Like Tree27Likes
Old 05-28-2016, 08:00 AM   #17806
Tech Legend
Cain's Avatar
Trader Rating: 235 (100%+)
on the stock powered buggies outdoors, do you guys like 12.3mm rotors or 12.5mm rotors?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL | Yokomo YZ-2 DTM x 2>
Old 05-28-2016, 08:36 AM   #17807
invrtd's Avatar
Trader Rating: 19 (100%+)
http://www3.towerhobbies.com/cgi-bin...?&I=LXKR90&P=7
A dab of this grease inside the gear box and on the spur will quiet the noise down. My cars are not noisy. I have had the same tube for over 5 years.
SWEEP RACING-----M2C-----TKO BEARINGS-----RW MODS----BELLGATE DISTRIBUTORS
HB D815/E817/D817T/D413
TLR 22T 2.0
invrtd is offline   Reply With Quote
Old 05-28-2016, 09:20 PM   #17808
Well glad im not the only one that has noticed the noise. I think I might give the grease a try but I don't necessarily think it is needed.
Today, I ran it in the stock class and it was much quieter! I think that the main problem is that the stock and probably Exotek covers simply aren't deep enough and the spur gear basically comes into contact slightly while running the car and causes the contact/rubbing that makes that annoying vibrating noise!
Since I am running the exotek slipper eliminator I decided to slightly sand down the Robinson Racing spur gear a bit with some sandpaper on a FLAT Surface with like 120 Grit. I think it helped quite a bit to silence the tranny like it should be. Not sure, but this might even help with a slipper. However don't remove too much and sacrifice the pads ability to remain in secure engagement with the spur! Basically the material only needs to come off of the Outer edge closest to the cover obviously!
I think it quieted things down for me and interested if anyone else does this if it quiets down their car as well!
Turtle Speed is offline   Reply With Quote
Old 05-28-2016, 11:23 PM   #17809
invrtd's Avatar
I am still running an original dex210. I want to upgrade to plus 8 chassis. Should I go with the dimec/dimec20 or aluminum. I did have a plus 8 dimec back in the day when they first came out, but it broke at the front bulk head so I went back to aluminum chassis. However, I think having the plus 8 would be nicer to drive. Looking at the revolution design plus 11 too since I think I can use my stock side pods. What are opinions on advantages and disadvantages of alum vs plastic chassis? I also ordered slippper eliminator, ultra light idler, and ultra light front 12mm hexes with axle. I am totally upgrading my dex210 since I have 2 of them and so many parts it's cheaper to upgraded than buy the new v3.
For those using slipper eliminator on stock motor on high bite clay and slicks, what rotor are you using in your motors. Higher RPM or torque.
For anyone using Rev Design plus 11 chassis, do I need v2/v3 chassis parts to connect to it or do the original parts work.
TLR 22T 2.0
Old 05-29-2016, 08:47 AM   #17810
Tech Legend
Cain's Avatar
another chassis to throw out there to you is the plan b chassis. I have this, and its a really nice piece of work. Talking to the manufacturer about the chassis (and will be trying this) he is saying that with the orientation of the battery and the chassis, they run the vehicle in mid motor configuration in all conditions. I really like that to cut down on flipping things when I go from dirt to carpet.
Old 05-29-2016, 06:22 PM   #17811
ekt
ekt's Avatar
The DIMEC types chassis have been updated since the initial release, look for the type B versions.
Personally, I'd only recommend the DIMEC for low traction dirt and the DIMEC20 and aluminium for med-high grip due to the difference in flex characteristics.
The RDRP chassis is designed for v1 parts but you can use most v2/v3 parts on it.
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 05-29-2016, 11:53 PM   #17812
invrtd's Avatar
Do you have a link or details about the type b chassis?
TLR 22T 2.0
Old 05-30-2016, 03:38 AM   #17813
ekt
ekt's Avatar
DIMEC http://www.team-durango.com/part-inf...artNo=TD320229
DIMEC20 http://www.team-durango.com/part-inf...artNo=TD320247
Leo Lorenzen
Old 05-30-2016, 09:50 AM   #17814
Tech Legend
Cain's Avatar
try him here:
https://www.facebook.com/planbrc/
Old 05-30-2016, 08:48 PM   #17815
MikeR's Avatar
Trader Rating: 15 (100%+)
Regarding upgrading the chassis- I would wait 2 or so weeks because something has been in the works
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 05-31-2016, 07:06 AM   #17816
Tech Legend
Cain's Avatar
good stuff. Hopefully that includes the rumored wing mounts for the dex410v5/dex210f too.
Old 05-31-2016, 07:23 AM   #17817
That's what I'm talking about!!
WallyRC is offline   Reply With Quote
Old 05-31-2016, 07:38 AM   #17818
Make some wing mounts that raise the wing about 1". It is far too low to be of any use right now. What moron hides an aerodynamic device down low behind a shock tower?
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 05-31-2016, 08:08 AM   #17819
Kremzeek's Avatar
Oh yeah... I hope this is a chassis similar to what they have available for the Losi 22.
Kremzeek is offline   Reply With Quote
Old 05-31-2016, 02:31 PM   #17820
New laydown gearbox option?
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
