Like Tree24Likes
Old 01-26-2016, 08:52 AM   #17116
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Originally Posted by Cain View Post
yeah that is what I noticed too.
So, can someone common with me running the motor the wrong way apparently in a 3 gear setup, what will I notice that is different exactly handling wise?
I run the 3 gear setup in my Dingo and it is smooth and consistent in stock. I also ran an 8.5 in it and it was almost just smooth as running stock. Needed a little more steering but car was very easy to drive and no funny business.
Wow not on for a few days during the snow storm and this thread was really busy. Nice to see it busy again.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 01-26-2016, 09:12 AM   #17117
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
yeah I am liking the 3 gear setup, with probably just stick with that.
For when Mod time comes, I have an 8.5T motor here I'll probably drop in as I am used to how to how it performs unless I pick up something else to run it in, like an SCT.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 01-26-2016, 10:07 AM   #17118
Originally Posted by emerilnut View Post
Thanks, guys. I was sure I was just fine if everything was cooler, but wasn't sure if I was sapping performance running cooler than desired.
There were a couple of others in there. I didn't really focus on them since I was focused on the rebuild. I'll give them a look and start playing with gearing to see how fast this thing can go since I seem to have plenty of room with temperature.
Stock gear should be 81, the 87 came on the ST and SC.
blankenj99 is offline   Reply With Quote
Old 01-26-2016, 12:03 PM   #17119
Tunatsol's Avatar
The Dex210 came with a 87 as well. At least the v1 did.
Josh Youngs
Team Durango: DNX8, Dex8, 408, 210, 410v3,
Sponsored By: Dialed Hobbies
Tunatsol is offline   Reply With Quote
Old 01-26-2016, 01:08 PM   #17120
JRSlash's Avatar
quick question. Does the V3 kit comes with wheels? I don't get a clear answer @ tower. Thanks. Im thinking of getting a DEX210
SOAR Seiki 998 TD1 Nitro
SOAR Seiki 998 TD1 E-buggy
PR Racing SB401
Dialed-RC Hobbies (www.dialedhobbies.com), SOAR Seiki USA
Bellgate Distributor (www.bellgatedistributor.com), PR Racing USA
JRSlash is offline   Reply With Quote
Old 01-26-2016, 01:15 PM   #17121
Right, V1 came with an 87 tooth, verified on the durango website on the standard parts page.
In and out of the hobby over the last 30 years
VINTAGE: Proud owner of an RC10 CE purchased waaay back in '92.
SORTA OLD: HPI RSR4 3 Evo nitro (hasn't been run in a long time).
MODERN: Durango DEX210v1. Rustler RTR purchased Feb '16 for my 5 yr-old daughter.
emerilnut is offline   Reply With Quote
Old 01-26-2016, 02:31 PM   #17122
Yes 87 for the kit cars but the rtr cars came with 81 and 28 or 29 pinion for the stock 13.5t motor.
Quick question - Has anybody had issues with the ball diff providing different amounts of torque at each wheel? In summer we run on grass and I noticed off the line it often pulls to the left, have rebuilt the diff several times and noticed the output shaft is much more worn on the right had side and no wear on the left 😕
Looking at replacing with a free diff but would still like to get it working correctly. Any ideas?
Pistol123 is online now   Reply With Quote
Old 01-26-2016, 03:08 PM   #17123
tc5 man's Avatar
I wouldn't be surprised if that dumb C clip that holds the thrust bearings in got loose .
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
Old 01-26-2016, 03:42 PM   #17124
Laker67's Avatar
Trader Rating: 61 (100%+)
Yep it comes with the standard 14MM rear hex wheels, and bearing front wheels. It has everything to convert the car to 12mm hexes but no wheels in the box to go with them.
Thanks to my sponsors: Maclan Racing, Addiction RC, Exotek, Jconcepts, Futaba, and Trakpower
Brian Jenkins
Local track: Addiction RC in Ogden, UT - AddictionRC.net
Laker67 is offline   Reply With Quote
Old 01-26-2016, 09:04 PM   #17125
Kremzeek's Avatar
Have you checked your outdrive bearings?
Kremzeek is offline   Reply With Quote
Old 01-26-2016, 11:28 PM   #17126
Good call, I didn't specifically check these but think I would have noticed as I have rebuilt the diff three times and it always done it. Guess I really need to check all the bearings (hubs as well) on the left hand side.
Thanks.
Old 01-27-2016, 06:24 AM   #17127
Tech Legend
Cain's Avatar
looks like the parts used for the front 12mm hex setup, at least the steering knuckle or whatever its called is hard to find right now. Was looking at some options and was having issues finding it at common places, with tower having it listed as May when they will get a restocking ???
Though, I do wonder, the part number for the dex210v3 steering knuckle is slightly different, has a -1 on the end.
Old 01-27-2016, 06:32 AM   #17128
Kremzeek's Avatar
Has anyone else looked at the setup sheet for the 210F? It looks like it has the same/similar RR hanger that Travis had on his car.
http://www.team-durango.com/pdf/setu...an%202016).pdf
Old 01-27-2016, 06:34 AM   #17129
Tunatsol's Avatar
My car would pull to the right on starting line. It was the rear shocks not compressing at the same rate letting the right side squat more. So the car acted like it had torque steer.
Josh Youngs
Old 01-27-2016, 07:26 AM   #17130
If your car is pulling to one side there is always a few things to look at. Binding in the transmission for sure.
Like stated above if your rear shocks are not equal, then the tire with more spring compression will grab quicker. I was adjusting ride height one time and turned on spring tensioner clockwise and the other counter clock wise.. Oops.
Also your front droop settings have to be equal. If one front tire lifts off the ground before the other the weight is transferred unequally to the rear and sideways you go.
So many things..
I must say though.. My 10 year old son drove his buggy better than I could this past weekend. He was pushing it hard, crashing hard. This buggy is very durable. He broke the rear wing off by the end of the day but nothing else. He hasn't popped one of the balls off in a year. Love it!!
WallyRC is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
XXX-Chris
