Like Tree23Likes
Old 11-26-2011, 10:20 AM   #2281
hopsing's Avatar
Trader Rating: 13 (93%+)
Originally Posted by MantisWorx View Post
WEll finally got a chance to run a few packs through the car on a blown out outdoor track in MM4 config. I must say that i am impressed with the out of the box handling and at this point I dont even know what I would change on it and thats a good thing. It has tons of mid corner steering and decent grip all the way around. I went with RCshox 2 stage pistons 4 hole 1.3/1.4 with 17.5wt in the front and 15 in the back and the AE garodisc. Even that thin the car would not chassis slap and has plenty of pack, the chassis barely has any scratches on it at all. I cant wait to get on a track with grip and see how it performs but so far i am liking the MM4. now on the not so good, on the third pack i let a friend take some laps and on about the 5th lap he started having traction issues and kept tagging the walls so i pulled it and went to twist the dif and "POP" something broke or got bound up. At the time it sounded like i snapped a screw inside the dif and it lost drive. When i got home and took it apart sure enough the clip came out of the groove, so used the guide and put it all back together again (lots of screws!) and it did it again with in 1min of me twisting the dif. obviously this is a problem, i know this has been talked about but it sux!
The big thing is to make sure the snap ring isnt overcompressed....if it is, it will never "snap" back into the groove (especially if it has popped out once already). After my initial problem with the diff, I pulled it all back apart and actually spread the snap ring out slightly. During reassembly I was very carelful to compress the snap ring the absolute minimum to get it into the outdrive. Havent had a problem since even with a "used" snap ring. Also make sure the washers are in correctly or it will just compound the problem. One more thing is to not overtighten the diff initially before break in.
Steve Butts
AKA, TrakPower, Serpent America/Desoto Racing, TrackStar, Futaba, EKD Paints
hopsing is offline   Reply With Quote
Old 11-26-2011, 11:42 AM   #2282
FastPete's Avatar
Trader Rating: 44 (100%+)
For sale
Durango DEX 210 with extras used twice
Authorized Dealer for /Agama / Tekno / Team Associated / Schelle / Hobbywing / PT Racing Shock & Diff oil / Serpent / Tekin / JConcepts / AKA / Proline / Savox / M2C / Picco / www.fiercercsolutions.com Like us on facebook www.facebook.com/FierceRCSolutions
FastPete is offline   Reply With Quote
Old 11-26-2011, 02:55 PM   #2283
tomdav's Avatar
Trader Rating: 42 (100%+)
First race with the 210 last night and I can say I'm happy with the purchase. Car was easy to drive and behaved well despite the lack of setup help. The big thing I noticed was the massive down travel this has out of the box. I think this really gives the impression of massive traction and the ability to flat land off any jump without being upset. If you race on a smooth high bite track it makes for a lazy handling car. I do like the ability to to use the droop screws for quick adjustments but they are not really easy to use as the angles required to access them might require a ball driver or removal of camber links. The diff is a dream. Built completely stock and with the help of this thread I can say its a big plus. After 12 packs last night on a high bite track with a mod motor its still butter.
One the minus side I did pop a few ball cups. I used the older style cups and lost the steering links only. I think the lack of servo saver may be a factor. I'm not complaining to much as I think the ackerman rack would have been broken if I had a more durable ballcup. I also had massive bump steer and was baffled until I noticed I had the ackerman ballstuds on upside down for most of the day.
One my wish list would be a longer chassis and a much beefier rear shock tower and steering rack.
Tom
The Couve, WA
davesrctracks.net
tomdav is offline   Reply With Quote
Old 11-26-2011, 03:07 PM   #2284
hopsing's Avatar
One my wish list would be a longer chassis and a much beefier rear shock tower and steering rack. That thing has some flex.
Awesome to hear!
On the note about ballcups....I still use the HD ones that come with the 210, and after near 25 battery packs, have yet to pop one off and can adjust mine while on the car still with no issues.
Carbon fiber rear shock towers and ackerman links are available if it suits you from a few different sources, and there is also an aluminum ackerman link available from Racers Edge.
Not sure about needing a longer chassis though, I kind of wondered why the car wasnt longer from the start but after driving it, I cant see why it would need to be. The car has traction, steering and stability what else do you need!
Steve Butts
Old 11-26-2011, 03:16 PM   #2285
MantisWorx's Avatar
Trader Rating: 28 (97%+)
well i have been fighting this bastard all day!! i swear i cannot for the life of me figure out what is going on, i have built 100's of ball difs from mini-z's and up. i have changed every component and it still does the same thing. from what i can tell for some reason the thrust assembly locks up but only in one direction??? you can twist it to the right about four rev;s and then it locks up, if you spin backwards it releases and acts normal but will lock up at almost the same exact spot. i do have the original clip still until my new ones come in but i really cant see how the clip can make this happen (not saying it cant, i just dont see it) i bent the clip outwards, and it is not popping out of the slot because the entire time the dif is working it just gets tight. i mentioned yesterday that when i was spinning it it went pop and now i realize that it was tightening up and then popping the clip out. so for now it just going to sit on the shelf til the new clips come in and hopefully it will go right after that......... the thrust washers are assembled right everything is right as i have taken apart at least 20 times today. oh one more thing since i decided to shelf it for the week i went ahead and put it back together but flipped the thrust bearing washers upside down so the groove are on the outside and it actually feels better but dont know how tight the dif is yet, it just seems like for some reason the thrust ssembly is locking up, i even polished the inside of the housing to stop it!
MantisWorx is offline   Reply With Quote
Old 11-26-2011, 04:00 PM   #2286
hopsing's Avatar
That is weird Marcus! So when you spin the right rear tire clockwise, the diff tightens up? Just like if you were actually tightening the diff screw? Wondering if the diff nut is bad? Replace that yet? Factory thrust assembly or Xray or Schuey? I have a Schuey carbide one to try and it looks exactly the same as the stock one (though I havent measured it). Have the washer that goes in between the two middle diff bearings? Just throwin out some ideas I build my diff exactly the way that TD recently posted on their site and it works perfect and is really smooth for all stock components. We'll get this figured out!!!
Edit....realized you run mid motor, so your diff screw shoud be on the left side of the car, and the nut on the right.
Steve Butts
Old 11-26-2011, 04:11 PM   #2287
tomdav's Avatar
Tom
The Couve, WA
davesrctracks.net
Old 11-26-2011, 04:16 PM   #2288
hopsing's Avatar
oops...
Steve Butts
Old 11-26-2011, 04:21 PM   #2289
hopsing's Avatar
Make sure the thrust washer with the smaller inner dia. Is installed in the outdrive first. It's possilble the washer with larger inner dia will move a bit and contact the outrive and bolt causing them to lock up.
Thats very well possible too....with diff screw head being tapered its possible that it could sit into the larger washer too deep and cause it to come in contact with the thrust bearing and the other smaller washer and making it all bind up. Doubly double check the washer orientation, use calipers to make sure of the sizes of the washers!
Steve Butts
Old 11-26-2011, 05:09 PM   #2290
Where do you guys think i should gear an 8.5 3RM setup. I always feel like im undergeared. running 87/26. Running on a medium/large track.
Team Durango DEX210/RS PRO
Axial Exo Terra
Losi Ten-SCTE
ProMatch/High Velocity Lipos
CRCRC
egilliland23 is offline   Reply With Quote
Old 11-26-2011, 05:27 PM   #2291
firecat's Avatar
as far as the thrust assembly locking up I had a similiar problem after a rebuild.it is the c clip/snap ring popping out of groove. u have to expand the ring when inserting it into housing and make sure it is seated properly after doing this i have had no problems.
team scream racing/ts racing/kyosho mp9 tki3/ xray xb2 xb4/Wolcott hobbies and airsoft/rc madness
firecat is offline   Reply With Quote
Old 11-26-2011, 07:20 PM   #2292
Matt Howard's Avatar
Ever have one of those days where you're car runs awsome but you just don't get the breaks, that was my day today. Running 17.5 "blinky" for the first time ever with my new DualSky esc/motor combo and my car was awsome. TQ'd by almost a lap and would of qualified 2nd in mod Unfortunatly got caught up in lapped traffic in the main and popped a turnbuckle. Went with 1.2 4 hole front with 25wt oil and black springs, rear was 1.3 4 holes with 25 wt oil and light red springs.
*rant on*
Durango really needs to come up with a stronger rear shock tower, went through two of them today to bring my tally up to 3 so far. I've got a carbon fiber one coming from atomic carbon but they REALLY need to redesign this part.
*rant off*
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 11-26-2011, 07:38 PM   #2293
MantisWorx's Avatar
tripled checked all of the washers, completely changed the screw and it still did it, changed the nut to a regular nyloc and it still did it. polished the inside to allow the outermost washer to spin, changed balls, removed one of the internal ball bearings to see if maybe it was binding on the clip, nothing. machined off about .005 from the end of one of the outdrives thinking that it was binding on the clip and it still does it. im truly baffled, i went through two packs yesterday trouble free and then all hell has broken loose. I am a machinist and have plenty of measurement tools to verify it all, it seems like something is just machined wrong although i cant find it. sometimes you can spin the dif a dozen times and it is super smooth with no high spots or anything and then BAM it locks up only in one direction like a one way bearing, its the damnest thing........
Old 11-26-2011, 07:40 PM   #2294
MantisWorx's Avatar
*rant on*
*rant off*
Matt now that i finally got a day of testing i know what i am sending you to try out.
Old 11-26-2011, 08:07 PM   #2295
hopsing's Avatar
Huh, maybe a bad bearing in there somewhere thats locking up intermittently? That is very odd.....
Steve Butts
St Ives RC Club B4Bandit Australian Racing 16563 Today 04:32 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 6 (1 members and 5 guests)
peter george
