Like Tree24Likes
Old 02-26-2016, 12:20 PM   #17446
Default Sideways shorty mod
Just need to finish electronics. Jconcepts battery brace, B5. Sorry all trying to upload photo and it won't work, will try again later.
WallyRC is offline   Reply With Quote
Old 02-26-2016, 05:09 PM   #17447
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Originally Posted by Cain View Post
I actually got an email from Travis, really cool!
Hope he posts on a Motorama setup and if they are going to make new side pods to run the battery across the chassis because if they do I will just wait for those vs do the mod like they have to run the battery across. I only have 3 or so more indoor races for the season and then its outdoors which I don't run again until next indoor season.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 02-27-2016, 12:31 PM   #17448
Here is a photo. Got it to work.
Old 02-27-2016, 01:44 PM   #17449
Looks nice and clean. Did you cut more off the side pods than you intended? Are you worried about it sliding fore and aft?
In and out of the hobby over the last 30 years
VINTAGE: Proud owner of an RC10 CE purchased waaay back in '92.
SORTA OLD: HPI RSR4 3 Evo nitro (hasn't been run in a long time).
MODERN: Durango DEX210v1. Rustler RTR purchased Feb '16 for my 5 yr-old daughter.
emerilnut is offline   Reply With Quote
Old 02-27-2016, 03:42 PM   #17450
It's in pretty good. Didn't cut out too much. Need a little space to be able to slide battery in. Gonna put some foam somewhere once I get it wired up to keep battery from moving foward.
Old 02-27-2016, 03:54 PM   #17451
I think the Schelle B5m racing one will work better because it has the stops for forward motion built in.
Old 02-28-2016, 05:18 AM   #17452
Devin's Avatar
All the parts stores say the dex210 rear arms are either backordered or even discontinued. Anyone know WTF is going on.
Devin is offline   Reply With Quote
Old 02-28-2016, 07:33 AM   #17453
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
I am assuming it may be related to the new vehicle releases and those parts I guess going into those kits. Tower is showing Mid April for stocking parts again. Hopefully it happens sonner than that.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Cain is online now   Reply With Quote
Old 02-28-2016, 03:56 PM   #17454
Kremzeek's Avatar
Has anyone else cracked the front arms on a DEX210v2 when putting in the droop screw? After breaking an arm at the track, I picked up two replacement sets from Tower and in both cases, the driver side arm cracked when putting in the droop screw. For the heck of it, I tried the passenger side and the droop screw went in there without any problems.
Is this a bad batch of arms? I already emailed Durango USA about a week ago but as usual they're taking their sweet time to respond.
Kremzeek is online now   Reply With Quote
Old 02-28-2016, 04:31 PM   #17455
Trader Rating: 42 (98%+)
Send a message via AIM to RockStar_199 Send a message via MSN to RockStar_199 Send a message via Yahoo to RockStar_199
So i broke a rear arm on my v3 and cannot find replacements for TD330712 type b.....does anyone have a set they would sell or know of another place to find them as everyplace i have looked says out till mid april
Mark C. Math
Kyosho TKI4
Triton Engines: L4 2108
J&T Bearing Co.
RC Pro TX10280
RockStar_199 is offline   Reply With Quote
Old 02-28-2016, 04:58 PM   #17456
Tech Legend
Cain's Avatar
the previous type I see available on ebay right now, the ones with only 1 set of holes for the shock mounting.
Old 02-28-2016, 06:59 PM   #17457
What would be a good shock tower replacement for the v1? (tougher )
Team Durango USA
OS Engines
Iggy 102 is offline   Reply With Quote
Old 02-28-2016, 11:04 PM   #17458
I have the stock v2 one on the front and on the rear I have the strc one.
I have a spare strc for the front but it has to alloy bits to put on the turnbuckle and I race stock so it ways a lot.
offroader47 is offline   Reply With Quote
Old 02-29-2016, 10:34 AM   #17459
I would check out "Diggity Designs". Good price and quality. I have the V2 and am running stock towers and in a year haven't broken one. The rear in the V2 is lower and the front on the V2 is rearward slightly. The front should just swap out. Diggity designs I believe has the V1 and "lowered" v2 as well.
As for rear arms, if you are mounting your shocks on the front of the rear arms. Either V1 or v2 will work. If you are mounting on the rear, better to get the V2/3 rear arms. I know early on people were flipping the V1 rear arms and adding limiter to the shocks because you loose the droop screw adjustments. I don't use the droop screws on the rear anyway because they end up bending the Chasis where they make contact.
As for fronts cracking at droop screw insertion. I would recommend everybody boil your arms for about 3 minutes. Softens them up slightly, shouldn't crack as easily.
Good luck
Old 03-01-2016, 07:55 PM   #17460
Default Good gear diff setup
I know this has probably been asked before, but want to believe that a gear diff could be setup close to a ball diff for indoor clay. Medium to high bite, smaller technical track. I run ball diff I my DEX, gear diff a in my DEST/DESC.
Would like to know what some of you are running that is working well for you. I have seen setups with 50wt oils up to 100,000.
Some say thicker for high traction and I have seen low for high traction.
I've seen 2 gear used.
Any input would be great. Thank you in advance!!
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
