Like Tree27Likes
Old 11-20-2011, 10:57 PM   #2161
hopsing's Avatar
Trader Rating: 13 (93%+)
Originally Posted by murky123 View Post
can someone explane to me what the word "casing" means in the phrase : casing a jump ?
Inglish is not my native language
Its when you dont completely clear the landing area of the jump...if you come up short and hit the top of the jump we sometimes call it that.
Steve Butts
AKA, TrakPower, Serpent America/Desoto Racing, TrackStar, Futaba, EKD Paints
hopsing is offline   Reply With Quote
Old 11-20-2011, 11:14 PM   #2162
fullsyzz's Avatar
Trader Rating: 103 (100%+)
Casing a jump....at the 8 second mark....
+ YouTube Video
fullsyzz is offline   Reply With Quote
Old 11-20-2011, 11:35 PM   #2163
brandundecided's Avatar
Has anyone else noticed the chatter that comes from the rear driveshafts/cups when the suspension is in full droop? Has anyone found a solution to this I have racked my brain trying to figure something out and only thing I can think of is a longer cup which isnt an option.
brandundecided is offline   Reply With Quote
Old 11-21-2011, 03:00 AM   #2164
goBezerk's Avatar
Send a message via Skype™ to goBezerk
Let me guess, 3deg kickup, no droop screws and no shock limiters...sounds like you either need to put your droop screws back in or like myself go olskool and put a shock limiter or two in
OR, it could be like discussed much earlier on -
Durango DEX210 Thread
► Paul Sims - KRCORCC - BRCCC - TFTR
► R/C racin', 1 percent car, 99 percent driver
► BEZERK RC on Facebook, PayPal accepted
► PROLINE - TEAM AE - GFORCE - R/C Race Supplies
goBezerk is offline   Reply With Quote
Old 11-21-2011, 08:32 AM   #2165
x7tristan's Avatar
has anyone found out which diff plates (other than durango) will fix on the dex210? I'd like to replace mine but not wait for the official durango ones.
TJ
DURANGO DESC410R
x7tristan is offline   Reply With Quote
Old 11-21-2011, 08:46 AM   #2166
hopsing's Avatar
Need to replace them already?
Have you flipped them over to use the other side already?
Steve Butts
Old 11-21-2011, 09:10 AM   #2167
x7tristan's Avatar
yeah i built the diff wrong a few times already and have put grooves on both sides of the plates already
TJ
DURANGO DESC410R
Old 11-21-2011, 09:11 AM   #2168
Bri from Chi's Avatar
It means he dorked it.
Team Durango**Hobbico**Futaba**Trak Power
Leisure Hours Raceway-Joliet, IL www.Leisurehoursraceway.com
*****ELECTRIC FOREVER*****
Bri from Chi is offline   Reply With Quote
Old 11-21-2011, 09:35 AM   #2169
Trader Rating: 132 (100%+)
Default Motor config
crazy question but does it matter which side the motor is on when running MM config?
skyline1015 is offline   Reply With Quote
Old 11-21-2011, 09:48 AM   #2170
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Yeah this is caused by the extreme angle. You should be limiting the droop with the screws. Maximum down travel is a steep angle on the axles.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 11-21-2011, 09:49 AM   #2171
hopsing's Avatar
Yes...... 4 gear is the most popular way to run it..... the only time you would run 3 gear is if its SUPER high bite typically, like asphalt or carpet. But you can always try both ways to see which works best for YOUR driving style.
Steve Butts
Old 11-21-2011, 09:51 AM   #2172
Trader Rating: 19 (100%+)
Yes and no- it depends on how many gears you have in the transmission. With a MM4 setup the motor plate is on the left (driver's) side. With MM3 the plate is on the right side. Each is better suited to specific grip levels, though I can't remember which is better for what grip level as we have only run RM configurations to date.
XRAY, RC America, MOTIV, Sanwa, Arrowmax, Neverlift Racing Apparel
Jonny5ive Designs- by racers, for racers!
Jonny5 is offline   Reply With Quote
Old 11-21-2011, 10:08 AM   #2173
Whats a god battery pack for a 9.5 turn motor in this buggy? Thanks
AssasinRacing is offline   Reply With Quote
Old 11-21-2011, 01:55 PM   #2174
hopsing's Avatar
I run Racers Edge 4000mah/60c shorty packs in my car.....plenty of power, light weight and being able to move the battery placement back and forth to adjust weight distribution is just dialed.....
Steve Butts
Old 11-21-2011, 03:08 PM   #2175
We have a few of these coming as well. We've been using the IP 5000 40c and the car is good, but the lighter pack along with more weight bias adjustment should make it even better.
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
