Like Tree43Likes
Old 11-10-2011, 11:31 PM   #1756
Originally Posted by Cpt.America View Post
So, I don't have calipers accurate enough to measure the internal and external diameteres of the thrust washers, but all you have to do is put them on at the same time and feel the play between the size of the bolt, and the internal hole to tell that one washer is plum flush with the bolt, and the other one is just so slightly larger with some play. Also, it seems that the larger internal diameter washer, also has a slightly larger outer diameter as well.. but without super accurate gauges, I can't confirm it.
That's exactly what I said. And I also expained why.
Olscool is offline   Reply With Quote
Old 11-11-2011, 01:03 AM   #1757
It is about 0.2mm different between two washers. When you stack two washers, you still can see the diameter different of the internal hole through the eyelets.
rossimega is offline   Reply With Quote
Old 11-11-2011, 01:53 AM   #1758
hacker's Avatar
Trader Rating: 141 (100%+)
washers
7.83mm x 2.83mm
7.98mm x 3.17
does it matter which way the washers go?
I would say YES
Have a look at the xray t3 2011 manual, smallest inside and outside diameter thrust washer is closest to the diff screw
so is the schumacher diffs.....
hacker is offline   Reply With Quote
Old 11-11-2011, 03:05 AM   #1759
stinky cheese's Avatar
Trader Rating: 21 (100%+)
Default Droop
How much rear droop are people running in the rear? I have the rear droop screws all the way in and I think it could do with a bit more.
My racing is supported by the following companies
AKA Tires. http://www.ryperhobbies.com.au/
TKO Competition Development. http://premiermodelsupplies.com/
Tornado RC Chargers
Schelle Racing Innovations.
stinky cheese is offline   Reply With Quote
Old 11-11-2011, 03:41 AM   #1760
hacker's Avatar
take em out cheeseman
Old 11-11-2011, 03:55 AM   #1761
Then it has too much froop. Just wanting to know what people are doing
Tornado RC Chargers
Old 11-11-2011, 06:43 AM   #1762
Matt Howard's Avatar
how much antisquat are you using? I'm running the 3 deg block and have my rear droop screws unscrewed about 1/2 turn. If you're running the 1.5deg block you'll probably need to remove your droop screws to get the needed droop. If you're running the zero deg block you might even need to shim up both suspension mounts to get your droop
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 11-11-2011, 08:06 AM   #1763
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Yes, and you wanted me to check.. so I checked, and I am reporting what I found. Is there a problem here? or are you trolling just for fun?
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 11-11-2011, 08:07 AM   #1764
hacker's Avatar
Default quick release shock mount
can anyone confirm the quick release shock mounts from the original dex410 will fit the 210?
Old 11-11-2011, 08:21 AM   #1765
Jmuck69's Avatar
Trader Rating: 14 (100%+)
They will, just need to use the shorter version
http://www.team-durango.com/part-inf...artNo=TD330032
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 11-11-2011, 08:30 AM   #1766
lockmouth's Avatar
Trader Rating: 33 (100%+)
I used the long mounts an they fit perfect.
MARIO KNOX
HOTBODIES RACING / FULL THROTTLE RACEWAY (OWNER / OPERATOR)
lockmouth is offline   Reply With Quote
Old 11-11-2011, 08:50 AM   #1767
hacker's Avatar
thanks, I just had a look as well, and according to amains site, the longer rear dex410 ones are compatible with the dex210, so will order some when in stock.
the original 210 setup just seem like a pain in the backside to change upper shock positions. Might just change the lock-nut for a regular nut, which sits inside the mount itself.
Old 11-11-2011, 08:59 AM   #1768
mjealey's Avatar
All right, I admit I am not an expert on ball difs and want to make sure I do it right. The Durango diff is a little different than the Losi diff I have experience with. I am a little confused on how to properly install the snap ring. I did not see a groove or anything for it to fit in, but I am pretty sure I did everything right. The diff feels nice and smooth and before I go any further I want to make sure it is right. Someone please give me some good instructions or a video of how to do this diff correctly. I know the Durango is a little different and want to make sure it is right?
Kyosho Inferno MP9 TKI 3 - OS Speed .19 & .21 - KO Propo
WinterBlast 2012 - Knoxville, TN - Chilhowee Park
10/27, 11/10, 12/8, 01/05, 02/02, 03/09*
mjealey is offline   Reply With Quote
Old 11-11-2011, 09:39 AM   #1769
Super Moderator
They may fit, I don't know myself, but I would NOT go based on what amain says. They have all KINDS of parts listed for 210 that are totally incompatible with the 210.
- RCSpecialties -
Old 11-11-2011, 09:48 AM   #1770
you need the longer shock mounts or the shocks won't be spaced away from the tower enough. The one piece shock mounts weigh quite a bit more than the stock setup, I'm gonna keep my mount stock.
RCTech #361
St Ives RC Club B4Bandit Australian Racing 16575 Today 12:44 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
