Like Tree26Likes
Old 02-02-2016, 06:52 PM   #17221
Kremzeek's Avatar
Originally Posted by prosport View Post
I removed the slipper assembly, the lay shaft spins easily by hand and it seems to have zero play when trying to push/pull it.
I'm confused as to why this slipper won't grab.
Another thing you can try is to add a 0.2mm shim or two between the gear box and the slipper (check page 27 in the dex210v2 manual to see what I mean). If you still can't get it tight enough, try adding a shim on the side with the spring.
Originally Posted by asalas View Post
Do you know what online shops are stocking all of the V3 upgrade parts? I have always used Amain but they don't have them in stock. maybe some in the UK?
Not in the UK.. but Tower has a bunch of them in stock. I currenlty have the new axles, hexes, etc in my cart over there.
Kremzeek is offline   Reply With Quote
Old 02-02-2016, 07:07 PM   #17222
prosport's Avatar
Trader Rating: 21 (100%+)
Ok I'll try that. Would a stiffer diff spring help or does it not work that way? This one feels stiff between my finger and thumb but it crushes easily with the little adjusting nut.
prosport is offline   Reply With Quote
Old 02-02-2016, 08:46 PM   #17223
Kremzeek's Avatar
That might help. Adding shims would probably do the same thing, at least in the short term.
Old 02-03-2016, 12:20 AM   #17224
csi
Hi!
Originally Posted by Cain View Post
I messaged exotek about exotek part # 1294 steering hub that was designed for the desc210 and here is their response:
Any thoughts on this? I am tempted on buying it, but its not a cheap option so would hate to have an expensive paperweight sitting here.
I'm using Exotek #1294 (DESC210 FRONT STEERING HUBS) and #1513 (DEX210 12MM HEX TITANIUM FRONT AXLES) in combination with RDRP #RDRP0185 (DEX210 Aluminium C-Hub Set) on my v2 without any issues.
Regards
csi is offline   Reply With Quote
Old 02-03-2016, 12:52 AM   #17225
One thing you could try too, are the AE HD slipper pads, they are a bit thicker than stock pads, may that helps too!?
Greetings from Austria
Cat K2 / DEX410V3 / DEX410V5 / DEX210 / DEX210F / Cougar SVR /
YZ-10 '94/'95 WCS/
Spectrum DX3R
micholix is offline   Reply With Quote
Old 02-03-2016, 01:16 AM   #17226
prosport's Avatar
Good idea, do you know which part number for the AE slipper pads?
Old 02-03-2016, 01:29 AM   #17227
Parts # should be, AS91170, for those.
YZ-10 '94/'95 WCS/
Spectrum DX3R
Old 02-03-2016, 01:53 AM   #17228
prosport's Avatar
Awesome thanks
Old 02-03-2016, 05:57 AM   #17229
Awesome thanks
You are wellcome!
Be sure, you put those two 5x7x0.2 mm shims, parts #709015 behind the first slipper disc, as if it was at the V1, there was only one shim behind and that was the most common problem that the slipper could not get tight enoth!
YZ-10 '94/'95 WCS/
Spectrum DX3R
Old 02-03-2016, 06:21 AM   #17230
Tech Legend
Cain's Avatar
Trader Rating: 234 (100%+)
I remember this problem. From what I recall it was like the pads were too thin.
If you are going to get new pads, I would suggest giving RC Shox a look or message and see about getting some garolite discs from them. The AE ones they have should work too if he doesn't have specific durango ones. I have these for my vehicle and even when running on carpet I had perfect slipper action with zero fade. To be honest even going with a slipper eliminator its hard to tell the difference, it performed that well.
Originally Posted by csi View Post
Hi!
Regards
Cool! Based on what you have seen, do see any issue with the stock plastic C-hubs then with the desc210 front steering hubs from exotek?
hope to make some serious headway on getting my vehicles ready for saturday.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Cain is online now   Reply With Quote
Old 02-03-2016, 07:12 AM   #17231
Tunatsol's Avatar
i like the arrma slipper pads on my v1. AR310584 They are thicker than stock. But only has one usable side.
Josh Youngs
Team Durango: DNX8, Dex8, 408, 210, 410v3,
Sponsored By: Dialed Hobbies
Tunatsol is offline   Reply With Quote
Old 02-03-2016, 08:05 AM   #17232
JRSlash's Avatar
in the v3, if I use the optional 12mm hexes... what wheel offset fits this buggy?
SOAR Seiki 998 TD1 Nitro
SOAR Seiki 998 TD1 E-buggy
PR Racing SB401
Dialed-RC Hobbies (www.dialedhobbies.com), SOAR Seiki USA
Bellgate Distributor (www.bellgatedistributor.com), PR Racing USA
JRSlash is offline   Reply With Quote
Old 02-03-2016, 08:23 AM   #17233
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Thumbs up
Did get a few runs of practice last night. I was able to try some Kyosho springs last night on my buggy. Ran some Gold rears and White fronts ( I was running AE White front and white rear). Car was very close to the same overall feeling with the rear maybe loosened up feeling just a bit which was fine. I have tons of traction with this car and the Proline Microns I run. After that run I was looking for more rear rotation in the corner so I moved my rear inner camber link to the #1 position on the transmission case (Was running #2) and added 3mm spacers under the ball stud (still in #2 position on the stock plastic hub). Took the car out for my 2nd run and the car now rolls more in the corner and rotates quicker for me through the corner so that is exactly the reaction I was looking for from the car. My overall rear traction is still excellent and I don't see any lack in rear overall traction. I can always lower the inner ball stud if I need more traction but at this time 3mm is perfect.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 02-03-2016, 08:31 AM   #17234
wyd
Tech Legend
wyd's Avatar
good stuff thanks!
so what is everyone's take on the 60mm wheel deal or 2.4" Plus as DE calls them?
I have to say, if I setup the other dex210 as the loner, may get it pink wheels lol.
I also picked up the mid motor bulkhead from exotek. looking forward to trying it out.
I have run the 2.4 setup on my B5M and my V3 and honestly as I get new tires I'm going back to the 2.2 setup. I find its much easier to glue up the 2.2 setup and on the track performance I don't see any difference performance wise. I do see the 2.4 pulling off the rim some (especially with new less experienced racers) and guys ripping tires (mainly in the 4wd buggy class). I just feel the 2.2 tire setup feels better to me overall so that is what I'm going back to.
Old 02-03-2016, 08:35 AM   #17235
wyd
Tech Legend
wyd's Avatar
I would take the stock slipper pads off and lightly sand them as they might be glazed over from the continual slipping.
It sounds like your diff is loose to me and not the slipper. Does the car chirp/bark under hard acceleration? If so that is the diff. The slipper slipping will be fairly quiet when it slips. Two totally different sounds as to which one is slipping.
St Ives RC Club B4Bandit Australian Racing 16570 09-23-2017 03:48 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
