Like Tree17Likes
Old 01-12-2016, 10:19 AM   #16981
Jeff Werner's Avatar
Trader Rating: 14 (100%+)
Send a message via Yahoo to Jeff Werner
With JP testing it I would imagine that is pretty good feedback to Durango to make those design changes. Kinda interesting that he built his Durango for the very first event running it in that layout.
Did notice Travis ran his in the more traditional layout.
Jeff
Jeff Werner is offline   Reply With Quote
Old 01-12-2016, 11:20 AM   #16982
Jeff
May TD is allready thinking about it, as the v3 body does have that edged and higher sides, to fit a shorty easyer!?
These are just my spaculations....
Greetings from Austria
Cat K2 / DEX410V3 / DEX410V5 / DEX210 / DEX210F / Cougar SVR /
YZ-10 '94/'95 WCS/
Spectrum DX3R
micholix is offline   Reply With Quote
Old 01-12-2016, 01:23 PM   #16983
Pittster's Avatar
Originally Posted by Pittster View Post
So I was looking through the Dex210F manual and thought it wouldn't be that hard to make the v2/v3 MM/RM Gearbox bolt to the 210F chassis and side pods. the front end is the same as a 210.
Why didn't durango just release the v3 this way ? it would of give the car a sideways shorty option? Like the b5m, 22 3.0. yz2 Rb6 etc etc
Seems like a missed opportunity for probably not alot of work.
Just doesn't seem to difficult that's all.
Part numbers are
210F chassis td320357
Sidepods TD320402
Im going quote myself here and say I think TD should either bring the 210F Chassis out with ability to mount the V3 Rear end on or like said above a revised Side Pod would be good also.
I have a Dimec20 Chassis I will probably modify for sideways shorty action won't be that difficult by the look of it.
Team Associated B6D, Speed Passion Reventon Pro 1.0, Hobbywing V10 7.5t
Team Associated B64D, Speed Passion Reventon Pro 1.1, Hobbywing V10 G2 6.5t
Team Associated B5M CE, Tekin Rs Gen2, Fleta ZX 17.5t
Pittster is offline   Reply With Quote
Old 01-12-2016, 07:24 PM   #16984
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Got V3 all wired up and took it for a little test run. I didn't have a stock motor to run so I had and 8.5 so put that in and setup the esc for mod. I put the wing on but new body isn't painted yet so I was pretty care running it on the track. Did a few laps and car was OK. Slipper was a little loose and had an off power push. Went back to my pit and switched tires and went to 30 degree caster. Went back out and wow my car was really dialed in. Car was easy to drive fast with a mod in so stock will even easier but overall was very impressed with about 30 laps I put in. Very good starting spot with it. Ran it 3 gear mid motor on a medium bite clay track.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 01-13-2016, 06:50 AM   #16985
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
I do like this wiring layout:
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 01-13-2016, 07:20 AM   #16986
wyd
Tech Legend
wyd's Avatar
Very nicely done. I ran my esc in front of the battery and my receiver on the right side pod. Not 100% if that is where I will keep mine or not but like the extra weight up front with my shorty servo.
Think I will move my shocks around to the rear of the car as well so I can use more adjustments on my shock tower. Do I need to do anything other than flip the a arms around and the hubs?
Old 01-13-2016, 07:22 AM   #16987
wyd
Tech Legend
wyd's Avatar
I tried the aluminum rear hubs but the inserts are about impossible to put in as they must of used too much anodizing on the hubs because if you do get the spacer in the hinge pins fit so tightly you can't free them up and if you want to change the the toe they need beat out and get ruined.
Old 01-13-2016, 07:33 AM   #16988
That's PUUUUURDY.
In and out of the hobby over the last 30 years
VINTAGE: Proud owner of an RC10 CE purchased waaay back in '92.
SORTA OLD: HPI RSR4 3 Evo nitro (hasn't been run in a long time).
MODERN: Durango DEX210v1. Rustler RTR purchased Feb '16 for my 5 yr-old daughter.
emerilnut is offline   Reply With Quote
Old 01-13-2016, 08:57 AM   #16989
That is a good looking buggy. The Viper esc and new Maclan motor looks good too. I know him and JP both run Maclan stuff.
Shocks on the back of the arms gives the buggy what?
Sweet how much life this thread has of late.....
Old 01-13-2016, 09:34 AM   #16990
OK, so I have this new (to me) DEX210 that I completely disassembled to fully clean all the parts. Gonna start reassembling it tonight.
Question.... should I set it up as mid-motor or rear-motor? It will mainly be for bashing on mixed terrain (asphalt, some grass, some tight packed dirt). I won't go racing much but if I do, the only place there is tight packed clay.
I'm thinking mid-motor since most of the driving will be on asphalt or tight packed clay?
Old 01-13-2016, 09:37 AM   #16991
wyd
Tech Legend
wyd's Avatar
Gives the rear of the car more traction overall plus allows to lay the shocks over without hitting the gear cover. I could only use the outer two holes on the tower but now I can use the other ones if need be.
Old 01-13-2016, 09:41 AM   #16992
Tech Legend
Cain's Avatar
I would say go with the mid motor setup as when bashing you probably don't care too much about having the overall best handling. And would be one less thing to change over when you try the track.
Depending on how much you like it, you could even pick up a second vehicle to server as your racer if yo uwant.
Old 01-13-2016, 11:18 AM   #16993
Kremzeek's Avatar
I thought I was the only one that hated the aluminum hubs. I'd love to hear if someone has a trick to get the inserts out without destroying them.
Kremzeek is offline   Reply With Quote
Old 01-13-2016, 11:23 AM   #16994
I tried quickly aluminium hubs on my V1 because stock parts were really too easy to break on landings. And then, my second V1 (one is MM for carpet, the other is RM for dirt) got alu hubs, then my DEST... And no more rear hubs breaking. Are V2 and V3 parts stronger?
Durango DEX 210 MM / Reedy Sonic 6.5 / HW V2.1 120A 1S
Durango DEX 210 RM / Savox 6.5 / HW V2.1 120A 1S
Durango DESC 210R / Reedy Sonic 10.5 / SpeedPassion Cirtix Stock Club Race
Tamiya F103GT / Reedy Sonic 10.5 / HW V2.1 120A 1S
FG Sportline 2008 (Formule France package) / Zenoah G230RC
DaTaz is offline   Reply With Quote
Old 01-13-2016, 11:35 AM   #16995
Kremzeek's Avatar
Not sure. I've never broken a rear hub. Only issue I've had is stripping out the screw holes on them but thats easy to fix with a longer ball stud and a nut.
St Ives RC Club B4Bandit Australian Racing 16561 Yesterday 03:54 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
