Like Tree36Likes
Old 11-22-2011, 09:48 AM   #2206
x7tristan's Avatar
Originally Posted by Diff Balls View Post
I haven't used it with the 210 yet (not finished building) but it should be the same as with the B4.1. You just need to have some spacers, if you don't have any, I've used bearings, washers and even the cones from the rear axles.
spacers where? shoudnt the hudy side plates fit right up to the hub? the 210 axle is too large to fit through the hudy 1/10 side plates.
TJ
DURANGO DESC410R
x7tristan is offline   Reply With Quote
Old 11-22-2011, 10:42 AM   #2207
rcman182006's Avatar
Send a message via Yahoo to rcman182006
Originally Posted by MantisWorx View Post
back to the 3-4 gear and its bending my mind! the idler gears on the 4 gear are both smaller than the idler gear on the 3 gear. now since both gears are the same size it technically makes them become one of the same size and it is smaller. so wouldnt that make the ratios different especially since the top and dif gear are the same?
Its been mentioned before somewhere, the FDR is the same in both 3 and 4 gear
-=-Charles Kilbarger-=-
Serpent SRX2 MM - D4 17.5 - Hobbywing Justock
AE RC10 Team Car - RevTech 17.5 - Hobbywing Justock
#NoChuck2015
rcman182006 is offline   Reply With Quote
Old 11-22-2011, 11:07 AM   #2208
MantisWorx's Avatar
Trader Rating: 28 (97%+)
i cant for the life of me figure it out the idler gears on the four gear are 28t and the gear are 34t. since the 28t's are the same size they equal each other out and equal 28t. i dont know how you can make 2 28's equal 34??
MantisWorx is offline   Reply With Quote
Old 11-22-2011, 11:20 AM   #2209
YOU CAN'T
I have left this subject alone because every time I try to help on this thread some know it all with 5000 + posts tells me i'm wrong. But it is mathmaticly imposible for the 3 & 4 gear setup to have the same FDR with a differant number of teeth.
Olscool is offline   Reply With Quote
Old 11-22-2011, 11:33 AM   #2210
TAMAK's Avatar
Trader Rating: 28 (100%+)
Originally Posted by Olscool View Post
YOU CAN'T
I hope your not an engineer. . The idlers do NOT matter, unless they drive something. All the idlers do is provide a "gap" or energy tranfer between the two "Active" gears. Which provides the same ratio as if they were connected directly...
So the diff gear and the top shaft gear are the only two gears you need to worry about when you talk about FDR
http://en.wikipedia.org/wiki/Gear_ratio
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 11-22-2011, 11:38 AM   #2211
Huleboer's Avatar
YOU CAN'T
FDR IS the same.
The idler gear is irellevant. As all the idler gears work by them selves and not on a fixed axle, all that matters is the first gear (the layshaft gear connected to the spur) and the diff gear. There could have been 500 gears in between in various sizes. As long as they work on their own axles it doesn't matter.
edit: Bah... Tamak beat me to it, and even gave a better explanation 8/
Team Associated RC8b3e w/ Hobbywing Xerun 150A 1800KV and Gens Ace 6750mAh 70c
Huleboer is offline   Reply With Quote
Old 11-22-2011, 11:47 AM   #2212
No, I am not an engineer.
THANK YOU for the education.
Old 11-22-2011, 11:52 AM   #2213
TAMAK's Avatar
No problem, Alot of answers can be found if there is some reading done prior. In your case, you thought you knew something and got defensive, next time do some research. No worries though, this thread is full of alot of good people and and advice. Stick around.
Old 11-22-2011, 02:21 PM   #2214
Jmuck69's Avatar
Sneaky bastards snuck this one in...
http://www.amainhobbies.com/product_...Clearance-Wing
http://www.amainhobbies.com/product_...Wing-65-Wide-2
No idea how the Finnisher will be interpreted with the DEX210 but its nice to see JC supporting the platform.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 11-22-2011, 02:38 PM   #2215
hopsing's Avatar
Trader Rating: 13 (93%+)
I'm sure it helps that Durango driver Billy Fischer is also a JConcepts driver
Steve Butts
AKA, TrakPower, Serpent America/Desoto Racing, TrackStar, Futaba, EKD Paints
hopsing is offline   Reply With Quote
Old 11-22-2011, 02:47 PM   #2216
Trader Rating: 520 (100%+)
Yuk, looks like a b44
flame56mx is offline   Reply With Quote
Old 11-22-2011, 02:49 PM   #2217
hopsing's Avatar
LOL....I hope you were joking since that was a B44
Steve Butts
Old 11-22-2011, 02:58 PM   #2218
Jmuck69's Avatar
Just a place holder until the official images are released. hopefully it has a little more clearance in the side pod areas.
B6D | B64D
Old 11-22-2011, 03:00 PM   #2219
Jmuck69's Avatar
My 210 with R10 Pro ESC, Orion motors, Lipos and servo.
Durango DEX210 Thread-img_7116.jpg   Durango DEX210 Thread-img_7117.jpg   Durango DEX210 Thread-img_7118.jpg
B6D | B64D
Old 11-22-2011, 03:02 PM   #2220
kwiksi's Avatar
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Yeah. Tell me about it.
Thanks in 2017 to
Xray/RC America - JConcepts - Trinity - Sanwa - Hobbywing - Exotek - PT Racing Oils -Schelle
kwiksi is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
