Like Tree43Likes
Old 11-10-2011, 08:52 AM   #1726
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by Shadows View Post
he needs to re-test.
The Schuey spurs fit both the 410 and the 210. Its the same inner diameter of 8mm, and uses associated style slipper pads:
I beleive you, I was just repeating what we were told was tested earlier in the thread. See below.
Originally Posted by Glowster21 View Post
Guys I'm a Schumacher Driver, got this for my son to mess with. I'll go pull open the bag with the layshaft and check my Schuie spurs on it, stand by for 10 minutes!
Sorry to report guys that the I.D. of the Schumacher Spurs is waaaayyyy too big.
It appears glowster was only looking at the diameter of the shaft that goes through the gearbox, not the diameter of the piece that the spur gear actually sits on.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 11-10-2011, 08:55 AM   #1727
Super Moderator
Originally Posted by Bman's 3XNT View Post
Guys two quick questions. What ride height are you guys running, and what gearing for a 10.5 motor. I ran a boosted 13.5 with a 28/75 and felt it needed more power down low. I think I am going to change motors. Thanks...
Iv been running 23.5mm F and B.
- RCSpecialties -
Old 11-10-2011, 09:48 AM   #1728
hopsing's Avatar
Trader Rating: 13 (93%+)
I'm currently at 24mm ride height in back and around 23.5 in front
Steve Butts
AKA, TrakPower, Serpent America/Desoto Racing, TrackStar, Futaba, EKD Paints
hopsing is offline   Reply With Quote
Old 11-10-2011, 10:03 AM   #1729
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Does the 210 come with simple tools like allenwrenches and the cross nutdriver?
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 11-10-2011, 10:05 AM   #1730
Super Moderator
seesh.. im trying to remember if it comes with any tools at all... my failing old man's memory is telling me no. (but it does come with a turnbuckle wrench)
- RCSpecialties -
Old 11-10-2011, 10:08 AM   #1731
Jmuck69's Avatar
My kit will be here tomorrow but I have not ordered my tools yet.
B6D | B64D
Old 11-10-2011, 10:09 AM   #1732
Super Moderator
this guy is selling two NIP 210s:
http://www.rctech.net/forum/r-c-item...a-shipped.html
- RCSpecialties -
Old 11-10-2011, 10:11 AM   #1733
Super Moderator
don't waste your money on anything other than MIP Thorp wrenches. Best money you will spend in this hobby. You will need more than just this, but this one is a must:
http://www.amainhobbies.com/product_...ex-Driver-20mm
- RCSpecialties -
Old 11-10-2011, 11:56 AM   #1734
Jmuck69's Avatar
That is all I use, but everything is for the B4 except the 2.5 and 1.3 mm. I was picking up a Schumacher 5.5mm and 7mm nut drivers. I have a THorp wrench I bought back in 89' that I still use and never rounded out.
B6D | B64D
Old 11-10-2011, 12:21 PM   #1735
Trader Rating: 19 (100%+)
Originally Posted by 2wdMod View Post
for the reason you mention, it DOES matter if one of the thrust washers is larger!! The larger of the 2 needs to be seated against the snap ring.Some of the issues people are having could be the result of using the smaller of the 2 washers against the snap ring. Combine that with having the snap ring in "upside down' so to speak so the rounded edge is the one carying the load and i can surely see where this could cause the issues some are having with the snap ring coming unseated from the groove it rests in.
Would you care to explain why you think this? I'm not saying it isn't so, but the orientation of the washers should not matter provided that the races are pretty facing the caged thrust. There is a set dimension of the bore that the thrust assembly goes into, defined by the outdrive and the circlip. There is also a set dimension of the thrust assembly- whether you have the larger washer in the hole first or last does not change the overall dimension, nor does it affect the depth at which the diff bolt rests. Maybe I'm missing something. I totally agree that the orientation of the circlip is crucial, but the way I see it the washers should not affect anything. Maybe I'm missing something..
XRAY, RC America, MOTIV, Sanwa, Arrowmax, Neverlift Racing Apparel
Jonny5ive Designs- by racers, for racers!
Jonny5 is offline   Reply With Quote
Old 11-10-2011, 12:34 PM   #1736
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
You're not missing anything. If the bore is "X" deep the thickness of the overall thrust assembly will not change if the washers are on either side. The "X" will still measure the same length.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 11-10-2011, 12:40 PM   #1737
TAMAK's Avatar
Trader Rating: 28 (100%+)
Yeah, my thought was the depth of the thrust bearing of other brands causing issues with the diff assembly being over tightened. Which may cause the circlip to fail prematurely. I have a sneaking suspicion that some peoples hands are not calibrated properly.
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 11-10-2011, 12:50 PM   #1738
Ok, I'm not going crazy here....
Any Durango guys going to Trackside this Saturday? We're gonna go and try to get a headstart tuning for the Spektrum race- I have the SC10 with a big "5" on that the roof and Cush will be running his Durango buggies.
Old 11-10-2011, 12:51 PM   #1739
TAMAK's Avatar
I'm in, I will be the guy with the black rangos. Only guy with Durangos recently.
Old 11-10-2011, 03:13 PM   #1740
hopsing's Avatar
I get what he meant by this..... the washers were a different DIAMETER, not thickness. If you put the bigger of the two washers in first, then the smaller diameter washer would push against the snap ring, but more towards the middle of the ring as opposed to out towards the outer edge where the ring enters the groove of the outdrive..the theory is that as pressure is applied to the thrust assembly, the smaller washer could make the snap ring flex enough that it could dislodge it from the groove. If the larger washer is pushing against the snap ring, then the pressure is applied closer to the "solid" part, where the ring rests in the groove of the outdrive. Little to no flex of the ring means, it shouldnt pop out of the groove.
Steve Butts
St Ives RC Club B4Bandit Australian Racing 16575 11-18-2017 12:44 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
