Like Tree26Likes
Old 01-30-2016, 11:10 AM   #17176
Originally Posted by micholix View Post
As you have any more questions, feel free to ask and i will try to answer, or do some messurements for you..
Why is the front of your chassis flat?
"Speak only if it improves upon the silence."
http://goo.gl/MFfbzr - My ever-updating comprehensive spring rate chart
Bracket is offline   Reply With Quote
Old 01-30-2016, 11:21 AM   #17177
This is because the kick up was bent/twisted from a hard crash, and now i use it for messurements for my custom chassis!
Greetings from Austria
Cat K2 / DEX410V3 / DEX410V5 / DEX210 / DEX210F / Cougar SVR /
YZ-10 '94/'95 WCS/
Spectrum DX3R
micholix is offline   Reply With Quote
Old 01-30-2016, 06:26 PM   #17178
Originally Posted by wyd View Post
Anyone running the -2mm rear alum mount with the Rear Front option aluminum mount with the pills? What pills are you using. It seems to me by the chart that using the #2 down gives me degree anti squat?
When I look at the chart that comes with the new aluminum RF mount it shows that I ran 4.8 anti squat when using the stock 1.5 plastic RF mount and the -2mm rear mount. If that is really true I never ran a car with more than 2mm anti squat before and I have lots of traction and no funny stuff under breaking so I'm already happy.
Yes, i also run this setup. Using exotek RF mount with both shims and their -2mm rear mount. It works very well at my local track. I agree with you, it give me excellent forward traction and does not get loose when braking.
mxzman is offline   Reply With Quote
Old 01-30-2016, 09:29 PM   #17179
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Did get everything done and ready for Sunday sonwill be interesting to see what a difference it makes on the track now that my anti squat is at more of a normal setting.
I would like to hear what Travis Amezcua or JP Richards has to say about the anti squat with the -2mm RR block and if my earlier post is correct with my overall anti squat setups.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 01-31-2016, 03:06 AM   #17180
Default Steering mod update! #2
Ok, so i did find the right position for my servo.
I do not have a correct servo arm with the right offset yet and only have a broken servo for testing for now, but you can see, it will work...
I only have to make a top plate with four M3 holes to hold the servo in place.
It will be not possible, to run a standard battery anymore, as the servo comes further in the back.
The servo mounting post i used, are RPM #70062
First picture is from the top, to see the possition from servo.
YZ-10 '94/'95 WCS/
Spectrum DX3R
Old 01-31-2016, 03:08 AM   #17181
From the side, with servo in place, to see, the mounting posts are the same high, as the top of the side pods.
YZ-10 '94/'95 WCS/
Spectrum DX3R
Old 01-31-2016, 03:10 AM   #17182
...without servo, to see, what to cut off of the side pods.
YZ-10 '94/'95 WCS/
Spectrum DX3R
Old 01-31-2016, 03:13 AM   #17183
...and one from the top.
I only have done one side pod, at the moment and you have to cut off the little nose piece from the front brace.
YZ-10 '94/'95 WCS/
Spectrum DX3R
Old 01-31-2016, 11:16 AM   #17184
Looking good Micholix!!! Can't wait to see the finished product and see how you think it feels in the car.
I saw a full aluminum STRC B5 steering rack on Amain hobbies for 24 bucks if any body is thinking of doing this mod as well.
WallyRC is offline   Reply With Quote
Old 01-31-2016, 01:00 PM   #17185
wyd
Tech Legend
wyd's Avatar
On the 210V3 what rear aluminum 12mm hexes are you guys using? The plastic ones I'm starting to round off some running mod.
Old 01-31-2016, 02:06 PM   #17186
Team Durango USA
OS Engines
Iggy 102 is offline   Reply With Quote
Old 01-31-2016, 02:35 PM   #17187
Best bet is get the exotek ones. I have a pair of proline Associated B4.2 aluminum hexes I pulled of my old car and they fit perfect as well. I have heard people are using the B5 ones as well. I Have also heard that there is a difference between some of the B5 ones with the lite version being a different size. I'm not exactly sure.
Old 01-31-2016, 02:58 PM   #17188
Default TLR 22 3.0 servo mount
Micholix,
Think these might work to mount the servo. The dimension look close. Then no upper brace and might be able to integrate into the sidepods. It's an exotek 22 3.0 servo mount
Old 01-31-2016, 04:14 PM   #17189
The B5 lite has larger dia axels they will not fit. The hex that fits the smaller dia axel will work just fine. I have them on my dex 210.
sgtlt is online now   Reply With Quote
Old 01-31-2016, 05:33 PM   #17190
Thanks for that info!!
St Ives RC Club B4Bandit Australian Racing 16570 Today 03:48 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
