Like Tree23Likes
Old 11-15-2011, 07:19 PM   #1951
rcman182006's Avatar
Send a message via Yahoo to rcman182006
Originally Posted by Bri from Chi View Post
Hang in there. Help is on the way!
I'm trying to hang in there for just my kit to show up at Speedtech...wish they would at least throw in a free set of tires for making me wait so freakin long
-=-Charles Kilbarger-=-
Serpent SRX2 MM - D4 17.5 - Hobbywing Justock
AE RC10 Team Car - RevTech 17.5 - Hobbywing Justock
#NoChuck2015
rcman182006 is offline   Reply With Quote
Old 11-15-2011, 07:22 PM   #1952
TAMAK's Avatar
Trader Rating: 28 (100%+)
Originally Posted by Jmuck69 View Post
Front rims!
Those have been available for a while by DE Racing
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 11-15-2011, 07:30 PM   #1953
Jmuck69's Avatar
I don't like the rivets.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 11-15-2011, 07:46 PM   #1954
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
I didn't like them when looking at them via pictures on amain, but I gotta say, they look pretty bad ass in person.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 11-15-2011, 09:06 PM   #1955
x7tristan's Avatar
Can anyone point me to the part numbers for the ' better' ball studs and cups? Or the post where this might already be stated.
TJ
DURANGO DESC410R
x7tristan is offline   Reply With Quote
Old 11-15-2011, 09:15 PM   #1956
Super Moderator
Durango DEX210 Thread
- RCSpecialties -
Old 11-15-2011, 10:11 PM   #1957
x7tristan's Avatar
Thanks, so youre saying the older style ball cups are better than the newer 'heavy duty' ones?
TJ
DURANGO DESC410R
Old 11-15-2011, 10:23 PM   #1958
fullsyzz's Avatar
Trader Rating: 102 (100%+)
TC5 ball studs
Jconcepts ball cups
That's how I roll.
fullsyzz is offline   Reply With Quote
Old 11-15-2011, 11:24 PM   #1959
rpeker's Avatar
Thats a really good looking buggy!!
*Current RC's*
Jconcepts BJ4WE, Brushless O'Donnell Z01-B, T.O.P Photon, Axial Wraith
rpeker is offline   Reply With Quote
Old 11-16-2011, 02:34 AM   #1960
panic-rev's Avatar
Originally Posted by fullsyzz View Post
Hey fulzz, I can only assume the threads on the tc5 are the same diameter as the stock 210's? I just ask cuz I thought the 210 was kind of a bigger size. So if you have ALREADY put the 210 studs in, will these still thread in and be tight, is what I'm asking.
Also, those jconcept ballcups have always been a little stiff to me. I kinda like the softer AE ones that actually bend real easy, enabling you to finish the race, then replace once in the pits. A bend is better than popping off or breaking a ballstud or whatever. Just sayin'.
Associated B4 & SC10
panic-rev is offline   Reply With Quote
Old 11-16-2011, 02:46 AM   #1961
triplesix's Avatar
Default AE Gear Diff
those of you who installed the AE gear diff:
which bearings and shims did you need to properly install it into the gearbox?
kind regards
MBX6R
B5M Lowrider
DEX410
Supastox GT
triplesix is offline   Reply With Quote
Old 11-16-2011, 02:55 AM   #1962
ronsand's Avatar
Default DEX210 w/ Tamiya servo saver
Here is a few pictures of my newly finished DEX210. No problems where encountered during the build, except a few missing screws (no problem as I have a large inventory of screws from tonys screws). I still have to fit the motor/esc/rx and glue the tires.
The car is stock except that I have fitted the Tamiya #51000 hi torque servo saver. Hopefully this will reduce the problem with the front links popping of.
The car will be run on a tight indoor carpet track.
Durango DEX210 Thread-sam_0773.jpg   Durango DEX210 Thread-sam_0774.jpg   Durango DEX210 Thread-sam_0776.jpg   Durango DEX210 Thread-sam_0781.jpg   Durango DEX210 Thread-sam_0784.jpg
Mugen MBX7 - Tekno V4 MBX6 - DEX410v3 - DEX210 - DESC410 - Serpent S411 - Futaba 4PKs - Tekin RX8 + RS Pro - Werks B6
ronsand is offline   Reply With Quote
Old 11-16-2011, 03:46 AM   #1963
x7tristan's Avatar
Does the body still sit flush with that saver on there? Also, where can I get that saver?
TJ
DURANGO DESC410R
Old 11-16-2011, 06:17 AM   #1964
ronsand's Avatar
It will rub slightly without trimming it (lifting the body 2-3mm in front. I will not use the front body-clips, but in stead use Velcro (that will in any case lift the body).
You can in any case trim/bevel the edge of the saver and get the body to sit flush if you like.
Google is your friend! You will also find it on ebay: http://www.ebay.com/sch/i.html?_nkw=....c0.m270.l1313
Old 11-16-2011, 07:13 AM   #1965
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Originally Posted by MantisWorx View Post
ok, so my 210 will be here friday so here is what i am gathering needs to be addressed right off the bat, yes i could probably search it but this is much easier!
rear shock tower is weak so i will immediately make a new one and nip that in the bud!
ballcups are suspect but it seems that aligning them and pre-threading the holes helps alot, which makes sense.
what is the final verdict on the wheel hexes and wheels? do i need to make some adapters with different size hexes?
i already have the ID clips coming from mcmaster for the ball dif issues, is that all that is needed? what size are the dif balls?
has anyone in America even bothered with mid-motor?
anyone??
MantisWorx is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 Yesterday 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
