Like Tree26Likes
Old 12-03-2011, 12:00 PM   #2446
Originally Posted by Peff View Post
Hi guys,
I'm a newb to 1/10th. I'm thinking of getting the dex210. I've read a few threads and most of them say that this is the most tunable buggy out there. My fear though, is it to tunable for a newb. Can too many changes cause confusion for a newb?
I dont want to waste money and would rather buy right the first time. As iam a newb, just how much torture can this baby handle?
Cheers
Dont be put off by all the adjustments. When making any setup changes on any car, its important to change as few things as possible, preferably one thing at a time. If you do get lost, go back to kit setup and start again.
With all the tuning parts being in the kit, allows you to spend more on tyres and then spend more time at the track
The car is very durable and the diff stays smooth for a very long time. Had 6 hours of running on the kit diff before flipping the plates around, then run it for another couple of hours before sanding the plates down and fitting new balls.
Xray XB4 | Kyosho RB6 | Kyosho Rudebits DB2
Chris-s is offline   Reply With Quote
Old 12-03-2011, 12:07 PM   #2447
Peff's Avatar
Thanks guys, I'll check what the guys are using, last I went to the track it was losi, team c, lots of ae and a few ranges. Rango guys are from out of town though so only see them at nats.
By the Way one kiwi congrats on the word cup
Originally Posted by onekiwi View Post
Id say get it as all the tuning parts are included in the stock kit and with a helpfull bunch that are on here Im sure you can get help you may n.eed
Its a great car out of the box and the stock setup is fine.
But I think a to make your choice have a look around at the local tracks/clubd to what others are running, think about getting a similar car to them as there you will have local knowledge and on track days others will have parts etc to help out if needed.
TLR 22T
Peff is offline   Reply With Quote
Old 12-03-2011, 12:22 PM   #2448
murky123's Avatar
Hi guys,
Cheers
to many changes can confuse.
but if you make 1 change at a time , this buggy is the perfect buggy to learn every aspect of all the tunings options.
Im learning aswell. take your time and do one change on your setup at a time
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 12-03-2011, 12:24 PM   #2449
murky123's Avatar
on my losi 22 I had my travel of the steering at 120% and with this buggy and same servo im down to 95%.
sounds familiar ? or?
Old 12-03-2011, 12:34 PM   #2450
rcman182006's Avatar
Send a message via Yahoo to rcman182006
I have an Aitronics 359 in mine, when it was in my old RB5 I had 95% on my EPA, on the 210 im down to 60-70% range so sounds about right to me
-=-Charles Kilbarger-=-
Serpent SRX2 MM - D4 17.5 - Hobbywing Justock
AE RC10 Team Car - RevTech 17.5 - Hobbywing Justock
#NoChuck2015
rcman182006 is offline   Reply With Quote
Old 12-03-2011, 03:28 PM   #2451
Dog Runner's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to Dog Runner
Originally Posted by rcman182006 View Post
I've heard of the AE SC10 gear diff is a direct drop in w/ some shimming
Originally Posted by dirtydan View Post
what oil would you recommend for the gear diff?
Typically 2000 or 3000 diff oil (Team Associated brand, for example) are good to start with to try for a 2wd buggy.
JR
Need a real estate agent? I can help.
Dog Runner is offline   Reply With Quote
Old 12-03-2011, 04:07 PM   #2452
what shims do you use to install it with?
#NoChuck2015
Old 12-03-2011, 06:25 PM   #2453
Just want to make sure that this is a good list of spares I should have on hand? I would add the bulkhead set but its out of stock atm
#NoChuck2015
Old 12-03-2011, 07:18 PM   #2454
NUZUM's Avatar
Trader Rating: 18 (100%+)
Originally Posted by Diff Balls View Post
I need some help.......
I am working on the shocks and the o-ring that goes at the top of the shock and than you put on the cap......When tightening down the cap, it squishes the o-ring out and it will actually come out enough where it is completely exposed (not sealing). If I don't tighten it enough for this to happen, it spins very easily.
No I am not over-tightening, I am doing it by hand and not using any force. The o-rings went on very easily and were hardly tight on the threads. Yes it is pushed all the way down on the threads also.
I have built hundreds of shocks over the years and have never had this problem before. My only idea of why its happening is because the top, inside of the cap is angled in a way that it pushes the o-ring outwards as it compresses.
Diff balls if ya look some of the shock caps are not perfectly flat on the seal surface i ran into the same issue just snug it down lightly and it will seal ok !!!
EA MOTORSPORTS /TRINITY/ EPIC/ REVTECH/B-FAST R/C PERFORMANCE/RADIOPOST
NUZUM is offline   Reply With Quote
Old 12-03-2011, 09:31 PM   #2455
Trader Rating: 520 (100%+)
I had a similar issue, but it seemed like it happened more on the shock that had a little oil seeping over the edge. The oring would get oily and more slippery and shoot out the side when tightened. I wiped the excess oil off, or was more careful and it didn't happen as often.
I rec'd my Carbon fiber Akula shock towers today, and when I was removing the stockers, I realized I unknowingly broke my first part, not sure if it happened tonight, or when I was running laps on Wednesday, but there was a hairline crack in the front tower. I am not real impressed with the Akula front tower, as the camber link mount is a little suspect. The ballstud mounts horizontal instead of vertically..Well see..
flame56mx is offline   Reply With Quote
Old 12-03-2011, 09:55 PM   #2456
fullsyzz's Avatar
Trader Rating: 103 (100%+)
I've only got one night of track time with the Akula stuff, but it's working awesome so far. Running outside middle hole for camber link on front tower.
fullsyzz is offline   Reply With Quote
Old 12-03-2011, 11:03 PM   #2457
joho's Avatar
Regarding the shock cap pushing out the o-ring, first of all, flip the shock cap and you will see there are some residue from the molding process, take a sharp knife and trim it, your problem will go away.
joho is offline   Reply With Quote
Old 12-04-2011, 06:56 AM   #2458
Yeah, it's the middle set of holes and inside ones where the problem rears its ugly head, the angle of the link going back to the hub causes the link to rub the tower. I run in the middle holes, I dont know why they even drilled the inside holes in the thing. And those front cups are gonna take a beating..I may just run the stock tower, until a better design comes out..
Durango DEX210 Thread-imag0183.jpgDurango DEX210 Thread-imag0184.jpgDurango DEX210 Thread-imag0187.jpg
Old 12-04-2011, 07:26 AM   #2459
NUZUM's Avatar
Attachment 842927Attachment 842928Attachment 842929
WOW terrible design for sure ... take that thing off man !!!
Old 12-04-2011, 07:26 AM   #2460
kwilke's Avatar
Trader Rating: 172 (100%+)
Send a message via AIM to kwilke
which brand shorty pack fits ? any one useing a std length pack ?
Bluegrass Hobbies
www.bluegrasshobbies.com.
kwilke is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
