Like Tree43Likes
Old 11-13-2011, 09:56 AM   #1831
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Originally Posted by mikeyscott View Post
Anyone able to recommend alternatives to these - http://www.team-durango.com/part-inf...artNo=TD330347
Reason is one spilt in two when I put a 2.5mm driver in
You will have to use another Durango ballstud. It's a unique size that only Durango uses. If you swap out all ballstuds and ball ups then you can use standard sizes. Many companies make titanium studs for the standard size.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 11-13-2011, 10:02 AM   #1832
Pants
Protectionism at it's best!
mikeyscott is offline   Reply With Quote
Old 11-13-2011, 10:21 AM   #1833
Trader Rating: 19 (100%+)
Originally Posted by chiatw73 View Post
so its 0 rebound for the shocks?
99% of the time I build emulsion shocks with zero rebound.
XRAY, RC America, MOTIV, Sanwa, Arrowmax, Neverlift Racing Apparel
Jonny5ive Designs- by racers, for racers!
Jonny5 is offline   Reply With Quote
Old 11-13-2011, 12:11 PM   #1834
panic-rev's Avatar
If anyone puts in an sc10 gear dif, would you care to post pix or tell how many shims on each side, what kinda shims too. SC10 gear difs are pretty abundent and cheap.
Ill wear out my first ball dif, but see my self going to gear. That's why I run 2wd in the first place, its an easy lo maintenance car.
Associated B4 & SC10
panic-rev is offline   Reply With Quote
Old 11-13-2011, 12:22 PM   #1835
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
Why is everyone afraid to run ball diffs ? If you build them and break-in correctly they last a long time .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 11-13-2011, 12:30 PM   #1836
rcman182006's Avatar
Send a message via Yahoo to rcman182006
To me I don't see it as being afraid to run one, I see the gear diff as just another tune-able part, and from what some people have been reading w/ the difficulties people have been having putting the ball diff together they might be second guessing themselves on their own skill to build and break it in properly
-=-Charles Kilbarger-=-
Serpent SRX2 MM - D4 17.5 - Hobbywing Justock
AE RC10 Team Car - RevTech 17.5 - Hobbywing Justock
#NoChuck2015
rcman182006 is offline   Reply With Quote
Old 11-13-2011, 12:31 PM   #1837
tom235's Avatar
getting mine Monday ordered all the spare that were in stock but should i run box stock setup or some one else?
tom235 is offline   Reply With Quote
Old 11-13-2011, 01:19 PM   #1838
The stock setup is a good place to start. The biggest change needed is to close off some holes in the pistons- 3 or 4 hole seems to be where most a ending up. With the 6 hole pistons there just isn't enough pack and the car lands fairly hard off of even small jumps. Otherwise build it how the kit says and tune to your liking.
Old 11-13-2011, 01:35 PM   #1839
tom235's Avatar
thanks i will start with the stock setup. have you tried thicker oil instead of closing holes?
Old 11-13-2011, 01:44 PM   #1840
Matt Howard's Avatar
thicker oil won't do anything for the lack of pack when using the 6 hole pistons. I'm running 4 hole 1.3's in front with 30wt and 4 hole 1.2's in the rear with 20wt and my car is dialed.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 11-13-2011, 01:59 PM   #1841
tom235's Avatar
are you running the stock springs also. the track that i run on is a 95x55 ish med bite indoor track and always has a big triple. what kind of track are you running on? just wondering if your track is close to mine to see if that would be a good start for me.
Old 11-13-2011, 03:26 PM   #1842
I'm running dark green in the front which is one rate softer than stock and black in the rear which is two rates stiffer than stock. I run at Mike's hobbyshop in dallas, usually med/high bite indoor
RCTech #361
Old 11-13-2011, 03:41 PM   #1843
TAMAK's Avatar
Trader Rating: 28 (100%+)
Got back from trackside Milwaukee and ended up with Losi red fronts and Losi grey rear. The conditions were very dry, dusty, low grip. Where areas had some blue groove, the track had not been swept after a big race the night before. I also ran pink beams all round. I did have the 6 hole pistons with AE 45F/40R. Fluids seem to be working. Hope that helps. With the softer front, the car is easier to drive, alot less push.
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 11-13-2011, 03:48 PM   #1844
Briguy's Avatar
Surprised to hear those conditions for Trackside . Good to see you made the 6 hole pistons work !
Royal R/C & Hobby
Old 11-13-2011, 04:00 PM   #1845
TAMAK's Avatar
Its a matured layout, FAST!!!
St Ives RC Club B4Bandit Australian Racing 16575 11-18-2017 12:44 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
