Like Tree43Likes
Old 12-22-2015, 12:28 PM   #16831
Kremzeek's Avatar
Originally Posted by WallyRC View Post
For those of you running gear differential, for indoor med to high grip (electrons are good tire). What weight are you running. I'm running 7000 in my DEST, and 10000 in DESC. Going to switch over the DEX, thinking 5000?
Opinions?
THANK YOU!!
I think a lot of it is personal preference. I have 5000 in my DEST and DESC and it works for my driving style. I went with 5000 in my DEX210 and it does push a bit so I'll probably drop down to 3000 the next time I rebuild my diff.
Kremzeek is offline   Reply With Quote
Old 12-22-2015, 12:53 PM   #16832
That's good info. Appreciate it. Might go in between and try 4000. Lol. Thanks!!
WallyRC is offline   Reply With Quote
Old 12-22-2015, 01:19 PM   #16833
What surface do u run on? Thanks
Old 12-22-2015, 02:08 PM   #16834
Kremzeek's Avatar
I run on ozite carpet in the winter. It's a tight, technical track so I need more steering than I would if I was outdoor.
Something I learned from (I think) Dino is that it can take a little while for the fluid in the diff to warm up. If I just throw my buggy down and drive, it handles different than it does after a few laps. Sometimes I'll even hold onto one of the rear wheels and run it at say 1/4 throttle just to get the fluid moving.
Old 12-22-2015, 02:50 PM   #16835
I remember reading that. I am on indoor clay/dirt mix. Med to high bite depending on watering level. With colder winter I think I might go with 3000 as well. Should lower my other cars for winter as well. Thanks!!
Old 12-22-2015, 03:37 PM   #16836
Default Front shock tower
Can some one give me the measurements on the front shock tower mounting holes of the dex210 2wd buggy .. I am looking to fix a Basher for my kid and I think it looks pretty close any help would be great thanks
ecoastrc is offline   Reply With Quote
Old 12-24-2015, 11:05 AM   #16837
Anyone help me ??!
Old 12-24-2015, 11:40 AM   #16838
tc5 man's Avatar
Yea I've noticed that with the diff oil on clay with Med traction to semi high is that if you go thicker than 3k it takes really . 2 laps at least or so before it warms up and gets constant . So I would stick with 2k to 3k .
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
Old 12-24-2015, 01:35 PM   #16839
Anyone help me ??!
Hello ecoastrc,
I dont know exactly, what messurements you need, but the distance between the thread holes left to right is 26 mm and the distance between the upper and lower hole is 14 mm.
Hope that helps?
Greetings from Austria
Cat K2 / DEX410V3 / DEX410V5 / DEX210 / DEX210F / Cougar SVR /
YZ-10 '94/'95 WCS/
Spectrum DX3R
micholix is offline   Reply With Quote
Old 12-24-2015, 11:42 PM   #16840
Thanks TC5.
To you and everybody else: if you are running the plastic internal gears which lowers the rotating mass do u think you should go with lighter oil as well than you would with the metal ones?
Old 12-24-2015, 11:57 PM   #16841
tc5 man's Avatar
Thanks TC5.
I use the plastic gears with them being lighter im not sure actually you would think heavyier oil with them. If so about 4K is good i haven't ran the metal gears for a while but.
It may actually help more the metal gears with mod motor so it doesn't spool up so fast easyier to get on the power .
Old 12-26-2015, 12:56 PM   #16842
We have a new ozite track coming our way. What tires are best for this surface?
blankenj99 is offline   Reply With Quote
Old 12-26-2015, 07:32 PM   #16843
Kremzeek's Avatar
See if they allow foam tires. I recently picked up a set from Gone Bananas Racing and really like them. They wear well and have plenty of traction.
Before that, I was using Pro-line Pinpoints and Wedges. I liked the Pinpoints, but wasn't real happy with the Wedges. I was going to switch to carpet tires from Schumacher or Dboots but went with foams instead.
Old 12-27-2015, 05:14 AM   #16844
We used to run ion's on the ozite, but it would eat the treads off the tires in about 2 nights worth of racing.
I would try primes... I think they would hook up well on the rear. you could try Panther slicks, but I don't think they will be near as good as the primes.
For the front, I used to run dboots blockpass... they worked very well. Any kind of stagger rib or "carpet hook" front tire seemed to work good.
Durango DEX210, Losi 22 2.0, XXX-SCT, XXXBK2, XXXT MF, XXCR
chadhertz is offline   Reply With Quote
Old 12-27-2015, 05:54 AM   #16845
Thanks for the help!
St Ives RC Club B4Bandit Australian Racing 16581 Yesterday 03:23 PM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
