Like Tree26Likes
Old 11-17-2011, 12:21 PM   #2026
grapejuice's Avatar
Trader Rating: 133 (100%+)
Originally Posted by Jonny5 View Post
Car looks good Justin! Do you guys run blinky or boosted? Looking forward to seeing you at Spektrum.
Thanks! And we were running blinky and I am definitely looking for to getting out to Spektrum and meeting the other half of the team!
MHOR RC Raceway / 5280 Raceway
grapejuice is offline   Reply With Quote
Old 11-17-2011, 12:48 PM   #2027
Matt Howard's Avatar
Originally Posted by Jmuck69 View Post
Does anyone else have some play between a fullsize lipo and the sidewalls and front to back in RM3/4? What are you using to shim it?
I used the fuzzy side of velcro cut into thin strips to take the movement out.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 11-17-2011, 02:39 PM   #2028
Jmuck69's Avatar
How do you seal up two of the holes in the pistons?
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 11-17-2011, 02:45 PM   #2029
hopsing's Avatar
Trader Rating: 13 (93%+)
A little glue and some kicker......or you can use a toothpick glued in and cut off.
Steve Butts
AKA, TrakPower, Serpent America/Desoto Racing, TrackStar, Futaba, EKD Paints
hopsing is offline   Reply With Quote
Old 11-17-2011, 04:52 PM   #2030
Trader Rating: 62 (100%+)
I used a soldering iron.
patrick is offline   Reply With Quote
Old 11-17-2011, 06:00 PM   #2031
Rideordieguy1's Avatar
Trader Rating: 45 (100%+)
Cool Gear help....
What's up guys I'm in need of gearing for a 13.5 motor. Any help is appreciated. Indoor track clay and have the rd4 installed !
Rideordieguy1 is offline   Reply With Quote
Old 11-17-2011, 06:03 PM   #2032
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
For an unboosted 13.5 setup, you will want to start somewhere around 78/28 or 81/29-30
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 11-17-2011, 06:06 PM   #2033
Smile Gear
Thnx dude I'll order some spurs now!
Old 11-17-2011, 06:08 PM   #2034
Super Moderator
http://www.ebay.com/itm/RW-Racing-81...item35b6a483a9
Here is your 81... im not sure how large of a pinion you can fit with the 81 though... im not sure a 30 would fit. Id say run a 78, but RW doesn't make one, you have to go down to a 75... heh.. if you wait 10 minutes, Ill go see how large a pinion you can fit with an 81
- RCSpecialties -
Old 11-17-2011, 06:11 PM   #2035
Super Moderator
an 81/30 fits great... with the motor all the way back, there is perfect teeth spacing. 81/31 is too tight. So you should have no problems runnin a 13.5 with the 81 spur... 28, 29, or 30 tooth pinion.
If you want to run the motor closer in, you will need to bump down to the 75 RW (also on ebay), and adjust your gearing accordingly.
- RCSpecialties -
Old 11-17-2011, 06:17 PM   #2036
Cool Sweet
Just ordered. 81 off EBay. Got pinions 29,30 and 31 coming on the am. It's crazy how u think your so close to being ready to run then remember u need to get the gearing right before u hit the track cause you'll have no parts. Thanks again dude!
Old 11-17-2011, 06:19 PM   #2037
Super Moderator
Get the 28 instead of the 31... you wont need the 31.
- RCSpecialties -
Old 11-17-2011, 06:37 PM   #2038
Jmuck69's Avatar
Amain has the RW spurs and more spare parts now.
B6D | B64D
Old 11-17-2011, 06:41 PM   #2039
ajj
ajj's Avatar
Trader Rating: 18 (100%+)
I'm going to be running 17.5T blinky. Anyone have experience with the 69T or 75T spur?
AJ
Associated SC5M, Hot Bodies D413, Durango DEX210, Durango DEX410, Mugen Seiki MBX7R
ajj is offline   Reply With Quote
Old 11-17-2011, 06:58 PM   #2040
rcman182006's Avatar
Send a message via Yahoo to rcman182006
My kit is on its way *dances*
what would be a good gearing start point for a Orion V2 13.5 w/ Tekin RS with or w/o boost and planning on reaming out a AE 75T spur for now
-=-Charles Kilbarger-=-
Serpent SRX2 MM - D4 17.5 - Hobbywing Justock
AE RC10 Team Car - RevTech 17.5 - Hobbywing Justock
#NoChuck2015
rcman182006 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16570 Today 03:48 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
