08-2011, 10:28 PM   #2585
Outtacontrol58's Avatar
Trader Rating: 91 (98%+)
Send a message via AIM to Outtacontrol58
Thumbs up
A pair of some sweet DEX210s, Cant wait to make the maiden voyage this weekend!
Outtacontrol58 is offline   Reply With Quote
Old 12-09-2011, 04:27 AM   #2586
kwiksi's Avatar
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
There is room inside the front bulkhead/pivot for up to 3/4 oz.
Thanks in 2017 to
Xray/RC America - JConcepts - Trinity - Sanwa - Hobbywing - Exotek - PT Racing Oils -Schelle
kwiksi is offline   Reply With Quote
Old 12-09-2011, 08:41 AM   #2587
tom235's Avatar
I did put about 1/2 behind the servo because I a
am running a low profile servo and that did help a little
should I move it to under the bulkhead?
I am going to play with springs and oil and see what
happens
Old 12-09-2011, 09:06 AM   #2588
onekiwi's Avatar
Anyone try a 4 hole piston in the BBs?
What will this do?
I presume that Ill have to go lower oils im at 35/40 now so maybe 20/25?
onekiwi is offline   Reply With Quote
Old 12-09-2011, 03:11 PM   #2589
fullsyzz's Avatar
Trader Rating: 107 (100%+)
I'm running 4 hole 1.3's in front with green springs and 25 oil. 4 hole 1.2's in the rear with 22.5 oil and black spring. Weather is COLD. Large track, medium grip, indoor clay. Car is working good, but gonna try even lighter oil, 22.5 front, 20 rear.
fullsyzz is offline   Reply With Quote
Old 12-09-2011, 03:17 PM   #2590
MantisWorx's Avatar
Trader Rating: 28 (97%+)
no movement in the rear donkey kicking through the washboard and very unstable on landings, these pistons act much different than normal pistons in that the pack comes from the pistons coming together more so than the hole sizes so you can run more holes and still achieve the same pack as less holes, if that makes any sense. I now have 6hole with 22.5 in the rear and it is MUCH better, glides across the washboards, no slap and jumps like a bird!
BTW i have a dedicated thread for RCshox now, my shock towers and battery straps will available soon!
RCshox products and services
MantisWorx is offline   Reply With Quote
Old 12-09-2011, 03:20 PM   #2591
So who is interested in blank shock pistons? These were cut on my laser CNC machine and turned out pretty good. They are Delrin so they shouldnt develop any mechanical slop.
Original on the right, new delrin blanks on the left and on the shaft. Note they also have the recess for the washer on the shaft.
Culetto is offline   Reply With Quote
Old 12-09-2011, 03:30 PM   #2592
Trader Rating: 19 (100%+)
Do they have a recess for the washer on the bottom? Or did you figure to just leave it out?
XRAY, RC America, MOTIV, Sanwa, Arrowmax, Neverlift Racing Apparel
Jonny5ive Designs- by racers, for racers!
Jonny5 is offline   Reply With Quote
Old 12-09-2011, 03:36 PM   #2593
hopsing's Avatar
He says it has the recess on the bottom....
Steve Butts
Old 12-09-2011, 03:45 PM   #2594
You can see the recess on the one on the left. Thats looking at the bottom of the piston. For a 1200$ camera it didnt turn out as well as i would have thought, lol.
Old 12-09-2011, 05:43 PM   #2595
stavman's Avatar
Should have my DEX210 Done tonight.....
Finishing shocks and painting.... Tires all glued and ready to mount
Now I just need to get My NEW track opened up so i can PLAY!!!!!
Stav
FYAIDGASAM
stavman is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16575 11-18-2017 12:44 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
