Like Tree24Likes
Old 12-02-2011, 09:53 AM   #2416
JS
JS's Avatar
Trader Rating: 70 (100%+)
Just picked up a Dex210 and getting ready for the build.
This is my first buggy and I had a newb question for tires.
I will be running on a bumpy dirt track/low to med traction.
The tires I chose are Holeshots M4 and Suburbs M4 for the rear. Using Scrubs M3 for the front.
Are vent holes recommended for the tires similar to SC and 1/8 tires?
I was doing some research and looks like vent holes are recommended when using closed cell foams. No vent holes for stock/white inserts.
Is this correct?
Any feedback will be great - thanks
JS is offline   Reply With Quote
Old 12-02-2011, 10:30 AM   #2417
hopsing's Avatar
Trader Rating: 13 (93%+)
Is this correct?
I always vent the tire either way..... usually two 3-4mm holes in each tire will do it. You can get a leather punch at Home Depot or Lowes for cheap and it will have a few different size punches on it.
Steve Butts
AKA, TrakPower, Serpent America/Desoto Racing, TrackStar, Futaba, EKD Paints
hopsing is offline   Reply With Quote
Old 12-02-2011, 11:09 AM   #2418
JS
JS's Avatar
Great - thanks Steve
Old 12-02-2011, 12:04 PM   #2419
just got mine...need to know a good steering servo for it. thanks
AssasinRacing is offline   Reply With Quote
Old 12-02-2011, 12:29 PM   #2420
Jmuck69's Avatar
I like my Orion VDS-1007 servo.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 12-02-2011, 12:35 PM   #2421
hopsing's Avatar
I really like my Savox 1257tg in mine
Steve Butts
Old 12-02-2011, 02:14 PM   #2422
tomdav's Avatar
Trader Rating: 42 (100%+)
Well after two races I have an outdrive thats shot. It was on the left side primarily and its hogged out to where the cvd will not move freely under power. Sounds like this is an isolated case as no one else is having the same problem.
Just rebuilt the diff with some Bfast balls and it feels nice. I flipped the diff so I can race on Saturday but will be buying some new outdrives as soon as they are in stock.
Tom
The Couve, WA
davesrctracks.net
tomdav is offline   Reply With Quote
Old 12-02-2011, 02:16 PM   #2423
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
I heard from a fellow racer the 210 has rear hinge pin problems . Since they are back ordered has anyone found a substitute that will work ?
Originally Posted by Briguy View Post
I'm picking up this buggy tomorrow . What do you guys recommend for gearing a 13.5 ?
Anyone ??
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 12-02-2011, 02:19 PM   #2424
Davidka's Avatar
Trader Rating: 75 (100%+)
Is this correct?
Something worth considering with venting: If you plan to use traction compounds on your tires, you should put vent holes in the rims. Holes in the tires will allow tire sauce to eat the foams quickly. If you're running outdoors on looser surfaces, vent holes in the tires allows dirt to escape.
Old 12-02-2011, 02:22 PM   #2425
lockmouth's Avatar
Trader Rating: 33 (100%+)
Anyone ??
The hinge pins on the 210 are rock solid... he must have his cars mixed up.
MARIO KNOX
HOTBODIES RACING / FULL THROTTLE RACEWAY (OWNER / OPERATOR)
lockmouth is offline   Reply With Quote
Old 12-02-2011, 02:35 PM   #2426
tomdav's Avatar
Anyone ??
Maybe he is talking about the plastic suspension holders. They are in stock at Losipartshouse.
http://www.losipartshouse.com/servle...ead-and/Detail
Tom
The Couve, WA
davesrctracks.net
Old 12-02-2011, 02:39 PM   #2427
dirtydan's Avatar
Trader Rating: 47 (100%+)
im wanted to know if anyone has tried a diff from another brand on this car? only reason im asking is because i need a new circlip and i dont have one here local, but i can pick up an ae diff or kyosho diff, but not sure if they will fit and i dont want to waste my money on one and have it not work.
dirtydan is offline   Reply With Quote
Old 12-02-2011, 02:57 PM   #2428
rcman182006's Avatar
Send a message via Yahoo to rcman182006
I've heard of the AE SC10 gear diff is a direct drop in w/ some shimming
-=-Charles Kilbarger-=-
Serpent SRX2 MM - D4 17.5 - Hobbywing Justock
AE RC10 Team Car - RevTech 17.5 - Hobbywing Justock
#NoChuck2015
rcman182006 is offline   Reply With Quote
Old 12-02-2011, 03:10 PM   #2429
Trader Rating: 520 (100%+)
You will have to check you cvd's, as the durango pins are larger than both of those cars I believe..
flame56mx is offline   Reply With Quote
Old 12-02-2011, 03:39 PM   #2430
JS
JS's Avatar
Thanks for the feedback
I will end up putting vent holes since I will be running on a loose dirt and 50/50 clay and dirt track.
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
