Like Tree27Likes
Old 03-12-2017, 08:56 PM   #19096
Originally Posted by fredswain View Post
Marketing has convinced everyone that TiNi is important. It's irrelevant.
But those gold shafts and lower shock caps look cool! 🤘
And then I cover them with shock boots so no one can see them. But I know they're there.
Alan_r is offline   Reply With Quote
Old 03-12-2017, 09:08 PM   #19097
czrlaker's Avatar
Trader Rating: 24 (100%+)
Not the reason I purchased them, I honestly couldn't care less. But that was what they had. And I needed them.
czrlaker is offline   Reply With Quote
Old 03-13-2017, 12:56 AM   #19098
I've been running the durango inside over the winter on carpet with jconcepts smoothies on. Had issues with it collapsing at the rear and lifting a front wheel.
High rc at the rear one washer at the front. It was horrible to drive. Somebody suggested that for carpet that you need to lay down the rear shocks. Hey presto handling was transformed. Eveything I've read about laying down the shocks says it makes them more progressive and more roll. Can anybody suggest why this helped out please?
Pistol123 is offline   Reply With Quote
Old 03-13-2017, 07:41 AM   #19099
What you effectively did was to lower the rear spring rate a bit. By laying the shock over, the spring has a little less leverage on the suspension arm. When you get into a situation where you are lifting a front tire, I assume on power out of a corner, by raising the rear roll center you aren't really doing much to help it on power but are only going to make the rear end really unstable under turn in braking going into the corner. The car would be horrible to drive as it would suck everywhere.
I don't generally like critiquing setups but I'd love to know what yours is so see if anything obvious sticks out about it.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 03-13-2017, 10:22 AM   #19100
Lifting inside front was at end of corner entry and on apex, fine on corner exit.
3mm
front axles raised up to account for larger front tyres.
1 washer under inner ball studs.
Long front top links
30' caster
Trailing axles
Red front spring
30wt oil 6x1.2 pistons
-2' camber all round.
Black rear spring
1.5 as
Medium long rear top links.
Shocks in outer hole in wishbone.
27.5wt oil 6*1.3 pistons.
No washers under rear top links.
Shorty pack fully forward.
Just to confirm the moving the shocks in at the top stopped the tripodding, moving them out made it worse.
I had it previously with thicker oil and dialed it out by adding a front rc washer and removing the rear rc washer. Had moved to thiner oil as week before was running out side on bumpy astro.
Not sure why lowering the rear spring rate stopped it collapsing??
Just to add the I have run the same set up on astro and it handles great. The big different with running inside is the tyres, fronts are very large diameter compared with slim staggered ribs.
Old 03-14-2017, 07:45 AM   #19101
have you tried making or sourcing 4x1.4 pistons?
at around the 860 page mark of this thread there is a discussion regarding people sealing two of the holes and boring out the other ones with an appropriate sized drill bit.
I was planning on trying it out
banx is offline   Reply With Quote
Old 03-14-2017, 08:11 AM   #19102
Yes I think that would work as would thicker oil. But i am more interested in how/why moving the shocks in at the top works.
Old 03-14-2017, 08:45 AM   #19103
Coincidental to that shock piston advice, I feel like it's 1990 again. I'm sitting here drilling out shock pistons by hand. I didn't have any 2x1.6 but fortunately I had several blanks. I'm going to be setting up the back around 2x1.6 pistons, light red springs and probably 25 weight oil. Outer location on the arm, next to outer on the tower. Shocks in front of the arms. I'm still closing in on the front. This is going to be a carpet/high grip setup where the track surface is smooth but with jumps. This wouldn't be good on rough tracks. Associated pistons are not interchangeable btw. I tried.
Old 03-14-2017, 10:10 AM   #19104
As a piece of information, there is absolutely ZERO development going on with the Durango line right now. Nothing in any scale. There is also no UK distributor and none being lined up.
Old 03-14-2017, 02:09 PM   #19105
I thought alan r was gonna buy that mutherfucker
Old 03-14-2017, 05:40 PM   #19106
That's too bad about Team Durango. With all the geometry issues we have solved and the exotek chassis. This car should be able to compete.
I went 2x1.6 in the rear w/27.5 wt. Your gonna like it. I'm running Kyosho white.
WallyRC is offline   Reply With Quote
Old 03-14-2017, 06:05 PM   #19107
Default Up travel bind
Fred,
Can you do me a favor on the rear end with the new shock bodies (29mm) on. On the right side of my buggy, when fully compressed and with tire rotation I get a slight bind from the dog bone end hitting the diff nut and it pushes the wheel down slightly. I have two Dex's and it does it on both. Wanted to know if you get that on yours with the increased up travel? It doesn't do it on the side with the screw end for adjustment.
Thank you
Old 03-14-2017, 07:35 PM   #19108
It comes darned close but clears. I don't know if it matters but I'm using the V1 ball diff.
Originally Posted by WallyRC View Post
Fred,
Thank you
Old 03-15-2017, 08:35 AM   #19109
Well mine is converted to an oval car. Only changes I made was lowering it with pieces of Nitro fuel tubing inside the shocks, Locked the slipper for stock oval racing.
Replaced the stock servo with a better one. 25 weight Losi shock oil (green in color)in the shocks.
Associated B6 "Dirt Version" latemodel, Team Losi Racing 22T 2.0 Bomber Truck.
Team Losi Racing 22 2.0 2wd Short Course Truck,Duratrax 835e Brushless 8th scale Buggy,
Stock Slash, B4.1 latemodel(retired), T4.2 Factory Team BOMBER CAR
Castle Creations( Since April 2016)
bmag5000 is offline   Reply With Quote
Old 03-15-2017, 03:17 PM   #19110
Thanks for checking. I don't think there was a difference between models for ball diff. I might shave down the diff nut ever so slightly and see if that helps.
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
