Like Tree23Likes
Old 01-09-2016, 11:11 PM   #16951
Laker67's Avatar
Trader Rating: 61 (100%+)
Originally Posted by micholix View Post
I've got a question, if i purchase a v3 kit, do i get a complete v2 and all the v3 parts, like front hubs, axels and the rear "multi" axels, ... are seperatly packt into the kit?
So i get like two different kind of rear axels, or are the v2 parts, they where updated not in the kit anymore?
Thx in advance
Everything from the v2 is in the kit along with the updated v3 parts in their own kit. So yep, everything all in one kit. It's pretty sweet!
Thanks to my sponsors: Maclan Racing, Addiction RC, Exotek, Jconcepts, Futaba, and Trakpower
Brian Jenkins
Local track: Addiction RC in Ogden, UT - AddictionRC.net
Laker67 is offline   Reply With Quote
Old 01-09-2016, 11:19 PM   #16952
Laker67's Avatar
Originally Posted by WallyRC View Post
Haven't tried that yet. Does the glue break down from the fumes? I saw someone on you tube soak half the wheel at a time?? Thanks for any help. Converting everything to 12mm and want to save my tires and foams. What do you guys recommend is the easier sir best way?? Thanks!!
Yep, the fumes will break down the glue. You can't do it anywhere cold either, it needs to be somewhere that's at least room temperature. If it's to cold it doesnt produce enough fumes to unglue the tire. They will usually get a little wet but the tire doesn't harden up like if you actually soak them. And after you hit with some tire sauce their usually good to go. With all that said, if you do it, do it at your own risk. I just have to put that on there.
Brian Jenkins
Old 01-09-2016, 11:34 PM   #16953
Laker67,
Thx for the answer!
So it would be a pretty good deal than, as the price is the same as the v2 was.
Greetings from Austria
Cat K2 / DEX410V3 / DEX410V5 / DEX210 / DEX210F / Cougar SVR /
YZ-10 '94/'95 WCS/
Spectrum DX3R
micholix is offline   Reply With Quote
Old 01-10-2016, 08:04 AM   #16954
Laker67's Avatar
Laker67,
Thx for the answer!
I think the car is a great deal, it's actually $30 cheaper then the v2. The v2 was $279.99 on tower before they went back ordered.
Brian Jenkins
Old 01-10-2016, 08:11 AM   #16955
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
+1 for a vehicle completely new in box, the V3 is a good deal for sure.
Anyone need yellow front DE Racing Durango style wheels? I got like tons of these new that I would never get to, and they are yellow where I usually get white or black.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 01-10-2016, 08:25 AM   #16956
performula's Avatar
whoops
performula is offline   Reply With Quote
Old 01-10-2016, 08:36 AM   #16957
Remeber, no matter what temperature a room is, that's room temperature.
In and out of the hobby over the last 30 years
VINTAGE: Proud owner of an RC10 CE purchased waaay back in '92.
SORTA OLD: HPI RSR4 3 Evo nitro (hasn't been run in a long time).
MODERN: Durango DEX210v1. Rustler RTR purchased Feb '16 for my 5 yr-old daughter.
emerilnut is offline   Reply With Quote
Old 01-10-2016, 10:49 AM   #16958
Devin's Avatar
Awkward timing for the dex210f. Released in the middle of carpet season. I like the engineering and idea behind it. Likely get it for for next year. Changing my current ride between indoor and outdoor during the spring is just too much time in that period due to work. Was going to buy a used dex210 for carpet only but this layout in intriguing. Can't wait to read some reviews until then.
Devin is offline   Reply With Quote
Old 01-10-2016, 11:24 AM   #16959
Laker67's Avatar
Haha touché, ok warm enough to get some vapor going. That should do it. Haha
Brian Jenkins
Old 01-10-2016, 11:40 AM   #16960
Laker67's Avatar
PM me on those wheels.
Brian Jenkins
Old 01-10-2016, 11:50 AM   #16961
I was thinking the same thing, even here in Canada where the indoor goes on until may, everybody has already a ride dialed for it.
They are either releasing it really late or really soon... For next season!
manumanrc is offline   Reply With Quote
Old 01-10-2016, 06:26 PM   #16962
Trader Rating: 235 (100%+)
Iam thinking of picking up a v3 kit really wanting to get back into some 10th scale
Er8sr is offline   Reply With Quote
Old 01-11-2016, 09:49 AM   #16963
The timing of the release is based on what projects they are doing in what order and when those projects get done. They did the DEX8/DESC10 first and released them. Then they did the DEX210V3, 210F, and 410V5 next. This is just where the timing fell once the projects were completed and parts were ordered. There's nothing weird about it. You can't just time big projects to coincide with some racing season somewhere.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 01-11-2016, 09:50 AM   #16964
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Got my V3 all built on Sunday. Just need add ESC and set it all up. Build wasn't too bad overall and went smoothly. One think I liked is the new orings in the shocks made my shocks much smooth than any other Durango shocks I have had. My previous 210 shocks where decent but with the purple o ring. The suspension feels really nice so once the motor and esc are in then will see what adjustments I need to make. Only hop up I would like down the road is to have alum. 12mm hexes for the V3. Plastic ones are ok but when and if they make aluminum ones I will be ordering some. The newer updated ball cups are a welcome addition vs the original ones that came in my original 210. These fit great and don't pop off when I make adjustments.
Hope to have time to get the new ESC in and make fine adjustments to the car. Final piece will be my body that is at my painters now.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 01-11-2016, 11:03 AM   #16965
did the original 210 have holes in the ballcups for easy adjustment of the ball screw?
St Ives RC Club B4Bandit Australian Racing 16564 Yesterday 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
