Like Tree24Likes
Old 05-09-2016, 09:50 AM   #17731
Can anyone tell me please what front and rear shocks size this car has?
- extended length eye to eye (mm)
- shock travel (mm)
- shock spring diameter (mm)
Thank you
buggyfan99 is offline   Reply With Quote
Old 05-09-2016, 10:09 AM   #17732
Is any one using the Exotek Finned Motor Mount? and if yes, is it helping dissipate heat any better?
What Gears are you using on 8.5T? I have 28/78 and I think it might be too much, still have to try it out a little and check Temps, but would like to see what others are running?
jcsantana92 is offline   Reply With Quote
Old 05-09-2016, 10:45 AM   #17733
I'm running 27/80 on a 9.5t with 35' of boost and all cool after 5 minutes.
Pistol123 is offline   Reply With Quote
Old 05-09-2016, 11:40 AM   #17734
- shock travel (mm)
Thank you
Hi,
The extended length of the front shocks of my 210v1 is 80 mm and from the rear it is 100 mm.
Rear shock compressed is about 68 mm and the front is 60 mm.
The spring inner diameter is 15 mm.
I hope that helps.
Mike
Greetings from Austria
Cat K2 / DEX410V3 / DEX410V5 / DEX210 / DEX210F / Cougar SVR /
YZ-10 '94/'95 WCS/
Spectrum DX3R
micholix is offline   Reply With Quote
Old 05-09-2016, 02:33 PM   #17735
Laker67's Avatar
Trader Rating: 61 (100%+)
I've used the Exotek motor mount on all my 210 cars. Originally it was to keep motor temps down when I was running 13.5. I think it helped a little bit, but not as much as I thought it would. Now I run it to keep slipper temps down more then anything. Running Mod beats the slipper up pretty good and it seems to have helped it from glazing over the pads as quickly.
Thanks to my sponsors: Maclan Racing, Addiction RC, Exotek, Jconcepts, Futaba, and Trakpower
Brian Jenkins
Local track: Addiction RC in Ogden, UT - AddictionRC.net
Laker67 is offline   Reply With Quote
Old 05-09-2016, 04:24 PM   #17736
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
try some RC Shox garolite discs or i think the Mcclune are the same kind of material, no glazing.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Cain is online now   Reply With Quote
Old 05-09-2016, 04:34 PM   #17737
ekt
ekt's Avatar
Originally Posted by Norf888 View Post
Hi!
Iīm building up my thrid Team Durango Car and it is the Dex210V3.
Getting the first trouble.
I want to use the 14mm rims in front because I have a lot of wheel setīs with 14mm rims. If I put the 14mm hex on the axel and then the rim on it there is only 1-2 threads left for the wheel nut???
What am I donig wrong?
Regards Norbert
The front axle for the DEX210v3 is only designed for use with the thinner 12mm hexes provided in the kit. The 14mm hexes are wider and would be the cause of your issue.
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 05-10-2016, 07:13 AM   #17738
Originally Posted by micholix View Post
Hi,
I hope that helps.
Mike
Thank you very much man!
Old 05-10-2016, 08:34 AM   #17739
You are wellcome!
These messurements are from middle to middle of the screws.
Mike
YZ-10 '94/'95 WCS/
Spectrum DX3R
Old 05-10-2016, 11:31 AM   #17740
Dino_D's Avatar
Using a 8.5T I prefer to run a 23 or 24 with a 81T. On a small or mid sized track
But it depends on the size of your track. On a huge 8th scale track I would try up to at 25T.
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
Old 05-10-2016, 07:35 PM   #17741
I run 8.5t, and 83/23
WallyRC is offline   Reply With Quote
Old 05-11-2016, 08:32 AM   #17742
Laker67's Avatar
I've heard that those and the McKune pads are awesome. I think I'm going to grab some for my 210F. But I was actually running the associated HD slipper pads for a while, and they worked well but since then I've switched to the Avid slipper setup. It was night and day on how the car came on and off power. It felt a lot smoother to me and the pads have lasted longer.
Brian Jenkins
Old 05-11-2016, 11:17 AM   #17743
Dino_D's Avatar
Associated pads are a decent upgrade and easy to do.
But the Avid is much better. Run all white pads on low grip, 1 red in the middle for med grip and 2 red for high grip.
Old 05-11-2016, 09:25 PM   #17744
Dino!!!
Good to see you back on here.
I haven't tried the triad on my cars yet but I can vouch for the McKune pads, they are fantastic. Fit better than the RC shox ones. Haven't had any issues.
What size shims/washer are used to shim the rear arms at the inner hinge pins to decrease the front to back motions?
Thanks all
Old 05-11-2016, 10:33 PM   #17745
ekt
ekt's Avatar
Originally Posted by WallyRC View Post
Dino!!!
Thanks all
Built to manual specs, a 3x8x1mm plastic and a metal 3x6x0.5mm.
Leo Lorenzen
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
