Like Tree23Likes
Old 11-10-2011, 02:31 PM   #1741
Originally Posted by Jonny5 View Post
Would you care to explain why you think this? I'm not saying it isn't so, but the orientation of the washers should not matter provided that the races are pretty facing the caged thrust. There is a set dimension of the bore that the thrust assembly goes into, defined by the outdrive and the circlip. There is also a set dimension of the thrust assembly- whether you have the larger washer in the hole first or last does not change the overall dimension, nor does it affect the depth at which the diff bolt rests. Maybe I'm missing something. I totally agree that the orientation of the circlip is crucial, but the way I see it the washers should not affect anything. Maybe I'm missing something..
Ok I don't have the parts sitting in front of me but this is how it should be. The washer with the smaller ID goes on the screw first. The smaller hole should be somewhat snug on the screw so it remaines centered as it spins with the screw in the outdrive bore. then the thrust bearing. then the washer with the larger ID goes on. the larger hole is so it does not rub on the screw as it spins the oposit direction of the screw.Also it may have a larger OD so it is centered in the out drive bore that it spins with. were as the smaller washer needs clearance in the bore so it does not rub as it spins oposit of the outdrive. Make sence?
Olscool is offline   Reply With Quote
Old 11-10-2011, 02:55 PM   #1742
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
I dont think they have different internal diameters.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 11-10-2011, 03:01 PM   #1743
Don't think, Check. Even IF they did'nt the outer would still apply.
Old 11-10-2011, 03:10 PM   #1744
Super Moderator
Don't think, Check
Since you "know" that they are in fact different, please post the difference in internal diameters please.
- RCSpecialties -
Old 11-10-2011, 03:12 PM   #1745
Trader Rating: 62 (100%+)
OK, so having run the car for a few weeks now, here are some observations, recommendations and findings.
The car went together great, almost no hand fitting(unlike the 22), but was missing a lower shock cap. I built the car rm4 as I like a lot of rear grip.
First couple nights out with the car went very badly, multiple ball cups popping off, broken steering link, and broken rear shock tower. I replaced the ball cups with jconcepts, and used associated ball studs, problem fixed.
I glued the steering link back together and used it as a template to make one out of carbon fiber. broke that one too. Made another one out of 2 sheets of thin c/f and broke that too. Went to home depot, bought some aluminum and made one out of that. Works perfect, but stripped a servo horn. Got a TLR 22 aluminum servo horn because it is extremely close to the offset and length of the rango one. So far so good but I would like to use a good servo saver if I can find one.
Kit diff balls or rings got very notchy very quick, so I got some b-fast balls and flipped the rings and is now butter smooth. Trick is to not let the diff ever slip. When first adjusting, make sure diff is tight(1/4 turn backed off from locked) and slipper is loose. Do your bench testing of the slipper and slowly tighten it down making sure the slipper will slip before the diff will bark.
Tlr 22 front wheel bolts will work with stock wheels, but not with DE rims.
You can replace all the screws that go straight down from the rr bulkhead to the chassis side plates with 5-40 screws because the 3mm screws dont tighten down.
I am no longer running any down stop screws, as the problems they cause are greater than any gains from ease of adjustability.
I put 4mm limiters in both front and rear shocks and have total shock lengths of 69mm front and 107mm rear. I simply adjust the lower eyelets up or down a little to adjust droop.
If you break a rear suspension arm, you can use one from a DEX410 with a lot of dremeling.(don't ask me how I know this haha).
That's all I can think of for now, hope it helps someone. I love driving this car, it does everything so well. Traction, steering, stability, it has it all.
patrick is offline   Reply With Quote
Old 11-10-2011, 03:54 PM   #1746
Trader Rating: 19 (100%+)
Originally Posted by hopsing View Post
I get what he meant by this..... the washers were a different DIAMETER, not thickness. If you put the bigger of the two washers in first, then the smaller diameter washer would push against the snap ring, but more towards the middle of the ring as opposed to out towards the outer edge where the ring enters the groove of the outdrive..the theory is that as pressure is applied to the thrust assembly, the smaller washer could make the snap ring flex enough that it could dislodge it from the groove. If the larger washer is pushing against the snap ring, then the pressure is applied closer to the "solid" part, where the ring rests in the groove of the outdrive. Little to no flex of the ring means, it shouldnt pop out of the groove.
Now that makes perfect sense. Thanks for clearing it up- I thought he was referring to thickness, not outside diameter.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 11-10-2011, 04:05 PM   #1747
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 39 (100%+)
EXACTLY!! Thanks, I couldnt have explained it any better myself..
*Vandal 4wd Late model*XXX-T sprinter*Micro scale specialties 1/24 'rock monster' crawler*MSS Micro-Rail*MSS Micro-Funny*MSS Micro-Outlaw*
2wdMod is offline   Reply With Quote
Old 11-10-2011, 04:36 PM   #1748
As I said, I don't have the parts in front of me to measure & since my diff has been butter smooth with now failier since day one I don't plan on taking it apart anytime soon. Maybe someone who is having trouble can measure theres & tell me i'm wrong.
The only thing I am 100% sure of is no manufacturer is going to go to the expence & trouble of 2 different washers if it didn't matter how they went.
I do however have a spare schumacher thrust "same design" small measures 3.40 large measures 3.45
Old 11-10-2011, 04:38 PM   #1749
They do have different ID between two washers, smaller goes first, then bearing, then bigger ID. If they go wrong , the diff performance effected.
rossimega is offline   Reply With Quote
Old 11-10-2011, 04:50 PM   #1750
THANK YOU
Old 11-10-2011, 07:22 PM   #1751
Felix's Avatar
Glad I'm not the only one missing the lower shock cap and also break the rear shock tower.
Serpent 811-T TE CLOCKED BONITO
Serpent 811-B TE SPEED
Felix is offline   Reply With Quote
Old 11-10-2011, 07:38 PM   #1752
madweazl's Avatar
Patrick has been laying down some great laps with the car! Must be the tire sauce...
RadioPost
Mugen MBX7r | CRE Picco 5TR/2120 | Hitec 7950/7940
Tekno NB48 | B6 Pro/2058 | Hitec 7950/7940
Kyosho RB6 | Viper VTX10r/Reedy Mach 3 9.5 | Hitec 7940
Schumacher SX3 Pro | Viper VTX10r/Reedy Mach 2 8.5 | Hitec 7940
madweazl is offline   Reply With Quote
Old 11-10-2011, 08:34 PM   #1753
Trader Rating: 66 (100%+)
Can someone tell me what the internal ratio is on this car, RM?
If you can't race it or sleep with it, it ain't worth having!
Gwoodrc is offline   Reply With Quote
Old 11-10-2011, 09:31 PM   #1754
2.6. rm and mm 3 and 4 gear is all 2.6 as the idlers play no part in fdr.
Old 11-10-2011, 09:46 PM   #1755
Super Moderator
So, I don't have calipers accurate enough to measure the internal and external diameteres of the thrust washers, but all you have to do is put them on at the same time and feel the play between the size of the bolt, and the internal hole to tell that one washer is plum flush with the bolt, and the other one is just so slightly larger with some play. Also, it seems that the larger internal diameter washer, also has a slightly larger outer diameter as well.. but without super accurate gauges, I can't confirm it.
- RCSpecialties -
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
