Like Tree43Likes
Old 02-13-2016, 05:54 PM   #17356
Trader Rating: 14 (100%+)
how has the durability been on the DEX210 V3? Durango isn't a popular brand in our area, however, the car has proven to be fast in the region, we are debating whether we should carry the car in our store. Thanks in advance for replies!
o.s. power is offline   Reply With Quote
Old 02-13-2016, 06:20 PM   #17357
Cool dec210v2
JRSLASH is that aV2 or is it a V3
flbugboy is offline   Reply With Quote
Old 02-13-2016, 06:28 PM   #17358
My 10 year drives it like he stole it. Couple front a arms in a year. Nothing else. Very durable.
WallyRC is online now   Reply With Quote
Old 02-13-2016, 07:41 PM   #17359
My v1/v2 is very durable, great car
offroader47 is offline   Reply With Quote
Old 02-14-2016, 10:34 AM   #17360
Trader Rating: 42 (98%+)
Send a message via AIM to RockStar_199 Send a message via MSN to RockStar_199 Send a message via Yahoo to RockStar_199
i dont have time to get the durango wheels........what other brand fits close to the durango wheels?
Mark C. Math
Kyosho TKI4
Triton Engines: L4 2108
J&T Bearing Co.
RC Pro TX10280
RockStar_199 is offline   Reply With Quote
Old 02-14-2016, 10:49 AM   #17361
I think xray are the only other 14mm wheels
blankenj99 is offline   Reply With Quote
Old 02-14-2016, 11:07 AM   #17362
bdyche's Avatar
Send a message via ICQ to bdyche Send a message via AIM to bdyche Send a message via Yahoo to bdyche
It is not the most durable car, but I wouldn't consider it fragile - I would say it is more durable than a Kyosho RB6, but certainly less durable than a TLR or AE. I picked up a new DEX210V3 kit to do some testing (quality research before jumping in with a DEX410V5) and I have found some of the plastic to have issues. The front rear hanger (C mount) has been the worst. Out of the box all 3 included hangers broke during assembly (the plastic at the apex of the outer radius split). Team Durango sent me another set and 2 of the 3 broke on assembly in the exact same manner. The 3+0 mount split on the left side, same with the 3+3 mounts and both 3+1.5 mounts split on the right side. I have been testing this car primarily on turf so I ordered a gear differential for it. During assembly, 1 of the 8 screws to hold the differential halves together encountered no resistance. It is assembled with a 0.050" driver, so it is not something that should require any torque to put together, but even 2 fingers was enough to split the plastic. I have not yet sent pictures of this to Team Durango, but it is on the agenda for the day.
The only parts that have broken during driving have been a rear arm (hit by another car in air) and a right C hub (clipped a pipe at high speed). I would consider both of those acceptable breakages. The only problem right now is that you cannot get the Type B rear arms anywhere, so I replaced the rear arms with Type A.
Performance of the car has been fantastic, otherwise. There is quite a bit of drag in the transmission with new gears, but the car is still fast and doesn't build heat. The shocks are very also very good, so if you were to carry the aluminum rear suspension holder (TD330565) and the standard arms/towers/C hubs/knuckles it would be good.
Durango DEX210 Thread-wp_20160211_19_36_03_pro.jpg   Durango DEX210 Thread-wp_20160211_18_15_35_pro.jpg
Tacoma RC Raceway /// Mike's RC World (RIP) /// Skagit River Raceway /// DieHard RC
Kyosho America /// Maclan Racing /// Xpert RC /// AKA /// Pro-Match Racing /// Stuck On Racing (SOR)
Maclan Racing Northwest Region Team Manager
bdyche is offline   Reply With Quote
Old 02-14-2016, 12:18 PM   #17363
Kremzeek's Avatar
Wow. I've broken plenty of RF hangers by crashing but never during assembly and never at one of the screw holes.
I have had issues with the gear diffs though. With the last one I bought I stripped about half the screws and split one of the screw holes.
Kremzeek is offline   Reply With Quote
Old 02-14-2016, 01:52 PM   #17364
In basically 3 years, I have broken 1 rear arm. That's it. The car is damned tough.
fredswain is offline   Reply With Quote
Old 02-14-2016, 05:49 PM   #17365
DE Racing makes Speedline and Borrego wheels for the DEX210. Can be bought everywhere including Amazon. Speedlines are just normal wheels. The Borregos have a pronounced "rim" to make it look like a beadlocker. I just mounted up a set of Speedlines last night. They fit great.
In and out of the hobby over the last 30 years
VINTAGE: Proud owner of an RC10 CE purchased waaay back in '92.
SORTA OLD: HPI RSR4 3 Evo nitro (hasn't been run in a long time).
MODERN: Durango DEX210v1. Rustler RTR purchased Feb '16 for my 5 yr-old daughter.
emerilnut is offline   Reply With Quote
Old 02-14-2016, 06:02 PM   #17366
joehundy's Avatar
Trader Rating: 15 (94%+)
Default side ways shorty
im running yokomo yellow rears and kyosho white fronts
3/1.4 front pistons 32.5 TLR
2/1.6 rear 30 TLR
cut carbon from a battery brace use the 22 turn buckles drill the rear brace and put a nut on the bottom for the turnbuckles
if you use B5 front wheels need to reem the hole a little make fit with the 12mm hexes
Thanks to
AmainHobbies/Protek/RB/Upgrade Rc/Jconcepts/Odonnelle fuel
joehundy is offline   Reply With Quote
Old 02-14-2016, 09:12 PM   #17367
Laker67's Avatar
Trader Rating: 63 (100%+)
2/1.6 rear 30 TLR
Are you using the VRP pistons or did you drill the 1.4's for the front?
Thanks to my sponsors: Maclan Racing, Addiction RC, Exotek, Jconcepts, Futaba, and Trakpower
Brian Jenkins
Local track: Addiction RC in Ogden, UT - AddictionRC.net
Laker67 is offline   Reply With Quote
Old 02-15-2016, 01:14 AM   #17368
fast-ho-cars's Avatar
does the V3 or F version use hex wheels front and rear?
on sideways shorty above...what holds the pack in place?
F-version http://www3.towerhobbies.com/cgi-bin...&I=LXFRFV&P=SM is showing in stock now using 014R2 coupon code $60 off = $319.98 + free shipping
fast-ho-cars is offline   Reply With Quote
Old 02-15-2016, 02:27 AM   #17369
ekt
ekt's Avatar
According to TDs website, the v3 and F come with the parts to run either bearing or hex front wheels. Comes with 12mm and 14mm hexes for the rear
http://www.team-durango.com/race-cars/dex210f/
http://www.team-durango.com/race-cars/dex210v3/
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 02-15-2016, 09:42 AM   #17370
I think the V3 comes with the front 12mm hexes but not sure if it comes with the proper front hubs, bearings, and axels to convert. They may be aftermarket pieces.
Can someone comment that has purchased the V3?
St Ives RC Club B4Bandit Australian Racing 16575 Today 12:44 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
