Like Tree33Likes
Old 11-17-2011, 08:28 AM   #2011
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Originally Posted by Bman's 3XNT View Post
Now that it has been a couple weeks for you guys, where is everyone settling on their front hubs? I have been running 2 on the trailing and 35 for castor. Car has some off power push coming off the sweeper into a 180 and is is a bit twitchy if I get on it to quick. So I was thinking of going to full trailing and cutting the castor down to 25. In the rear I run full toe, hubs forward, and rear shocks out on the bottom. Really helped keep the rear locked in. Good rear traction, but need a bit more steering for the 180's. Thanks...
The Full castor isn't helping your cause nor is the "full" toe. Try 3.5 toe in the rear, 30 caster and add 3/4 oz to the front of the car. Travis has weight9not sure how much) right on his front bulkhead through the opening of his shock tower, as do I.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 11-17-2011, 08:35 AM   #2012
Jmuck69's Avatar
I finally got my 210 in yesterday and put it together with the exception of shocks and electronics. It was a pleasure to build but I think TD is subsidised by the screw industry. This buggy is 60% screws! I'm waiting for the metal shock preload adjusters and gold shafts to come in today from Amain to finish that part. The plastic quality and tolerances are amazing and this is coming from a B4.1 which is loose and sloppy as a cheap whore. I ordered from Atomic Carbon the lipo strap, steering link and steering brace and should be here next week. I have the kit ball cups and studs on the car to use and if they give me repeated issues then I gold TC5 ballstuds and Kyosho hard ballcups on hand to swap. first race will be Sunday!
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 11-17-2011, 08:50 AM   #2013
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Wait till you need to take the diff out. 99% of the screws in the car need to be removed to get the diff out
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 11-17-2011, 09:06 AM   #2014
Trader Rating: 19 (100%+)
Originally Posted by grapejuice View Post
Good night with the car last night, feeling a lot more comfortable with it! (I started second)
http://www.youtube.com/watch?v=eOg-7j2INo0
Car looks good Justin! Do you guys run blinky or boosted? Looking forward to seeing you at Spektrum.
Originally Posted by Dammit138 View Post
I'm getting back into the Hobby. I used to race a 1/8 Losi 8 2.0 but after a fire I lost all my RC gear. So I'm starting over. Since my only experience is 1/8th buggy, do you think the 210 would be a good starting point for a 1/10 scale 2wd buggy? Or would a Losi 22 be a better starting point?
*Edit* My LHS doesn't really have much (or anything) for Durangos so I would be doing all parts replacement via web orders. That doesn't really bother me and I wouldn't mind being the only guy on the track with one of these cars. Also, I'm planning on starting up running the 17.5 class at my track.
Can't go wrong with the 210. It seems like you are fairly experienced so the fact that the build is slightly more involved than other buggies shouldn't matter to you. Durability wise thw buggy is as good or better than any other out there, and the tuning option are more extensive than any buggy on the market. Good out of the box setup too for a starting point. The only real downfall right now is parts availability, but they are starting to come in and should be fully available very soon. My lhs got a big order in with some of the more common things, arms and such. You won't be disappointed with it if you go the 210 route.
XRAY, RC America, MOTIV, Sanwa, Arrowmax, Neverlift Racing Apparel
Jonny5ive Designs- by racers, for racers!
Jonny5 is offline   Reply With Quote
Old 11-17-2011, 09:09 AM   #2015
Trader Rating: 66 (100%+)
Anybody running the shorty battery and if so where would be a good starting point for locating it (RM3)?
If you can't race it or sleep with it, it ain't worth having!
Gwoodrc is offline   Reply With Quote
Old 11-17-2011, 09:17 AM   #2016
jzemaxx's Avatar
Anyone have a loose outdoor setup. Going to run in RM4 config.
Kyosho MP9 TKi2 Tekin
Kyosho MP9 TKi2/3 Novarossi BTT
jzemaxx is offline   Reply With Quote
Old 11-17-2011, 09:22 AM   #2017
Bman's 3XNT's Avatar
Trader Rating: 70 (100%+)
Originally Posted by Jonny5 View Post
We were at full trailing and 30 degrees on Cush's car with 3.5 toe in the rear. Moving the front axle forward 1mm helped a lot with an entry push, but was stil stable middle out.
Taking some toe out of the rear should help mid corner rotation if your car is too locked down mid corner.
Originally Posted by triplesix View Post
2 on trailing here, 30deg castor
but i'm on mm4 though, running on carpet.
going from 4 trailing to 2 really brought the front end to life, as well as limiting front droop helped with push on exiting corners.
Thanks guys, The track is still fresh and not sure on how the car naturally performs. Being loose I locked in the rear and lost the front. I will try a happy medium until comes in.......
Team Durango DEX410 w/3 Diffs ;) The original
Xray Xb2 CE
www.rchr.biz------www.Wolcotthobby.com
Bman's 3XNT is offline   Reply With Quote
Old 11-17-2011, 09:49 AM   #2018
Jmuck69's Avatar
No joke! I was studying it to find a quick painless way to remove it...no luck.
B6D | B64D
Old 11-17-2011, 10:05 AM   #2019
hopsing's Avatar
Trader Rating: 13 (93%+)
I run a shorty with RM3 and run it all the way forward......not against the servo, but against the forward battery holder.
Steve Butts
AKA, TrakPower, Serpent America/Desoto Racing, TrackStar, Futaba, EKD Paints
hopsing is offline   Reply With Quote
Old 11-17-2011, 10:08 AM   #2020
Jmuck69's Avatar
Does anyone else have some play between a fullsize lipo and the sidewalls and front to back in RM3/4? What are you using to shim it?
B6D | B64D
Old 11-17-2011, 10:10 AM   #2021
WOW that seems like alot of weight foward, what rear toe do you run and did you add any other weight to the rear?
Old 11-17-2011, 10:12 AM   #2022
Team Tekin
Randy_Pike's Avatar
I'm running one standard L__i pad in rear and the rest of the void forward. Any standard battery pads will work.
Old 11-17-2011, 10:14 AM   #2023
Team Tekin
Randy_Pike's Avatar
I swapped the entire tranny in less than 10 minutes. If you look at the upper braces on top of the chassis simply loose the lower braces screws, remove the motor guard while keeping the wing mounts secured, remove the trans screws, out.
Old 11-17-2011, 10:21 AM   #2024
hopsing's Avatar
3 deg rear toe, no added weight. Med-high grip clay indoor track
The battery is still actually just rear of the center of the car. Going to the shorty actually gave me some more middle-exit corner steering I needed without sacrificing hardly any noticeable rear traction.
Steve Butts
Old 11-17-2011, 10:48 AM   #2025
Trader Rating: 45 (100%+)
Originally Posted by RC Bombshells View Post
Just in time for race 2 of 6 of the ELECTRIC MASTERS SERIES at The Vegas R/C Raceway. http://www.thevegasrcraceway.com
Give em hell, Jonah!
Nice paint job! That body is screaming to have an American Eagle painted on it...The body just looks like a bird.
Apex is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
