Like Tree26Likes
Old 11-20-2011, 11:54 AM   #2146
Konich's Avatar
Yes if you take the hex off use the cone and spacer off the 410 and you can use both AE or Losi wheels on the rear just like the 410
Tresrey Spec DEX410 - Yaiba Spec B5M
Konich is offline   Reply With Quote
Old 11-20-2011, 12:29 PM   #2147
tom235's Avatar
thanks thats awesome to know now i can use the 10 sets of b4 tire/wheels i have lieing around
tom235 is offline   Reply With Quote
Old 11-20-2011, 01:39 PM   #2148
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Well, I made about yen laps before I flipped upside down and broke the rear shock tower,this is not cool drove 45min to test and didnt drive 5 minutes........ The car drove very well though. I hope durango does something about this as it is definately a defect in either design or matl.
MantisWorx is offline   Reply With Quote
Old 11-20-2011, 02:58 PM   #2149
1armed1's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to 1armed1
I broke 2 rear towers yesterday.
The first was caused by casing a jump and flipping over landing hard on the tower. As hard as I hit many cars would have broke.
The second was on a flat landing, all 4 tires hit at the same time.
I also broke an inner rear camber mount.
I was in a high speed corner, traction rolled and SNAP!
I will be looking into an alternate method/mounting point for the inner rear link and I think I have a idea for a brace for the rear tower.
Both towers that I broke and every broken one I have seen on here and at the track has broke in the same spot.
I think there is a design flaw that was not realized during team testing but now needs to be resolved.
The car is absolutely amazing but has a few issues that need to be fixed.
Dayton
Serpent,Sanwa,Fantom Racing
92zero.com,Lunsford Racing,AKA Racing
TXD Snake Skin Graphix
1armed1 is offline   Reply With Quote
Old 11-20-2011, 03:09 PM   #2150
MantisWorx's Avatar
Dayton
well i am designing my own as we speak! i will try 6mm delrin at first to see how it holds up. i dont think Carbon will be a good choice because you will break the gearbox if it is too stiff especially since we are seeing camber mounts breaking. to be honest i think good ole G10 may be the best material to use but its ugly! at this point i dont care about looks. once you start breaking your car its harder to push because you dont want to break.....UUUUUGH
Old 11-20-2011, 03:10 PM   #2151
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 39 (100%+)
Dayton
Dayton, i think i will be making some HD R towers right off the bat for mine
*Vandal 4wd Late model*XXX-T sprinter*Micro scale specialties 1/24 'rock monster' crawler*MSS Micro-Rail*MSS Micro-Funny*MSS Micro-Outlaw*
2wdMod is offline   Reply With Quote
Old 11-20-2011, 03:17 PM   #2152
brandundecided's Avatar
Originally Posted by tom235 View Post
the b4 has a pin not a hex that would be sweet if they did fit i have a ton of tires for the b4
I was referring to the hexes proline and jconcepts released or possibly hexes from a 22
brandundecided is offline   Reply With Quote
Old 11-20-2011, 04:01 PM   #2153
dirtydan's Avatar
Trader Rating: 47 (100%+)
i have a question about the c clips. i installed it with the beveled face towards the thrust washer and after maby 10 laps the diff started slipping like if the c clip has come lose. i have yet to disassemble the diff, but my question is are there any other alternatives to using the c clip in the diffs? this is the third time i take the diff apart today because of this issue. the first 2 times it was due to have the flat side facing the thrust washer, but now with it facing the correct way it still poped off. i also see that durango has a part number for the gear diff, but are they available already?
dan
dirtydan is offline   Reply With Quote
Old 11-20-2011, 05:31 PM   #2154
Mopar's Avatar
Had 1st night with the car last night and the car did great. Made 1 major change to pistons and oil after 2nd practice. Then minor changes the rest of the outting. Was 3rd qual after 1st round and 2nd qual after 2nd round. The car was better in the main but the driver failled the equipment. This thing was 2 laps better than my other UK car. My S car was never consistant and was always loose. Was running RM4 for this outting but will try RM3 for next time mainly from what Patrick said about the change.
Mopar is offline   Reply With Quote
Old 11-20-2011, 06:42 PM   #2155
hopsing's Avatar
Trader Rating: 13 (93%+)
dan
You also have to make sure that the small washer goes into the outdrive first, then the thrust bearing, and then the larger diameter washer last. Also, if you reused the snap ring, you need to spread it out some so that it is slightly larger....if you have taken it in and out a couple times it wont spring back to the original diameter and will never work like its supposed to, it will always pop out with pressure applied escpecially if the small thrust washer is pushing against it intstead of the larger one.
The best thing to do is to install a new one, but if thats not possible, just slighlty open up the ring some. You also need to make sure that you dont over compress the spring when installing it or it wont spread back open into the groove tightly either. One thing I do is after its installed n the groove, take a small flathead screwdriver and twist it in the open end of the snap ring to make sure its spread out into the groove.
And no, there is no other method of holding the thrust in....the system works great, there was just a failure in the instructions on how to install it correctly to avoid these problems.
Steve Butts
AKA, TrakPower, Serpent America/Desoto Racing, TrackStar, Futaba, EKD Paints
hopsing is offline   Reply With Quote
Old 11-20-2011, 06:44 PM   #2156
hopsing's Avatar
My car is really good at SDRC Ed And I'm running RM3 as well.
Steve Butts
Old 11-20-2011, 06:49 PM   #2157
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Flipping over backwards and snapping a shock tower is not a defect. You could say you would like the tower to be stronger but the cars is not meant to be upside down travelling forward. A B4 will often snap the front tower doing this exact "flop."
IF you snapped a tower casing the jump make sure when you cycle your suspension that the shocks aren't bottoming out before the chassis is.
I raced with 3 other 210's this weekend all driven by good drivers and none of us broke anything. Plenty of cars broke this weekend on the track.
I can say that you should never allow your diff to slip. One driver allowed his to slip during practice and it damaged the balls beyond use. IF it barks, pull it over and fix it.
So far what I've found is that this car is very sensitive to weight placement and rear shock setups. Don't go too drastic when making changes as each little change can be felt.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 11-20-2011, 07:51 PM   #2158
1armed1's Avatar
Agreed, but....
When you flat land and a tower snaps there is an issue.
I have plenty up travel, you can push the chassis to the table and still pick the rear wheel up off the table 4-5mm.
The first tower I broke would have broke on any other car, it was a brutal hit as stated in my previous post, but the second was on a flat landing and that should never happen with enough up travel.
I had 2 race days and around 30 practice packs through my car before braking any parts.
The car is very good,
I did a lot of testing with a shorty pack after the mains last night and I'm liking the results.
Dayton
Old 11-20-2011, 08:14 PM   #2159
hopsing's Avatar
Agreed, but....
Dayton
Here's what I think MIGHT be happening....not sure that it applies to you but I know in the three full race days I have on my car I've broke two rear towers....both times I had or was involved in a pretty good crash that had me ending up on lid pretty hard beforehand...no harm no foul BUT, what happened a few laps later were hard flant lands that ended up with broken towers I think whats happening is that the upper crossbrace is breaking right in the middle when the car lands on its "lid" hard....that then leaves no real supoprt for the remaining tower "ears" and ends up in catastrophic failure with an overley hard landing.
The reason I believe this may be the issue, at least in my case, is that I ran a full race day without breaking a tower.....and I was casing a 20ft quad HARD several times over the course of the day...and I mean HARD. I cringed everytime I came up short because I only had one spare. And that day, I never once ended up on my lid (very rare actually )
Just my observation....
Steve Butts
Old 11-20-2011, 10:50 PM   #2160
murky123's Avatar
can someone explane to me what the word "casing" means in the phrase : casing a jump ?
Inglish is not my native language
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16570 Today 03:48 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
