Like Tree23Likes
Old 12-06-2011, 12:03 PM   #2536
Huleboer's Avatar
Originally Posted by hopsing View Post
Thats part of the reason to run the shorty packs......... You'll drop almost a 100 grams off that weight and be able to adjust your weight bias more easily. My car is around 1630 with all stock hardware and steel turnbuckles. Put some titanium turnbuckles, titanium and aluminum screws and I should be just under 1600 which is good enough for me. I also dont run any extra weight and so far havent found the need to either.
You must have some heavy electronics. My car messures 1658g on my kitchen scale and that's with a full size 5600mAh hardcase lipo.
All stock with LRP speedo and motor, spektrum reciever and savox servo.
Team Associated RC8b3e w/ Hobbywing Xerun 150A 1800KV and Gens Ace 6750mAh 70c
Huleboer is offline   Reply With Quote
Old 12-06-2011, 12:04 PM   #2537
Jmuck69's Avatar
Stupid moment here...
I went to put on my new Atomic Carbon CF steering link and brace along with the lipo strap. Went in flawless and looks great. The track i'm going to this weekend is deffinitely a candidate for the RM4 config. So I take the countless screws out and finally get to the gear box. i crack it open and flip the spur gear around and put everything back. This takes a while! Well I forgot to take out the large idler gear and put in the two smaller idler gears. Doah!!!! I have to get back in and do it again!
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 12-06-2011, 01:12 PM   #2538
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
aahhh yes.. the joy of working on the backend of the 210
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 12-06-2011, 01:35 PM   #2539
hopsing's Avatar
Trader Rating: 13 (93%+)
I run a Speed Passion GT pro esc and motor, standard futaba receiver, standard 1257 Savox servo. The weight will depend on your pack....standard size packs typically range from around 250-300 grams....there are lighter ones depending on mah and C rating. I have a couple of standard packs that range from 210-230. Shorty packs are are all around 195-205g. Chances are, most poeple will save at least 50g by changing to a shorty pack..... that guys car was over 1700 grams which means he probably has a heavy pack.
Steve Butts
AKA, TrakPower, Serpent America/Desoto Racing, TrackStar, Futaba, EKD Paints
hopsing is offline   Reply With Quote
Old 12-06-2011, 03:19 PM   #2540
rcman182006's Avatar
Send a message via Yahoo to rcman182006
Originally Posted by onekiwi View Post
Here is the solution that is arriving shortly I hope but have heard hes working on it
http://www.oople.com/forums/showthread.php?t=83523
I hpoe he can wrap it around the lower edge of the tower so its a lot like the original
I dropped a message on there about us US guys might wanting them
-=-Charles Kilbarger-=-
Serpent SRX2 MM - D4 17.5 - Hobbywing Justock
AE RC10 Team Car - RevTech 17.5 - Hobbywing Justock
#NoChuck2015
rcman182006 is offline   Reply With Quote
Old 12-06-2011, 03:49 PM   #2541
JeremyHarris's Avatar
Here's the new Finnisher body.
Jeremy G. Harris
Pro-Line-RCWrapz-LFR-SXT-KustomRCGraphics-Airtronics-Team Associated-Reedy-LRP-Superiorhobbies.com
JeremyHarris is offline   Reply With Quote
Old 12-06-2011, 03:50 PM   #2542
Super Moderator
got mine in the mail yesterday... should have it painted and mounted by the weekend.
- RCSpecialties -
Old 12-06-2011, 04:07 PM   #2543
I received this one at the beginning of last week just for practice. Larry over at Kustomrcgraphics should have my painted one on his thread tonight.
Jeremy G. Harris
Old 12-06-2011, 04:14 PM   #2544
Trader Rating: 520 (100%+)
Like the paint scheme, but I have seen that design somewhere else before..lol
flame56mx is offline   Reply With Quote
Old 12-06-2011, 05:09 PM   #2545
Here is the painted one.
Jeremy G. Harris
Old 12-06-2011, 07:06 PM   #2546
Nice looking lid Jeremy, you don't see those colors very often. I imagine it would take more than a glance to notice all the details..
Old 12-06-2011, 08:19 PM   #2547
ali_g's Avatar
is there any gear diff for DEX210?
☆ JU.C RACING ☆
https://www.facebook.com/Ju.Cracing
ali_g is offline   Reply With Quote
Old 12-06-2011, 08:27 PM   #2548
Nothing available from Durango as of yet, but some are using an SC10 diff, and shimming it to work, but I haven't seen it in person..The ball diff is pretty beefy, and works great for me..
Couldn't sleep thinking about that Akula front tower, so I took out the dremel and my cracked stock tower and came up with this..
Akula tower
Modded Akula tower-I would have have tightened up a bit, but the stocker was cracked where I couldnt do much more. I will put it through the ringer, and see how it holds up..
Old 12-06-2011, 08:49 PM   #2549
brandundecided's Avatar
Akula tower
Attachment 844379
Attachment 844380
I like it much better. I dont think there will be any problems running them the other way but the angle is just to extreme for me. BTW does anyone have an extra gear cover
brandundecided is offline   Reply With Quote
Old 12-06-2011, 08:49 PM   #2550
ronsand's Avatar
Smart use of a cracked tower
I was planing to mill similar brackets from 7075 aluminum, placing the upper link as per the original (and maybe do the same for the rear, removing the original ones from the gearbox).
Mugen MBX7 - Tekno V4 MBX6 - DEX410v3 - DEX210 - DESC410 - Serpent S411 - Futaba 4PKs - Tekin RX8 + RS Pro - Werks B6
ronsand is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16563 Today 04:32 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
