Like Tree17Likes
Old 11-19-2011, 11:03 PM   #2131
mjk1210's Avatar
use some chapstick, or grease, or wax on the turnbuckle threads when threading on the ball cups. Then they won't twist off when making adjustments.
Speed Passion USA - speedpassion.net
Leisure Hours Hobbies & Raceway - leisurehoursraceway.com
"Watch the quad. Watch the quad! ...SHA-BAM!"
mjk1210 is offline   Reply With Quote
Old 11-20-2011, 05:38 AM   #2132
MantisWorx's Avatar
Trader Rating: 28 (97%+)
i use oil on the threads when assembling, maybe the second batch specs are different? either way i will figure it out eventually.
what bladders will fit these shocks?
will AE spurs fit?
MantisWorx is offline   Reply With Quote
Old 11-20-2011, 06:03 AM   #2133
ABBOTT's Avatar
not sure about the bladders but was told losi springs work well, Ae spur has to be reamed out a little to work
SmacTrac / STL Dirtburners / Blaze RC
ABBOTT is offline   Reply With Quote
Old 11-20-2011, 06:05 AM   #2134
MantisWorx's Avatar
thanx!
Old 11-20-2011, 08:08 AM   #2135
hopsing's Avatar
Trader Rating: 13 (93%+)
will AE spurs fit?
My car is a first batch....
Check here http://www.tsrproducts.com/index.php/durango.html for bladder kits.
Steve Butts
AKA, TrakPower, Serpent America/Desoto Racing, TrackStar, Futaba, EKD Paints
hopsing is offline   Reply With Quote
Old 11-20-2011, 08:09 AM   #2136
I wish my ballcups popped off easier. Yesterday my car took a hit in the left rear and broke the tranny case tab for the ballstud mount.
rcmikel is offline   Reply With Quote
Old 11-20-2011, 08:18 AM   #2137
hopsing's Avatar
....bummer! Thats the one thing that worries me on the car but your's is the first I've heard of it happening to.
Steve Butts
Old 11-20-2011, 08:21 AM   #2138
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
You broke a factory ball stud in that position?
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 11-20-2011, 08:25 AM   #2139
hopsing's Avatar
Sounds like he broke the tranny case where the ball stud mounts to, not the actual ballstud.
Steve Butts
Old 11-20-2011, 08:30 AM   #2140
Super Moderator
oh snap!
I broke ANOTHER rear toe-block last night.
- RCSpecialties -
Old 11-20-2011, 08:31 AM   #2141
Super Moderator
Originally Posted by mjealey View Post
Yes the pin is in it. I was affraid the clip came out and was thinking that was it or something else wrong with the diff. Oh boy, I guess I wiull be tearing this whole thing apart tonight!!!! Yes I know it has been talked about, but do not feel like going back and looking for it as it is late. Refresh my mind on which way the circlip goes in as far as the stamped edge goes?
Durango DEX210 Thread
- RCSpecialties -
Old 11-20-2011, 10:05 AM   #2142
Ya, broke the tranny case. Got aluminum mounts being made for mounting the ballstuds. The mount will be attached at the shock tower mount screws. Will need to remove the plastic on the tranny case. It will also have two mounting holes instead of one. No more worries about braking that mount again.
Old 11-20-2011, 10:13 AM   #2143
brandundecided's Avatar
Will the rear hexes for something like a b4 fit on the rear axles?
brandundecided is offline   Reply With Quote
Old 11-20-2011, 11:18 AM   #2144
Huleboer's Avatar
Finally finished my buggy completly.
That was quite hard to make the paint tape stick and avoid the colors to overlap. Not my best, but it'll do.
And if you didn't guess it, I'm a Steeler supporter 8D
The hardware is Savox 1256tg, Turnigy Nano-tech 5600mAh, LRP SXX Comp and LRP Stock Spec 13.5t.
Team Associated RC8b3e w/ Hobbywing Xerun 150A 1800KV and Gens Ace 6750mAh 70c
Huleboer is offline   Reply With Quote
Old 11-20-2011, 11:22 AM   #2145
tom235's Avatar
the b4 has a pin not a hex that would be sweet if they did fit i have a ton of tires for the b4
tom235 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16562 Today 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
