Like Tree17Likes
Old 11-14-2011, 08:09 PM   #1906
rsawyers9's Avatar
Has anybody tried boiling the ball cups before running them? My kit is coming on Thursday and I was thinking about boiling before swapping ball cups.
Mugen MBX6R US | Novarossi P5 | 2058 | Savox |
rsawyers9 is offline   Reply With Quote
Old 11-14-2011, 08:20 PM   #1907
todb's Avatar
Trader Rating: 57 (100%+)
Send a message via AIM to todb
I must be insanely lucky as my ballcups do not pop off at all. I had one come off this weekend when I broke a front A Arm but that is the first time I have one pop off. This is on a desc410r though not a dex210 though. On my DEX410 I used to have, I put the stock ball cups back on it after switching to rpm ballcups and not liking them.
OVA Neo. HW, Motiv.
Orange is faster.
todb is offline   Reply With Quote
Old 11-14-2011, 08:24 PM   #1908
markhat250's Avatar
Trader Rating: 65 (100%+)
Originally Posted by KainK View Post
They are the ballcups off of the desc or dex410.
I had trouble with those popping off too. It was mostly just the ones on the steering. It seemed to be mostly caused by the flex of the ackerman plate. I made one from carbon fiber and it seemed to fixed it.
Would everyone agree that the ballcups that are mostly popping off are the steering links? or is it randomly the whole car?
markhat250 is offline   Reply With Quote
Old 11-14-2011, 08:25 PM   #1909
Trader Rating: 29 (100%+)
I have been running my desc410r for 6 mos and have not had a ball cup pop off, but front arms seem to pop off once in a while...
Yzlvr is offline   Reply With Quote
Old 11-14-2011, 08:31 PM   #1910
markhat250's Avatar
Somone just mentioned that it is the new HD style on the 210 with the issues.
Old 11-14-2011, 08:32 PM   #1911
TAMAK's Avatar
Trader Rating: 28 (100%+)
RM 3 setup I swapped my rear hubs. and installed the ball cups so they are straight. Ever since that change I have not popped a ball cup in the rear. I also have not popped a front in weeks.... Allaignment on the ball cups is key. Pay attention to the natural float of the ball in the ball cup. And dont hit anything or bottom out.
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 11-14-2011, 08:33 PM   #1912
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
sigh.... they don't use the same ballcups.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 11-14-2011, 08:38 PM   #1913
todb's Avatar
I thought it might be something like that...sigh
OVA Neo. HW, Motiv.
Orange is faster.
Old 11-14-2011, 08:39 PM   #1914
ABBOTT's Avatar
I thought I was the only one!
SmacTrac / STL Dirtburners / Blaze RC
ABBOTT is offline   Reply With Quote
Old 11-14-2011, 08:42 PM   #1915
Super Moderator
Cripes all mighty.. this isn't the 410r thread My brain hurts.
- RCSpecialties -
Old 11-14-2011, 08:43 PM   #1916
hopsing's Avatar
Trader Rating: 13 (93%+)
I still havent popped any ballcups at all.............
Steve Butts
AKA, TrakPower, Serpent America/Desoto Racing, TrackStar, Futaba, EKD Paints
hopsing is offline   Reply With Quote
Old 11-14-2011, 09:21 PM   #1917
Trader Rating: 19 (100%+)
Originally Posted by mjealey View Post
Hey guys, I can already tell the ball cups are going to be a problem. I have everything built and I go to adjust the camber on the car and I put my wrench on it and turn the turnbuckle and it just pulls the links right off the ball studs! I know it has been talked about on here, but what is everybody running as far as the balls and the plastic links go?
This is because when you build them to the correct length the ballcup actually goes over the non threaded shank of the link. You can do one of two things: trim/sand a small amount (1/8 inch or less) off the end of the ballcup or counter bore the hole in the end of it about an 1/8 to allow the non threaded shank enough room to rotate freely in it. Also, make sure to lube the threads before assembly. Ive been using black grease but chapstick or beeswax work well too.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 11-15-2011, 12:30 AM   #1918
onekiwi's Avatar
Ive now had a good few hours with the car... orsm is all I can say.
Ball cups , Ive had a few pop off but all in all thats because I crashed or hit something. Make sure that you have them at 90* to both ball studs that they are connected to that way they have a little play.
When you build them use grease and if you can out one end in a drill and slowly drill them in and out several times. Even after this I may need to hold/press down on one of the ball cups with my fingers while adjusting them.
Diff, no problems here, build it right and run it in and enjoy, its still smooth.
I use the ace 1015, maybe a little overkill but made a difference as it weighs more than the sav÷x low profile
And I fited tamiya battery holders and reamed out the stock battery holder so now I can use body clips instead of thumb screws, really easy
onekiwi is offline   Reply With Quote
Old 11-15-2011, 12:34 AM   #1919
ronsand's Avatar
Originally Posted by panic-rev View Post
I don't have mine, so good heads up if this piece looks a little suspect.
But your servo could be next in line. Sketchy. I'm thinking plastic is the play.
As far as "something's gotta give/break", just from past experience, the force of an impact has to manifest itself somewhere.
I have fitted the Tamiya #51000 hi torque servo saver to mine. Fits nicely and is really precise. If it is good enough for the Tamiya 417 TC it is good enough for my DEX210
Mugen MBX7 - Tekno V4 MBX6 - DEX410v3 - DEX210 - DESC410 - Serpent S411 - Futaba 4PKs - Tekin RX8 + RS Pro - Werks B6
ronsand is offline   Reply With Quote
Old 11-15-2011, 12:45 AM   #1920
panic-rev's Avatar
A picture is worth a 1000 words .
Associated B4 & SC10
panic-rev is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16561 Today 03:54 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
