Like Tree23Likes
Old 11-12-2011, 10:18 PM   #1816
Trader Rating: 19 (100%+)
Originally Posted by chiatw73 View Post
hi guys.. just builded up the Dex210.. need some advice..
i hv no experience with shock(caps) wo bladder.. how do i finish the shock build? do i adjust the preload i want, add oil, then cap it off(with the bled screw already in place)?
i did dat but when i worked the shock it feels like air inside..
or do i add oil with the shaft fully extended?
thanx
Fill the shock 3/4 full and push the shaft up, then pull it down to get the bubbles out from under the piston (you may want to do this twice on initial build). Then once all the air bubbles have worked their way out, top the shock off so that it "domes" over the top of the body slightly. With the screw out of the cap, place a few drops (2-3) in the cap and screw it on. Then hold the shock perfectly vertical and slowly push the shaft to the top (it helps to hold a rag just under the hole) and install the screw. Three more shocks and you're done Very simple and smooth shocks to build.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 11-12-2011, 10:59 PM   #1817
slow_jun's Avatar
Trader Rating: 14 (94%+)
Originally Posted by manjagu View Post
this is +8mm finnisher body
it's dirty painting ^^;
i like sc10 gear diff
good driving in park
not run circuit yet
does a SC10 Grea Diff fit the dex 210? havent tried to fit my 22 sc10 diff..
please share....
thanks.
Mag 3 taon, tapos isalpak pa sa PAGMUMUKHA KO......... tagal....Deeeeymmm!!!
slow_jun is offline   Reply With Quote
Old 11-12-2011, 11:12 PM   #1818
manjagu's Avatar
Default gear diff
please share....
thanks.
dex210...slightly move right and left in gear box
but thought that it doesn't matter
manjagu is offline   Reply With Quote
Old 11-12-2011, 11:30 PM   #1819
panic-rev's Avatar
I was getting all excited that the sc10 dif fit. But moving side to side? Yeh, kind of a big deal. Not sure if that's what you meant. If it fits, like perfect, fill us in.
Associated B4 & SC10
panic-rev is offline   Reply With Quote
Old 11-13-2011, 03:14 AM   #1820
so its 0 rebound for the shocks?
Summit/FluxHp/R1/CR01/SCX10/XR10/Scte/Nexx10sc/808e/22/Fs2SP...
chiatw73 is offline   Reply With Quote
Old 11-13-2011, 04:50 AM   #1821
Looks like my 2012 plans will be a Kyosho RB5 Vega Elite
mikeyscott is offline   Reply With Quote
Old 11-13-2011, 05:33 AM   #1822
xtomtom's Avatar
the sc10 gear diff fits. You just need to add shims to the out drives to match the length of the durango ball diff. That way you have no side to side movement
xtomtom is offline   Reply With Quote
Old 11-13-2011, 05:41 AM   #1823
slow_jun's Avatar
this i gotta try if my 210 dont sell. hahahaha....
Old 11-13-2011, 07:55 AM   #1824
stavman's Avatar
Well...
Since I should have our indoor track done early Dec..... Pulled the trigger on the DEX210 this week
May try the SC10 gear diff and see how it works... need ta BUILD this baby 1st....LOL
With Billy F being a local here in AZ his setup sheets apply to most of the racing here in the Valley... So That helps for sure..
Sounds Like not a lot of MODS needed...
I also have the +8 bodies, so may test one of those as well
Fine Times ahead.... just gotta get Parts in stock at the shop now
Stav
FYAIDGASAM
stavman is offline   Reply With Quote
Old 11-13-2011, 07:58 AM   #1825
CHIZZLE's Avatar
Trader Rating: 37 (100%+)
Originally Posted by stavman View Post
Well...
Stav
Good to know as I have one of these on order as well. I'm looking forward to the new track!
Chance Renstrom
Repeat after me......"toy cars"
CHIZZLE is offline   Reply With Quote
Old 11-13-2011, 08:03 AM   #1826
stavman's Avatar
I saw yer Name here Chance... Cool
Ill have some Parts next week.... going thru manual now...
U trying SC10 Gear Diff????? i May... Ball diffs are a lot of maintenance... and I dont do Maintenance....LOL
FYAIDGASAM
Old 11-13-2011, 08:13 AM   #1827
Matt Howard's Avatar
FWIW I have 3 weeks on my ball diff and it still feels like new, haven't touched it since I built it
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 11-13-2011, 08:31 AM   #1828
CHIZZLE's Avatar
Either that or wait until the TD gear diff comes out. I'm pretty good about maintenance but I have yet to see a huge difference between a gear and ball diff. But I'll try both on this rig for sure and then make a decision.
Chance Renstrom
Old 11-13-2011, 08:33 AM   #1829
CHIZZLE's Avatar
With that said, I have about 4 months on the gear diff on my xxx-sct. It still feels money!
Chance Renstrom
Old 11-13-2011, 08:51 AM   #1830
Anyone able to recommend alternatives to these - http://www.team-durango.com/part-inf...artNo=TD330347
Reason is one spilt in two when I put a 2.5mm driver in
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
