Durango DEX210 Thread
#2266
I will be running in the stock blinky class in a couple weeks, and I will be using the novak ballistic 17.5. I have read the 87t spur is way to big for 17.5 motors so I ordered the RW 69, 75, 81 and 85 spur gear. Does anyone have a suggestion for gearing this buggy?
Also, any suggestions for an esc? I was looking at the team Orion, and the hobbywing looks identical. My other inclination is a LRP. What do you guys think?
#2268
#2270
R/C Tech Elite Member
I had Tekin for the last three years, and loved them, giving the Orion a try right now, but if we ever ran boosted 17.5, I would use a Tekin, although blinky mode would even things out. Actually the Hobby wing looks more like an LRP to me... 17.5 blinky will more about which motor you pick IMO ..
#2271
#2272
Just a quick pic from my club race at SDRC Raceway in San Diego on Wednesday night....that's Patrick See's 210 behind mine. I qualified 3rd and Patrick 4th in 2wd exp mod. I led half the race and had a brain anurism dropping me to 3rd/4th. Got back to 2nd and blew it again dropping to 3rd again. Patrick had some bad luck and had to pull off for 4 laps before rejoining the race. I did set hero lap for that particular run though so I know the car is fast
My car is just soo easy to drive that any mistakes made is purely my fault.....cant wait to hit the track again!
I have a starting set up for loose to med grip indoor clay on Petit RC..... the grip came up a little at my local track so I had to make a couple of small adjustments. This car responds soo well to minor changes. Just awesome.
#2273
Finished mine tonight, again not the easiest build, but lack of sleep may have played some part of that.. I destroyed my first diff retaining clip, but there was a Fastenal shop local that had a replacement. I found a spring steel instead of the stainless, I think it will hold up a little better, and they are cheaper..
http://www.fastenal.com/web/products...u=35200&ucst=t
#2276
This car I thought was a nightmare build. Don't hate.... just talking about build only. The car is quality and looks to drive pretty sweet. But I was very un-impressed with the build, instructions, manual, and packaging. Have some calipers out!!!! or you have to memorize what part number the bolts are, cuz you couldn't assume anything. This was because of the 4.3 million different screws and their individual different lengths. Then all the plastic doo dads and spacers and uggg. Terrible build. BUT....once built, it looks like that all goes away. Car good. Build bad.
#2277
WEll finally got a chance to run a few packs through the car on a blown out outdoor track in MM4 config. I must say that i am impressed with the out of the box handling and at this point I dont even know what I would change on it and thats a good thing. It has tons of mid corner steering and decent grip all the way around. I went with RCshox 2 stage pistons 4 hole 1.3/1.4 with 17.5wt in the front and 15 in the back and the AE garodisc. Even that thin the car would not chassis slap and has plenty of pack, the chassis barely has any scratches on it at all. I cant wait to get on a track with grip and see how it performs but so far i am liking the MM4. now on the not so good, on the third pack i let a friend take some laps and on about the 5th lap he started having traction issues and kept tagging the walls so i pulled it and went to twist the dif and "POP" something broke or got bound up. At the time it sounded like i snapped a screw inside the dif and it lost drive. When i got home and took it apart sure enough the clip came out of the groove, so used the guide and put it all back together again (lots of screws!) and it did it again with in 1min of me twisting the dif. obviously this is a problem, i know this has been talked about but it sux!
#2278
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 42 (100%+)
#2279
so when is the gear dif option coming??
