Like Tree23Likes
Old 11-23-2011, 09:30 AM   #2236
Crazy Carl's Avatar
Trader Rating: 7 (89%+)
Any ideas what pinion to use with the stock spur for a 10.5 and 13.5?
Crazy Carl is offline   Reply With Quote
Old 11-23-2011, 09:32 AM   #2237
x7tristan's Avatar
Originally Posted by Jmuck69 View Post
How did you break the mounting tabs? i have had this servo in my B4 for a year with glued servo saver and no issues.
No idea how it broke but I didn't have a servo saver. Maybe it just took all the force when I crashed once. It was something I just randomly noticed and not after an obvious accident.
TJ
DURANGO DESC410R
x7tristan is offline   Reply With Quote
Old 11-23-2011, 10:35 AM   #2238
Default questions
Hi guys... I was thinking about buying a durango 2wd buggy... can you guys tell me what you like and dislike so far about the buggy... I have a Losi 22 so I'm trying to compare.. and are the parts hard to find? Any feedback would be appreciated.
jjohnson555 is offline   Reply With Quote
Old 11-23-2011, 11:24 AM   #2239
Trader Rating: 66 (100%+)
I know this might not be the right place to post this question about speedo and gearing but it is in a 210! Ok here's the deal, I've got a tekin rs in the car and I put in a 8.5 (x-12) last night and after 4 minutes the motor was 112 and the speedo was 156! The motor has the 4dot -10 insert in it and speedo is set to blinky, gearing is 81/25, any suggestion?
If you can't race it or sleep with it, it ain't worth having!
Gwoodrc is offline   Reply With Quote
Old 11-23-2011, 11:27 AM   #2240
Jmuck69's Avatar
Did you check to see if gear mesh is too tight or if there is binding in the tranny?
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 11-23-2011, 11:31 AM   #2241
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Yeah leave it alone. 156f isn't hot at all. The RS has an onboard temp monitor on it that is far more accurate than temping the outside of the unit. It looks like this:
You have no concerns until you start seeing 6 led's.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,KoPropUSA,JConcepts,Avid RC,MIP,SikLidz,ImagineItGraphx, FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 11-23-2011, 12:07 PM   #2242
murky123's Avatar
is there a kit setup sheet ? that I can follow during the build?
Im down to the steering knuckle, just curious what inserts to use according a stock out of the box set-up sheet
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 11-23-2011, 12:10 PM   #2243
Matt Howard's Avatar
4mm trailing is the kit setup
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 11-23-2011, 12:11 PM   #2244
hopsing's Avatar
Trader Rating: 13 (93%+)
If you go to http://www.petitrc.com/index.php?page=setup_sheet
There are a bunch of set up sheets for the 210 on there in both RM and MM configuration.
Steve Butts
AKA, TrakPower, Serpent America/Desoto Racing, TrackStar, Futaba, EKD Paints
hopsing is offline   Reply With Quote
Old 11-23-2011, 03:33 PM   #2245
jzemaxx's Avatar
Putting the 210 together and part # 329141-4 is missing. Called the # on the piece of paper that was in the box.....dude acted like I was smoking crack and calling the wrong # wtf?? Who do I need to contact since obviously the # on the piece of paper is useless.
Kyosho MP9 TKi2 Tekin
Kyosho MP9 TKi2/3 Novarossi BTT
jzemaxx is offline   Reply With Quote
Old 11-23-2011, 03:43 PM   #2246
Hi there,
I can help you out.....pm me your phone number and I'll try make sure you get whatever you need to get things back on track.
Sorry for the inconvenience.
Jason Snyder
Check out my "YouTube" channel
www.youtube.com/shortcourseworld
Jason Snyder is offline   Reply With Quote
Old 11-24-2011, 06:00 AM   #2247
triplesix's Avatar
I don't think, you can mount a pinion that big with a stock spur.
Last weekend I tried a 13.5, but I had to use a 76 spur (Cougar SV) with a 26 pinion.
Gear ratio is 2.6 so now you can calculate the desired final ratio (spur/pinion*2.6) yourself
MBX6R
B5M Lowrider
DEX410
Supastox GT
triplesix is offline   Reply With Quote
Old 11-24-2011, 07:29 AM   #2248
New DEX210 goodies
http://www.redrc.net/wp-content/uplo...EdgeDex210.jpg
aluminum steering rack from Racer's Edge
http://www.redrc.net/wp-content/uplo.../8Racing-1.jpg
Carbon Fiber stuff from 8Racing
RCTech #361
Old 11-24-2011, 07:30 AM   #2249
1armed1's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to 1armed1
Originally Posted by Matt Howard View Post
New DEX210 goodies
I already ordered the towers last night.
Serpent,Sanwa,Fantom Racing
92zero.com,Lunsford Racing,AKA Racing
TXD Snake Skin Graphix
1armed1 is offline   Reply With Quote
Old 11-24-2011, 08:49 AM   #2250
jurquhart's Avatar
Trader Rating: 22 (100%+)
Could someone please explain what adjusting the droop screws accomplishes as well as what is meant by wheel base adjustment and trailing axle adjustment also rear anti-squat
I am getting a Durango but I'm a little nervous about all these adjustments because I don't know what they are or what they do especially in combination with one another.
Is there a good resource that explains what these terms mean...I know Durango doesn't have it I've already asked them.
THanks and sorry for so many questions. Have a great Thanksgiving
John Urquhart
Sponsors include Caster Racing USA, Radiopost, and Trick-parts.com
Caster F8T e-Truggy with Tekin RX8 & 2000 motor Radiopost radio & servos
jurquhart is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 Yesterday 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
coaltrain
