Like Tree23Likes
Old 11-09-2011, 07:29 PM   #1711
Jmuck69's Avatar
Originally Posted by Shadows View Post
just wondering...For those of you who are breaking rear shock towers.... are your kits from the first production run batch?
cheese-man, if you are stuck searching for RW spurs, Schumacher spurs are a direct bolt on
The center hole is the same?
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 11-09-2011, 07:52 PM   #1712
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
We had a guy test this already and he reports that they are nowhere near the same.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 11-09-2011, 08:09 PM   #1713
TAMAK's Avatar
Trader Rating: 28 (100%+)
Originally Posted by KainK View Post
Thanks for the help today. I found quite a few places to get the circlips in the search. I ended up ordering from a couple different places to try some different types.
We need a first page organized like the Losi SCTE's page. Really helps to have resources like that. On this thread if you miss a couple days of not reading its like work just to catch up on info.
I also ordered a couple different thrust bearings to try also. I think I like the looks of the Schumacher one the best.
Do us a favor and take a caliper and measure each setup then test. Would be nice to have measurable data.
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 11-09-2011, 08:31 PM   #1714
bender's Avatar
My spur gear from my cougar sv fitted the dex210 perfectly - they both use 8mm inside diameter hole
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 11-09-2011, 09:11 PM   #1715
ronsand's Avatar
These things brings out the engineer in me (and I hear some say Internet-engineer )
The rear shock towers breaking on flat (or right side up) landings gets me thinking about the 55mm vs 52mm shock shafts.
The nut on top of the piston might be bottoming out in the top of the shock with the 55mm shaft, giving a blow to the rear tower (the rubber damper on the shaft might compress on impact sending the piston to high).
If that is not the case then the towers might be a bit under-dimensioned or the shock mounting holes should be raised slightly (but then also reducing down-stroke/droop).
just my two cents anyway. I will look into this when building mine next week.
Mugen MBX7 - Tekno V4 MBX6 - DEX410v3 - DEX210 - DESC410 - Serpent S411 - Futaba 4PKs - Tekin RX8 + RS Pro - Werks B6
ronsand is offline   Reply With Quote
Old 11-09-2011, 09:17 PM   #1716
fullsyzz's Avatar
Trader Rating: 102 (100%+)
A friend of a friend (whatever that's worth) also says the Schum. spur was a direct bolt on and been running flawless, but I have not seen it yet.
fullsyzz is offline   Reply With Quote
Old 11-09-2011, 10:06 PM   #1717
Rdog's Avatar
Trader Rating: 83 (100%+)
Just finished building mine.....went together pretty good cant wait to get it out on the track and run it
Rdog is offline   Reply With Quote
Old 11-10-2011, 12:00 AM   #1718
Damit's Avatar
Trader Rating: 22 (100%+)
Default DEX210
Trust me when I say the set up out of the box is A1, this car maybe the best
2wd car ever made, it drives like a 4wd the grip is unbelievable.
I am now converted to Durango, next on the list DEX410.
B6d 2wd / B64d 4wd - SJF01 Street Jam F1 - Tamiya Mini v2
Futaba-HW-LRP-Lunsford-Reedy/Associated
South Australian Member: AERCCC #16 and ARCR 9098
Damit is offline   Reply With Quote
Old 11-10-2011, 03:12 AM   #1719
Bman's 3XNT's Avatar
Trader Rating: 70 (100%+)
Guys two quick questions. What ride height are you guys running, and what gearing for a 10.5 motor. I ran a boosted 13.5 with a 28/75 and felt it needed more power down low. I think I am going to change motors. Thanks...
Team Durango DEX410 w/3 Diffs ;) The original
Xray Xb2 CE
www.rchr.biz------www.Wolcotthobby.com
Bman's 3XNT is offline   Reply With Quote
Old 11-10-2011, 05:33 AM   #1720
EastCoasterVa's Avatar
Mine was from the first batch. I landed very hard and the shock tower broke. The buggy survived a few hard crashes (in another race) before the tower broke. Overall I am very happy with the durability of the buggy. The shock tower does appear to need more material around the affected areas.
EastCoasterVa is offline   Reply With Quote
Old 11-10-2011, 06:45 AM   #1721
Shadows's Avatar
Trader Rating: 23 (100%+)
he needs to re-test.
The Schuey spurs fit both the 410 and the 210. Its the same inner diameter of 8mm, and uses associated style slipper pads.
I have ran an 83T spur in my 410 in the past. Schuey Part number is U3351
76T spur is part number U3790
RYPER AKA YOKOMO MIP
Shadows is offline   Reply With Quote
Old 11-10-2011, 07:01 AM   #1722
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Can someone tell me if the DEX410 and DEX210 use the same servo horns?
kwiksi is offline   Reply With Quote
Old 11-10-2011, 07:26 AM   #1723
Jmuck69's Avatar
They use two different servo horns. #320124 for the 210 and #340007 for the 410.
B6D | B64D
Old 11-10-2011, 07:30 AM   #1724
Yes. I know they have diff part #'s, but they look very similar in pics. I just bought a used 410, but I need a servo saver. I have the spares from my 210 that I can use with diff brand servo.
Old 11-10-2011, 07:33 AM   #1725
TAMAK's Avatar
I would go ALU on the 410. Racers edge makes a good one. Stick with plastic on the 210 cause there is no servo saver.
St Ives RC Club B4Bandit Australian Racing 16563 Yesterday 04:32 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
