Like Tree27Likes
Old 09-11-2017, 08:28 AM   #19666
Do you have set up your shocks with rebound?
May you can look for some TD "type b -2 spring retainers", this also could help for lowering the right high and not having the collars screwed up that much?
But you would need two sets of them!
BIG BORE SPRING RETAINER (TYPE B) from Team Durango, TD330600
Greetings from Austria
Cat K2 / DEX410V3 / DEX410V5 / DEX210 / DEX210F / Cougar SVR /
YZ-10 '94/'95 WCS/
Spectrum DX3R
micholix is offline   Reply With Quote
Old 09-15-2017, 05:09 PM   #19667
theclutch's Avatar
Originally Posted by theclutch View Post
I'm running the DEX210 V1. Hey guys, first, since we have a parts shortage, what do you typically substitute for the ball ends? I noticed that the top links with the bend in it are longer than typical ball ends. Is there a known substitute?
Thanks in advance!!
Any known substitute for the ball ends?
XRAY XB4 2017, Durango DEST210R, XRAY XB4 2014, Vaterra Slick Rock, Durango DEX210, SpeedMerchant REV4, HB TCX, Traxxas EMaxx, HPI RS4 Pro, Tamiya TA02, Yokomo YZ10, Associated RC10 Team Car, Bolink Eliminator 10, Kyosho Optima, Tamiya HotShot, Tamiya Grasshopper
theclutch is offline   Reply With Quote
Old 09-24-2017, 07:29 PM   #19668
theclutch's Avatar
Default Gear diff o-ring 4x2 mm correct?
Originally Posted by micholix View Post
As for the o-rings on the geard diff, i use those in the link below from TD, but i think any 4x2 mm o-ring works!
Most of the 1/8 scale buggys use these sice in the shocks.
SILICONE O-RING P-4 (4x2mm 8pcs) (S30 BLUE) from Team Durango, TD330611
Originally Posted by WallyRC View Post
For the differentials I would at least use the purple P4. They have a higher S rating. Blue are great for shocks. I actually use one purple on the outside and blue on the inside. Someone gave that tip way back in this thread.
I actually have been using the standard orange Kyosho P4 with good results.
Micholix is right. Need P4 size o rings for the differential.
TDR330099 Orange orings work well too. I haven't tried the blue ones.
Hey guys, I was about to purchase the purple o-rings shown below but then stopped short.
https://www.amainhobbies.com/team-du...330612/p475294
I just measured the black x o-ring from the gear diff and cannot measure 4x2 mm in any way. It seems like the inner diameter is 5mm and the outer diameter is 8 mm (making the thickness of the o-ring around 1.5 mm). See the pic below. Are you sure that this will fit?
I just happen to have a Hot Bodies "P4" o-ring that I don't even remember what I used it for. But look and see how it's "loose" inside the diff housing compared to the original x o-ring.
Any thoughts? This is the gear diff for my DEX210 (original).
Old 09-24-2017, 07:40 PM   #19669
EbbTide's Avatar
Trader Rating: 35 (100%+)
I just measured the black x o-ring from the gear diff and cannot measure 4x2 mm in any way. It seems like the inner diameter is 5mm and the outer diameter is 8 mm. See the pic below. Are you sure that this will fit?
Any thoughts?
I use the 4mm o-rings. When you put it over the outdrive it expands and fills the hole. Never had any leaks with them.
EbbTide is offline   Reply With Quote
Old 09-24-2017, 08:13 PM   #19670
theclutch's Avatar
Thanks for the quick reply! When I put the o-ring on the outdrive and spin the outdrive, the o-ring spins WITH the outdrive vs. the outdrive spinning inside the o-ring. So the o-ring AND the outdrive both spin inside the housing. Is this the same with you?
Old 09-24-2017, 08:24 PM   #19671
EbbTide's Avatar
That's Okay if it spins with the outdrive. Once it is all assembled it should still spin freely.
Old 09-25-2017, 12:12 AM   #19672
CARD's Avatar
Originally Posted by Kremzeek View Post
I may still pick up that chassis for my son since he's running my old buggy this season.
I too have a son, but still too young at the age of only 4~
Can't want for him to get older, so I can bring him to LHS, pointing my finger to what ever I want, and tell the counter staff, "He, want thisÖ"
CARD is offline   Reply With Quote
Old 09-27-2017, 05:47 PM   #19673
EbbTide's Avatar
I saw something very nice recently on Exotek's website: some new 12mm titanium front axles for the dex210, in stock
When I looked for them a couple months ago I had to ask a British shop to send me what they had lol. I wonder how many exotek has in stock. Or where they found them.
Old 10-05-2017, 04:38 PM   #19674
Kremzeek's Avatar
Alan_r, do you have this body?
Team Durango TD402014 DEX210 CAB FORWARD BODY shell 1:10th rc Buggy transparent | eBay
Kremzeek is offline   Reply With Quote
Old 10-14-2017, 02:42 AM   #19675
roosterreagan's Avatar
Trader Rating: 16 (100%+)
Fred, what are your thoughts about keeping the gap between the top of the springs and the shock collars? It seems like my choice is to either:
1) eliminate the gap by bringing the shock collars down = ride height increases more than 17mm but I retain jumping ability with full suspension travel
2) eliminate the gap by adjusting the droop screws = lift inside tire during cornering and reduced suspension travel for jumps.[/QUOTE]
Why worry about it? Does that gap effect anything? I could see when unload it would "float", I guess it could lead to inconsistenCy though...
Maybe a limiting spacer on the shock shaft INSIDE the shock...?
roosterreagan is offline   Reply With Quote
Old 10-14-2017, 09:00 AM   #19676
I only use the shock collars to determine ride height. If there's a gap at full droop, it doesn't really matter but there might be too much droop at that point.
fredswain is offline   Reply With Quote
Old 10-14-2017, 09:49 AM   #19677
Kremzeek's Avatar
This would be the same as using the droop screws to limit droop.
What kind of a track are you running on? How big are the jumps?
Old 10-16-2017, 10:27 PM   #19678
Hey, sorry guys Iíve been out of the loop for a while. Family in Texas, Florida and friends in the USVI has kept me busy and not focused on RC. Busy damn season for sure.
Anyway, yes, Iíve got that one. Iím about to mail the collection of bodyís to TBG and then itís in their hands. Wanted and was ready to do it a few weeks ago but priorities priorities.
As of right now the only bodyís i was unable to locate or didnít get for one reason or another are the DESC410V2 and the DEX210V3.
The only body that Iím currently tracking for the dex210v3 is with a kit in Australia; I just canít justify paying $500 US for a kit I donít need. Iíve already spent A TON on this project. Iíve got everything else: 408,408T, 210 V1 reg, Cfwd,+8mm CFwd, 210V2, all the 410ís, DESC210R, DEST210R, DEX8,DNX8, and DEX8T. Plus a few 210 bodyís that didnít come with kits.
I ignored the DESC410 body because any SCT body pretty much fits and itís not distinctive like the DESC210R body.
Theyíre coming guys, Iíve been talking weekly with TBG and they are anxiously awaiting them.
Hopefully we make it worth their while.
Last call on the DEX210V3. Iíll send it separate if I can get one. If someone is sitting on one, just know that youíd only be without a body for the next couple months, then youíd get two free ones from me.....
Alan_r is offline   Reply With Quote
Old 10-16-2017, 10:37 PM   #19679
Kremzeek's Avatar
The DESC410V2 body looks identical to the one for the DESC210.
Old 10-17-2017, 04:58 AM   #19680
any of you guys have some v2 side pods you don't need?
I have some extra parts i could send your way... have a complete diff that needs a rebuild...
banx is online now   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
