Like Tree26Likes
Old 11-13-2011, 06:27 PM   #1846
panic-rev's Avatar
Originally Posted by Matt Howard View Post
I'm running 4 hole 1.3's in front with 30wt and 4 hole 1.2's in the rear with 20wt and my car is dialed.
Are the 4 hole 1.2/1.3 pistons something that comes stock with kit? I know a bunch are included. Or did you drill the blank ones that come with it?
Do you all find it interesting that the car would be that far off? The post above said 45/40 oil with stock pistons? That's like heavy 1/8 scale territory. So to drop down to a 4 hole and still be at 30 wt. means Durango's recommended 6 hole is waaay off the mark. Oh well, we'll get it sorted out, but just found it interesting to be nowhere near close right outta the box.
Associated B4 & SC10
panic-rev is offline   Reply With Quote
Old 11-13-2011, 06:35 PM   #1847
panic-rev's Avatar
PS.....
Is there a drill bit size that equates to 1.3 or 1.2? Or is that the size? I've never drilled my own from scratch, just made bigger to existing. Just wondering what the actual bit is. Drango kit comes with blanks I read.
I'm not getting my kit for a few more days, and like most of you, want a good ballpark place to start. Thanks!!
Old 11-13-2011, 06:37 PM   #1848
Bman's 3XNT's Avatar
Trader Rating: 70 (100%+)
Depending on your track. I run the six hole pistons in both the 210 & 410. 35/30 rear. Seems good for me......
Team Durango DEX410 w/3 Diffs ;) The original
Xray Xb2 CE
www.rchr.biz------www.Wolcotthobby.com
Bman's 3XNT is offline   Reply With Quote
Old 11-13-2011, 06:45 PM   #1849
rcman182006's Avatar
Send a message via Yahoo to rcman182006
Just curious where you got your buggy from?
I'm getting impatient for mine, back-ordered and paid for it a month ago from Speedtech with expectations of it being in at the beginning of the month
-=-Charles Kilbarger-=-
Serpent SRX2 MM - D4 17.5 - Hobbywing Justock
AE RC10 Team Car - RevTech 17.5 - Hobbywing Justock
#NoChuck2015
rcman182006 is offline   Reply With Quote
Old 11-13-2011, 06:49 PM   #1850
rsawyers9's Avatar
I had mine back ordered through Amain and got the e-mail Friday that they had stock. Paid on Saturday and should be here mid-week. Their site still says that they have stock.
Mugen MBX6R US | Novarossi P5 | 2058 | Savox |
rsawyers9 is offline   Reply With Quote
Old 11-13-2011, 06:56 PM   #1851
Yea I saw it too, if it want for having it already paid for I would cancel my order through Speedtech and order it through A-Main
#NoChuck2015
Old 11-13-2011, 07:06 PM   #1852
slow_jun's Avatar
Trader Rating: 14 (94%+)
Built DEX 210 For sale.
Item is here in Singapore
if anyone is interested.
Mag 3 taon, tapos isalpak pa sa PAGMUMUKHA KO......... tagal....Deeeeymmm!!!
slow_jun is offline   Reply With Quote
Old 11-13-2011, 07:45 PM   #1853
hopsing's Avatar
Trader Rating: 13 (93%+)
I'm running the 6 hole 1.3 in front and 1.2 in the rear that is called for in the build.......I have 40w losi in front and 30wt losi in the rear and my car is really good right now. I think 37.5 or even 35 will be better in front, but for now the car was real good on a med to high bite clay at West Coast Raceway in La Mirada. I will eventully change to 4 hole to try it out as the 4 hole could very well be better....Carson Wernimont was running the 4 hole set up (with 30 front and 27.5 rear) on his at West Coast last night (the same set up that Travis Amezcua runs there as well) and his car was really good ......but after only 9 batteries through my car I'm not about to change just for the sake of copying everyone elses set ups. I was making slight changes in shock positioning, battery placement, and bump steer and the car just got better and better. And I'm still on stock kit springs.....
Just because all the set up sheets say to do this or that, dont count out the stock set up as a good starting point.........learn the car and make changes one at a time so you can get a feel for what the change is doing for the car. If you just automatically put 4 hole pistons in your car without ever trying the 6 hole, how will you know if your car is truly bettter FOR YOU....
And yes 45/40 with stock pistons would be way to heavy with the stock springs. I had 40 in my rears and felt like I had mud in the shocks LOL....
Steve Butts
AKA, TrakPower, Serpent America/Desoto Racing, TrackStar, Futaba, EKD Paints
hopsing is offline   Reply With Quote
Old 11-13-2011, 08:09 PM   #1854
hopsing's Avatar
Originally Posted by Jonny5 View Post
The stock setup is a good place to start. The biggest change needed is to close off some holes in the pistons- 3 or 4 hole seems to be where most a ending up. With the 6 hole pistons there just isn't enough pack and the car lands fairly hard off of even small jumps. Otherwise build it how the kit says and tune to your liking.
thicker oil won't do anything for the lack of pack when using the 6 hole pistons. I'm running 4 hole 1.3's in front with 30wt and 4 hole 1.2's in the rear with 20wt and my car is dialed.
My car jumps and lands great.....at West Coast we have a big quad (about a 20 footer) as well as several doubles and a 6 inch "step off" and my car landsthing solid everytime even if I over jump the quad slightly....I saw lots of Losi's that got a chassis slap rebound hop in the rear if they over jumped it at all.
Steve Butts
Old 11-13-2011, 10:43 PM   #1855
panic-rev's Avatar
From Hopsing's and Bman's posts above, I am going to stick with the stock 6 hole and probably throw in some AE 35/30 to start, see where it takes me. Thanks for the input.
I wonder if the nature of the fatter shock just calls for thicker oil? Say compared to the thinner B4 style? Does that have anything to do with it? Just when I heard these thicker oil numbers being thrown around, I was like whaow.....1/8 scale.
Old 11-13-2011, 11:08 PM   #1856
panic-rev's Avatar
What is stock spur? Anyone running 8.5 or close? What pinion matches up well? Thanks.
Old 11-13-2011, 11:11 PM   #1857
slow_jun's Avatar
87 same with 410. As for the pinion depends on your track sorry.
Old 11-14-2011, 05:21 AM   #1858
hacker's Avatar
Trader Rating: 140 (100%+)
PS.....
haha yes a 1.2 & 1.3mm drill bit
hacker is offline   Reply With Quote
Old 11-14-2011, 05:29 AM   #1859
PS.....
Ya, 3/64 (.0469) for 1.2 (.0472) and #55 drill (.052) for 1.3 (.0512) very close if you don't have mm. Or just glue up two holes in the stock pistons.
Xray Xb2 CE
Old 11-14-2011, 07:24 AM   #1860
Jmuck69's Avatar
Default Akula Racing
CF goodies for the 210.
http://www.redrc.net/2011/11/akula-r...ns/#more-49003
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16570 09-23-2017 03:48 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
