Like Tree27Likes
Old 06-03-2016, 05:32 PM   #17836
peter george's Avatar
Trader Rating: 351 (100%+)
Ok so cutting area away from plastic side peices to keep lipo in place and lowering it flat on chassis eliminates many of the things I was worried about and I don't think that the lipo underside is in danger .or is it??? I also did the Turtle Speed modification too on one of my other dex210. Hope to try both real soon
I donít always talk smack but when I do itís 99% spot on
peter george is offline   Reply With Quote
Old 06-03-2016, 07:06 PM   #17837
Originally Posted by chadp View Post
Sweet, now if someone could only print desc/dest210 arms that don't break.
Go look at the DEST or DESC THREAD, I posted some pictures of how to reinforce the rear A arms with stainless 1mm (.032, I think) wire.
WallyRC is offline   Reply With Quote
Old 06-04-2016, 04:29 AM   #17838
my car
syntex1 is offline   Reply With Quote
Old 06-05-2016, 03:48 PM   #17839
Originally Posted by syntex1 View Post
my car
Looks nice!!!
What type of track to you run on??
Old 06-06-2016, 04:15 AM   #17840
large outdoor bumpy track
Old 06-08-2016, 01:14 PM   #17841
Tech Legend
Cain's Avatar
Trader Rating: 235 (100%+)
anyone got a suggestion on setups for low traction dirt for both a dex210v2 standard setup (inline battery) and a plan b based dex210v2 in mid motor configuration?
track has 1/8 style jumps but would roll those as needed.
Also, anyone have experience with the VRP pistons, if so, which ones do you recommend going with front and rear?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL | Yokomo YZ-2 DTM x 2>
Old 06-09-2016, 01:52 AM   #17842
http://site.petitrc.com/setup/durang...hring20120605/ great starting point
Old 06-09-2016, 02:20 AM   #17843
Pittster's Avatar
I have found JP Richard's and Travis's Setup work well on low grip dirt with the Dimec type B and the Alloy chassis, but only when i did the sideways shorty modification.
Also they both appear to use VRP Pistons
http://site.petitrc.com/setup/durang...CRC2016010610/
http://site.petitrc.com/setup/durang...CRC2016012124/
Team Associated B6D, Speed Passion Reventon Pro 1.0, Hobbywing V10 7.5t
Team Associated B64D, Speed Passion Reventon Pro 1.1, Hobbywing V10 G2 6.5t
Team Associated B5M CE, Tekin Rs Gen2, Fleta ZX 17.5t
Pittster is offline   Reply With Quote
Old 06-09-2016, 07:00 AM   #17844
Tech Legend
Cain's Avatar
cool thanks.
I'll give those a look and also compare to what dino has posted.
Old 06-14-2016, 10:51 AM   #17845
Sounds like you're going back to old school off-road style racing.
In and out of the hobby over the last 30 years
VINTAGE: Proud owner of an RC10 CE purchased waaay back in '92.
SORTA OLD: HPI RSR4 3 Evo nitro (hasn't been run in a long time).
MODERN: Durango DEX210v1. Rustler RTR purchased Feb '16 for my 5 yr-old daughter.
emerilnut is offline   Reply With Quote
Old 06-14-2016, 11:44 AM   #17846
Tech Legend
Cain's Avatar
yeah for the summer thats pretty much what it is. Step pins work great lol.
Then when winter comes assuming the track keeps running its carpet like videos I posted.
Old 06-16-2016, 04:22 AM   #17847
Thumbs up
Originally Posted by Pistol123 View Post
Mm4 have me too much understeer in exit, I have noticed much more apex/corner speed with mm3.
Wasn't undriveable on mm3 but was kicking out at the rear when trying full throttle. its on grass which is medium grip (i think)I think the change to shocks and weight should sort it. However I have sideways mid in mind as the next step - starting to look like a b5m or 22 3.0!
First time back at the track last night to practice with the above, much better but still a little loose. Tried shortening the front camber link and lengthening the rear and that really helped, much more bolted down down. Was able to run very consistently and knocked 3 seconds off my average lap time.
Best its ever handled and think I now need to get more laps in to get used to it, I think it can corner quicker than I can drive it now
Pistol123 is offline   Reply With Quote
Old 06-16-2016, 02:01 PM   #17848
So glad to hear. I am on indoor clay. I mostly drive a DEST, my son drives the Dex. I did the sideways shorty conversion. I went to MM3, and no antisquat. Because the rear end was loose last time practicing. His car was dialed. Most rear traction we have had. It felt twitchy to me because it was so on rails. I need to calm the steering down. My DEST has 1.5 degree antisquat. I added lots of weight and it was fun to drive this time out. I need to find more steering though.
Thanks for posting PISTOL. if you have time maybe share your setup when you have a chance.
Old 06-16-2016, 02:34 PM   #17849
Quite similar, mm3, zero anti squat, long rear arms, short front arms, -1 camber all around, 4mm trailing axle and 20' caster.
Although I'm running on grass. If you need more steering then you can run axles in line or with lower front roll centre or shorty Lipo forward.
Old 06-16-2016, 11:36 PM   #17850
I should of been more clear. The Dex has tons of steering, 25 degree castor.
The DEST is lacking steering. Mainly corner entry. I am going to shorten the front arms. And Lower the roll center. Thanks.
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
