Like Tree26Likes
Old 12-02-2011, 03:58 PM   #2431
valleyraceway's Avatar
Originally Posted by Briguy View Post
I heard from a fellow racer the 210 has rear hinge pin problems . Since they are back ordered has anyone found a substitute that will work ?
Anyone ??
Briguy i usred a old allen driver one time cut it to lenghth and worked good to get me buy
valleyraceway is offline   Reply With Quote
Old 12-02-2011, 04:05 PM   #2432
Dog Runner's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to Dog Runner
Originally Posted by rcman182006 View Post
I've heard of the AE SC10 gear diff is a direct drop in w/ some shimming
It works just fine. You will need a bunch of shims. Mine needed about .5mm more on one side than the other to make sure the gears meshed correctly.
JR
Need a real estate agent? I can help.
Dog Runner is offline   Reply With Quote
Old 12-02-2011, 06:01 PM   #2433
dirtydan's Avatar
Trader Rating: 47 (100%+)
what oil would you recommend for the gear diff?
dirtydan is offline   Reply With Quote
Old 12-02-2011, 06:04 PM   #2434
sparkwraps's Avatar
Trader Rating: 34 (100%+)
13.5 gearing
Anyone ??
Start with something close to 79/27 and watch temps and how car is doing on the track.
sparkwraps is offline   Reply With Quote
Old 12-02-2011, 09:08 PM   #2435
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Rewire from RM4 to RM3 done.. booya.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 12-02-2011, 09:12 PM   #2436
kwilke's Avatar
Trader Rating: 172 (100%+)
Send a message via AIM to kwilke
Bluegrass Hobbies
www.bluegrasshobbies.com.
kwilke is offline   Reply With Quote
Old 12-02-2011, 09:48 PM   #2437
tomdav's Avatar
Trader Rating: 42 (100%+)
Originally Posted by kwilke View Post
Rear motor 4 gear to rear motor 3 gear.
Tom
The Couve, WA
davesrctracks.net
tomdav is offline   Reply With Quote
Old 12-02-2011, 09:51 PM   #2438
kwilke's Avatar
I was asking why switch from 4 gear to 3 gear
Bluegrass Hobbies
Old 12-02-2011, 10:24 PM   #2439
Trader Rating: 19 (100%+)
Originally Posted by dirtydan View Post
im wanted to know if anyone has tried a diff from another brand on this car? only reason im asking is because i need a new circlip and i dont have one here local, but i can pick up an ae diff or kyosho diff, but not sure if they will fit and i dont want to waste my money on one and have it not work.
The circlips are easily bought from Fastenal or McMaster Carr in bulk. We got a bag of 100 for around $12 when a friend broke his circlip trying to remove it without snapring pliers. Snapring pliers are an absolute MUST for working on the diff.
XRAY, RC America, MOTIV, Sanwa, Arrowmax, Neverlift Racing Apparel
Jonny5ive Designs- by racers, for racers!
Jonny5 is offline   Reply With Quote
Old 12-03-2011, 08:28 AM   #2440
Diff Balls's Avatar
Trader Rating: 38 (100%+)
I need some help.......
I am working on the shocks and the o-ring that goes at the top of the shock and than you put on the cap......When tightening down the cap, it squishes the o-ring out and it will actually come out enough where it is completely exposed (not sealing). If I don't tighten it enough for this to happen, it spins very easily.
No I am not over-tightening, I am doing it by hand and not using any force. The o-rings went on very easily and were hardly tight on the threads. Yes it is pushed all the way down on the threads also.
I have built hundreds of shocks over the years and have never had this problem before. My only idea of why its happening is because the top, inside of the cap is angled in a way that it pushes the o-ring outwards as it compresses.
Diff Balls is offline   Reply With Quote
Old 12-03-2011, 08:37 AM   #2441
tomdav's Avatar
Trying a new setup I'm guessing. More on power steering?
Tom
The Couve, WA
davesrctracks.net
Old 12-03-2011, 09:50 AM   #2442
Huleboer's Avatar
First real outing with my buggy today, and apart from my low gearing (13.5t 25/87) it ended up running rather well.
I had alot more wrenching time than track time due to my circlip coming loose all the time. I ended up cleaning it all. Expand ther circlip before installing it and then applied some fast curing clue (like tire glue but not too thin a liquid) with the tip of a small flat head screwdriver. All the way around the circlip and then give it a squeese to allow the glue to get behind it.
That was after the third time i took it apart today. Now it seems to stay put.
Just be very careful not get any glue on the thrust drive.
Team Associated RC8b3e w/ Hobbywing Xerun 150A 1800KV and Gens Ace 6750mAh 70c
Huleboer is offline   Reply With Quote
Old 12-03-2011, 11:24 AM   #2443
Peff's Avatar
Default Dex210
Hi guys,
I'm a newb to 1/10th. I'm thinking of getting the dex210. I've read a few threads and most of them say that this is the most tunable buggy out there. My fear though, is it to tunable for a newb. Can too many changes cause confusion for a newb?
I dont want to waste money and would rather buy right the first time. As iam a newb, just how much torture can this baby handle?
Cheers
TLR 22T
Peff is offline   Reply With Quote
Old 12-03-2011, 11:30 AM   #2444
sparkwraps's Avatar
Originally Posted by Peff View Post
Hi guys,
Cheers
I would not recommend this buggy for you. It is essentially buying every tuning part for a car, but it all comes with it. While this is a huge bonus for those that can tune, it would hurt you right now. You could be so far out of tune because of one small thing and you wouldn't know how to fix it.
Just my own thoughts
Old 12-03-2011, 11:49 AM   #2445
onekiwi's Avatar
Id say get it as all the tuning parts are included in the stock kit and with a helpfull bunch that are on here Im sure you can get help you may n.eed
Its a great car out of the box and the stock setup is fine.
But I think a to make your choice have a look around at the local tracks/clubd to what others are running, think about getting a similar car to them as there you will have local knowledge and on track days others will have parts etc to help out if needed.
onekiwi is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
