Durango DEX210 Thread
This may be a bit off topic but there's been so much talk about standard length lipo vs saddles vs shorty and they're given mAh and weight comparison compared to chassis balance. What is everyone running capacity wise? I know my 4000 standards weigh substantial less than my 5100 saddles.
Night and day different than before. The car is very drivable now. It still feels a bit loose compared to my 5M but I'm definitely getting there. Thank you all for the help. Wall: I can definitely see why you suggested the 2/1.7 in the rear shocks. The 3/1.6 was good, but it left me wanting more pack back there. I forgot to bring my bag of tires so I was running a good, but not optimal tire package. 3DS when I needed Holeshots. The car has a tendency to suddenly have sharp oversteer when off power coming around the final part of the apex of a turn. I have to back off due to slight on power understeer, this is when it happens. Could be the tire package, though the diff still doesn't feel right to me. I decided not to change anything today because of the tires but tonight I'll be installing the 2/1.7 pistons. Wednesday I'll come back out, with tires and see if it goes away. But definitely a 90% improvement. Now I gotta work for that last 10%!
Alan,
Happy to hear, the car is working much better now!
I always do like two hole pistons on all my cars, cause of the pack...
Keep us informed, how it works out!
Tech Legend
Alan,
You may want to try 30 degrees front caster for the surface you are on. Your set up sheet said 25, which generally is for higher grip. Just something to try and see if it smooths out your steering. I tried both. I am on higher grip indoor dirt/clay. 25 worked for me. But 30 wasn't too bad.
Wally
Wally
http://site.petitrc.com/setup/durang...RDirt20150620/
Cain, it's currently this setup except for the transmission, which is MM3. The car had a ton of steering. The only things I noticed were the following:
The rear end would slap a little on jumps that are not usually downsided. My ae's Are plush here by comparison. Likely Walls suggestion to use 2/1.7 in the rear will correct this.
We have a wide sweeper after a medium straight that with my other cars gets attacked by braking upon entering, once the car is settled I can slowly accelerate as it winds around. The DEX requires me to let off during the last 1/4 of it or it will push towards the outside of the pipe. Once I let off it gets in line quickly. Reminds me of a RM car.
On sharp 45 degree plus turns, it has a tendency to snap oversteer right when I'm about to straighten the wheels. It seemsbto happen a split before I start accelerating out of the turn.
The car is so much better to drive than it was last week but it still requires a lot of work to get it around the track quickly. I'm sure by practising with these quirks it could be competitive. But I still think there's more to be found. I'm a very smooth driver and my lap YO lqp consistency is pretty tightly grouped. This car makes it more difficult to do this because of some of the unpredictability. It's my only 2wd buggy that feels this way.
In the back of my mind I know that this is a European car being tuned for a typical American, outdoor 1/8 scale dirt/clay track so I expected many baseline settings to be way off. At higher levels of grip I could definitely see the current setup working well.
I definitely want to change the rear pistons and try out a few tires before making any other changes though. 30 degrees of Caster sounds like the right direction.
I had the same problem with the steering. I layed the shocks down one whole hole and that seemed to help.
Tech Legend
just an FYI I would not be surprised if that setup is running the shorty mod even though I don't "think" the link mentions that.
The vintage car on the top is absolutely dialled. Consistent laps within a few seconds are almost too easy.
