Like Tree43Likes
Old 02-21-2016, 09:34 AM   #17416
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
I remember back in the day that Academy had a vehicle that you could adjust kickup by the hingepins if I recall correctly.
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 02-21-2016, 11:00 AM   #17417
Inserts, at the hinge pins, would be great!!!
WallyRC is offline   Reply With Quote
Old 02-21-2016, 01:18 PM   #17418
Yes, something like that!
http://www.revolution-rc.com/our-pro...inium-set.html
Greetings from Austria
Cat K2 / DEX410V3 / DEX410V5 / DEX210 / DEX210F / Cougar SVR /
YZ-10 '94/'95 WCS/
Spectrum DX3R
micholix is offline   Reply With Quote
Old 02-21-2016, 04:51 PM   #17419
I have a VBC Firebolt, you can use the front bulkhead to set your kick up.
One direction gives you 25 degrees, the other is 30.
manumanrc is offline   Reply With Quote
Old 02-21-2016, 07:27 PM   #17420
Tech Legend
Cain's Avatar
What brands make spur gears in the stock usable sizes other than durango, looking for a 69T spur.
Old 02-21-2016, 08:25 PM   #17421
Pittster's Avatar
http://durangofansite.com/main.php?v...t&buildstep=E3
I have used the RW Racing 69 Spur and it was good quality
Team Associated B6D, Speed Passion Reventon Pro 1.0, Hobbywing V10 7.5t
Team Associated B64D, Speed Passion Reventon Pro 1.1, Hobbywing V10 G2 6.5t
Team Associated B5M CE, Tekin Rs Gen2, Fleta ZX 17.5t
Pittster is offline   Reply With Quote
Old 02-22-2016, 02:18 AM   #17422
I see one problem with that, as by changing the kickup with those inserts, the shock tower stays the same, so the angle from arms/hinge pins change to the shock tower than!?
YZ-10 '94/'95 WCS/
Spectrum DX3R
Old 02-22-2016, 08:21 AM   #17423
Tech Legend
Cain's Avatar
no luck finding those in the USA.
From what i have heard though, the AE spur gears will work with a slight opening of the mount hole, so I'll probably pick up a few of those to try.
Old 02-22-2016, 08:58 AM   #17424
Laker67's Avatar
Trader Rating: 63 (100%+)
Are you running a slipper eliminator? Exotek has one and you can run their gears or Kimbrough gears. It might make getting gears that small easier to find?
Thanks to my sponsors: Maclan Racing, Addiction RC, Exotek, Jconcepts, Futaba, and Trakpower
Brian Jenkins
Local track: Addiction RC in Ogden, UT - AddictionRC.net
Laker67 is offline   Reply With Quote
Old 02-22-2016, 09:39 AM   #17425
I was going to say the same thing. It's not something that I'd do.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 02-22-2016, 10:17 AM   #17426
Tech Legend
Cain's Avatar
Right now I have a slipper eliminator on the Dex210, but popped the gear on my DEX210F. And of course, it was one of those nice expensive machined ones so when I got to setup the dex210 for dirt, it will need a gear with the slipper. As it sits though, I am liking the dex210F enough I may try it on dirt lol.
I wonder if you had say an insert that handles both the insert angle and the upper tower angle too?
Old 02-22-2016, 10:47 AM   #17427
The issue may be as easy as just installing spacers on the upper shock mount to push the top of the shocks forward when using less kick. I know Losi doesn't move the tower with various front kick angles, and maybe it's really that big of a deal, but I like my shocks perpendicular to the arms. That's why I don't like rear mounting shocks on the rear arms. I have to space the tops out really far.
Old 02-22-2016, 01:51 PM   #17428
I believe Schumacher gears work on the dex with no modification. Lowest I've seen is 71 though.
RDRP 72
Old 02-22-2016, 02:04 PM   #17429
With my solution, the hole front package changes by -5*!
YZ-10 '94/'95 WCS/
Spectrum DX3R
Old 02-22-2016, 03:14 PM   #17430
Did u just drill a new hole where the brace went. Was there enough material?
St Ives RC Club B4Bandit Australian Racing 16574 11-04-2017 02:55 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
