Like Tree26Likes
Old 01-04-2016, 01:44 PM   #16906
hey yall... Need some gearing advice on my DEX210. Its the RTR version... running a 9.5T Speedpassion motor... What pinion should I start off with?
Durango DEX210, Losi 22 2.0, XXX-SCT, XXXBK2, XXXT MF, XXCR
chadhertz is offline   Reply With Quote
Old 01-04-2016, 02:45 PM   #16907
Dino_D's Avatar
Originally Posted by tc5 man View Post
The Exotek 12mm Rear hexs work fine on the Dex210 but depending on what wheels you run it can make the axle stick out a bit much .
I use the proline B5 rims for the rear with the exotek hexes. If you use AKA the dish is flat but the axle and wheel nut is exposed. If you choose proline, the dish is coned, and concave to protect the axle and wheel nut. The AKA looks pretty but the proline is more practical. Your choice.
Not sure about the 2wd front yet, as the new car isn't out yet, but the 4wd buggy I use the 22-4 front rims on the 4wd.
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
Old 01-04-2016, 02:45 PM   #16908
Dino_D's Avatar
24T-25T depending on your track size.
Old 01-05-2016, 07:28 AM   #16909
Tech Legend
Cain's Avatar
Trader Rating: 234 (100%+)
Alright guys, I have a chance to get two dex210v2s with a variety of NIB spares for about $240, thoughts? Vehicles look to be in good condition, and may keep one to make a specific "mod" car or outdoor car, and other other a indoor car.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 01-05-2016, 09:32 AM   #16910
Laker67's Avatar
Trader Rating: 62 (100%+)
I say buy them! You figure your getting them for about $120 each its a really good deal. Even if you ran just one car and broke the other one down for parts your coming out way ahead of what it would cost to get all those spare parts on their own.
Thanks to my sponsors: Maclan Racing, Addiction RC, Exotek, Jconcepts, Futaba, and Trakpower
Brian Jenkins
Local track: Addiction RC in Ogden, UT - AddictionRC.net
Laker67 is offline   Reply With Quote
Old 01-05-2016, 10:39 AM   #16911
Tech Legend
Cain's Avatar
yeah, I was looking at the alloy rear hingepin block since my car doesn't have it, and for the money seems these could be a way to go.
I'll probably keep both these and sell my hybrid dex210 on the cheap.
Could also be more on spec with the latest shocks, etc.
Old 01-06-2016, 07:47 AM   #16912
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
New ride shows up today. No hurry to get it together as I'm not sure on what setup I will to go with anyways. Need to order some shock pistons as well.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 01-06-2016, 08:03 AM   #16913
Laker67's Avatar
Did you order the V3? I'm no Dino, but if I can help with set up high grip clay or carpet just let me know.
Brian Jenkins
Old 01-06-2016, 09:09 AM   #16914
Laker67's Avatar
I ran my V3 for the first time last night, and even though they didn't change much with the car I can tell you there is a difference in the way a fresh car feels. I ran the axles with the 65mm drivelines, went down to 35wt oil in the fronts from 37.5wt, and up one spring rate in the rear and the car was money! It rotated well in the corners, jumped great, and carried better corner speed then it did with my last carpet setup. All in all, I'm just spouting off at how great this car is! Even though its not the 210F this things is still a monster on the carpet and holds its own against the XB2, YZ2, KF2, and other carpet driven front motor cars!
Brian Jenkins
Old 01-06-2016, 09:41 AM   #16915
Trader Rating: 43 (100%+)
Yeah this new car is really good! Im running Travis setup from the Midwest champs minus the kyosho springs. I'm using a associated blue up front and green in the rear and the car is good. I tried Durango springs that are the same rate or very close to what the kyosho pink and gold were but the car was real unsettled so I went back to the ae springs till the kyoshos get here. I'm using associated offset wheels front and back with the exotek titanium front axles. Also running the 65mm axles, haven't tried other settings yet. What have you guys found that the shorter axle settings have done for you?
Brian Alderman is offline   Reply With Quote
Old 01-06-2016, 09:44 AM   #16916
Also does anyone have an opinion or tested the v2 body over the v3? Personally I like the looks of the v2 body better. My v3 body got cracked up pretty good and I haven't seen them in stock anywhere so looking for an alternative.
Old 01-06-2016, 12:13 PM   #16917
wyd
Tech Legend
wyd's Avatar
Thanks. Yeah I have a new V3 coming in today at Bumps and Jumps. I help the owner out a few days a week so with the new changes from the V1 to the V3 I thought I would give the new one a chance. It is a medium to high bite clay but since its pretty cold now I would say its medium traction right now. Not sure if I will setup the car in 3 gear MM for stock or 3 04 4 gear MM for mod. I see with most other brands everyone is going back to 3 gear MM for both stock or mod so will see.
Old 01-06-2016, 01:03 PM   #16918
Tech Legend
Cain's Avatar
yeah debating what to do for tranny gear setup as well, think I'll do the 3 gear and see, previous was 4 gear. it worked well enough in stock previously though but worth trying something different.
Depending what I hear back hopefully today, still debating maybe just getting a V3 to splurge on myself lol.
My big thing is that I prefer white wheels, and I got TONs of mounted tire sets and durango specific wheels here that came when I bought this package. And even funnier, most of them are indoor tire types with modeled foams, stuff I wouldn't use here lol.
Old 01-06-2016, 01:43 PM   #16919
Kremzeek's Avatar
Have you found the v2 in stock anywhere? Last time I checked, Tower was out.
Kremzeek is offline   Reply With Quote
Old 01-06-2016, 02:02 PM   #16920
Pittster's Avatar
So I was looking through the Dex210F manual and thought it wouldn't be that hard to make the v2/v3 MM/RM Gearbox bolt to the 210F chassis and side pods. the front end is the same as a 210.
Why didn't durango just release the v3 this way ? it would of give the car a sideways shorty option? Like the b5m, 22 3.0. yz2 Rb6 etc etc
Seems like a missed opportunity for probably not alot of work.
Just doesnt seem to difficult thats all.
Part numbers are
210F chassis td320357
Sidepods TD320402
Team Associated B6D, Speed Passion Reventon Pro 1.0, Hobbywing V10 7.5t
Team Associated B64D, Speed Passion Reventon Pro 1.1, Hobbywing V10 G2 6.5t
Team Associated B5M CE, Tekin Rs Gen2, Fleta ZX 17.5t
Pittster is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16570 Yesterday 03:48 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
