Like Tree23Likes
Old 11-23-2016, 11:01 AM   #18601
I dont own the DESC10 and a view little things of the new line held me off to buy one!
That is: To replace the outer bearings of the diffs, it always looked like to me, you have to tear down the hole diff, may one of the DESC10 owners can clariefy? And, i do not like the motor mount that much, otherwise, the truck is realy looking good to me, just that was holding me off...!?
At the DESC410 it is easy to replace or clean the outer diff bearings!
Greetings from Austria
Cat K2 / DEX410V3 / DEX410V5 / DEX210 / DEX210F / Cougar SVR /
YZ-10 '94/'95 WCS/
Spectrum DX3R
micholix is offline   Reply With Quote
Old 11-23-2016, 11:31 AM   #18602
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
from what I recall I think you could just pull the bearings but I could be wrong.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 11-23-2016, 07:56 PM   #18603
From what I can tell, the DESC10 is a much heavier/stout truck that compares directly to the Tekno in this way. The DESC410V2 looks like it is designed for smaller tighter tracks, like the SC10 was. Knowing me, I'll likely build both just because I love short course trucks.
As far as the DEX210, when I read that some of you are running your electronics in line down the center, are you cutting out some of the waterfall and mounting it behind the battery? Everything I read about this buggy seems to point to needing better weight distribution. I.E. cross mounted battery, in line electronics ect. What are you gaining by doing this? To me, it seems that all of this really only applies to the guys running super high traction. A place where that kind of stuff matters most.
Alan_r is offline   Reply With Quote
Old 11-24-2016, 06:15 AM   #18604
Tech Legend
Cain's Avatar
Tekno's SCT410 had specific lightweight parts for it designed, the DESC10 is basically the DEX8 with some changes to make it fit the class. Hence why its heavier. Good vehicle though let down by the company. It actually works very well indoors and out, etc.
The DESC410 series basically started out when 4x4 sct was still young and more 1/10 oriented than it is now. But, it actually works quite well on a variety of tracks, you just have to uparmor it with some things to deal with the heavier vehicles but once that is done, its works quite well.
As for the dex210 running the shorty battery in the sideways position to me it makes the vehicle feel more consistent on the rear end, especially if you want to run the vehicle Mid motor. It is a mod that I would recommend doing.
Old 11-24-2016, 07:25 AM   #18605
I always whanted the sidway battery position, to get as much weight to the rear end, i think 65/35 would be best, so i decided to start boulding my own chassis, but had not had the time to finish it, and as the exotek chassis released...
May you have seen my starting, to convert the 210F chassis to a stand up gear car, quit a fiew pages back?
YZ-10 '94/'95 WCS/
Spectrum DX3R
Old 11-24-2016, 08:27 AM   #18606
Tech Legend
Cain's Avatar
saw that.
The big thing I was wanting on the dex210F was the ability to use a ball diff, your setup could have done the trick.
Old 11-24-2016, 08:49 AM   #18607
JRSlash's Avatar
You are correct. You cannot remove the diff bearing without tearing the whole diff apart. Also the things I didn't like from the truck was the limitation on shock adjustment, meaning only one position on the a-arms and 2 positions in the front tower and 3 in the rear which actually you are limited to two due to the body mount been on the way of the third hole. Shocks are not very consistent in stock form. The weigh is the biggest drawback of this truck. Despite the downfalls of it I managed to A-main 99% of the races i went with it and podium about 75% of them. And thats a whole year if racing the crap out it. It is an awesome truck but weight is what kept me from doing a fast 10min main therefore i moved to a lighter 4wd sct. Bottom line is that if 4wd sct was to be ran with 3S, there's no catching the desc10 IMO.
SOAR Seiki 998 TD1 Nitro
SOAR Seiki 998 TD1 E-buggy
PR Racing SB401
Dialed-RC Hobbies (www.dialedhobbies.com), SOAR Seiki USA
Bellgate Distributor (www.bellgatedistributor.com), PR Racing USA
JRSlash is offline   Reply With Quote
Old 11-24-2016, 11:19 AM   #18608
Tech Legend
Cain's Avatar
The performance of the DESC10 makes it sadder how durango ran away from racing. But, for that and other vehicles that have if you don't care about that you can have one heck of a vehicle.
Old 11-24-2016, 02:44 PM   #18609
czrlaker's Avatar
Trader Rating: 23 (100%+)
Good to know. I'll be running my dex210 either with the battery mod or buy the exotek chassis. And even if parts are harder to find as time goes, the only real replacement parts I need are A-arms (after finding a pair of treseray c-hubs). I own a B5m which I love but I fixed up this dex210 for my daughter and when she broke a front A-arm over the weekend I saw that my b5m were almost the same, I fit them on slightly modifying the bulkhead. So now they are easy to find. I got home so excited for my find that I was going to post here but I did my homework and noticed It had already been discussed. Now I have to find a way to calm some of the droop the modified bulkhead allows. Still runs solid, I am running it 17.5 stock and flies beautifully.
czrlaker is offline   Reply With Quote
Old 11-24-2016, 02:52 PM   #18610
Tech Legend
Cain's Avatar
yeah the car works pretty well, if durango would sit down and really work on the cars I'd love to see what comes of things.
Old 11-25-2016, 04:30 AM   #18611
asalas's Avatar
Send a message via Skype™ to asalas
Default Done
Originally Posted by Kremzeek View Post
One thing that concerns me is the lack of mounting points along the chassis. Given, the side pods probably don't add a lot of strength to the aluminum chassis but they must have some impact on the flex. It might be good to add one or two screws along the area highlighted in red in the picture below.
I added a couple of circles showing existing screw holes that could probably be used. It might be good to use the blue one as the forward battery brace mounting point instead of making new ones. This does limit how far forward you can run the battery but without a lay down gear box, I don't think there's a real reason to run one that far forward.
Comments?
Attachment 1396852
I got the printed pods and they fit in well. I need to dremel the posts as 3d printing kind of messed up their inner diameter. I think i need to cut the body with an extra cm from its original cutting line.
asalas is offline   Reply With Quote
Old 11-25-2016, 07:31 PM   #18612
Kremzeek's Avatar
Wow.. those look really good. I gotta print a set when I'm back at work next week.
Kremzeek is online now   Reply With Quote
Old 11-25-2016, 07:50 PM   #18613
czrlaker's Avatar
Looks good. What kind of printer are you using?
Old 11-26-2016, 09:38 PM   #18614
czrlaker's Avatar
Any ideas? What setting to change? Every time I take this double I flip when I turn. Only happens when I use this buggy. Never with my B5m. The yellow spot is the after the double is the culprit. Any help and suggestions would be greatly appreciated.
Old 11-26-2016, 10:41 PM   #18615
Please post your full set up, so we may can figure out, where the problem is!?
My first guess would be the shock set up...
YZ-10 '94/'95 WCS/
Spectrum DX3R
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
