Like Tree28Likes
Old 12-20-2015, 01:41 AM   #16816
Originally Posted by TRF415boy View Post
The V2 (and V3) have both shorter shock bodies and shock shafts.
Yes, i do know, but the shorter v2(3) shocks and shafts does only compensate the higher mounting point from the v2 arms, to the v1's, not the problem of the max. uptravel.
Try to bottom out your 210 and try to lift your weel untill your shock stop it, there is only a fiew mm, if at all.
Greetings from Austria
Cat K2 / DEX410V3 / DEX410V5 / DEX210 / DEX210F / Cougar SVR /
YZ-10 '94/'95 WCS/
Spectrum DX3R
micholix is offline   Reply With Quote
Old 12-20-2015, 05:10 PM   #16817
Tech Legend
Cain's Avatar
Trader Rating: 235 (100%+)
okay so to confirm, I only need the shorter shock shafts from the V2 shocks in my V1 bodies, and then look at the stop on the shocks, possibly remove or use a thinner oring for up travel.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL | Yokomo YZ-2 DTM x 2>
Old 12-20-2015, 05:19 PM   #16818
I'm using the titanium 44 mm (V1) in the V2 bodies. If you are not using bladders and using emulsion they work fine. No need to order the 42.5mm ones. I switched out the rubber shock stopper and used orings. Like someone else stated. Gives u a few more mm of uptravel.
I think Fred is on to something I have yet to try. Use the DESC/DEST front shock tower and the V2 rear shocks up front. (31mm stroke and 52mm shaft). Use stiffer rear springs or the white series rear springs up front to fit your correct compression. This will allow for more uptravel.
"OR" maybe somebody could design a new front tower that was a little bit higher and we could use the v1 version front shocks? Fred? This should give us the down travel we want and up travel.
WallyRC is offline   Reply With Quote
Old 12-20-2015, 10:52 PM   #16819
I think if u are using the v1 front shock bodies they are slightly longer than the v2. This would limit your uptravel even more. I could be wrong though.
Old 12-21-2015, 01:57 PM   #16820
Tech Legend
Cain's Avatar
gotcha. I'll probably just stick with the v1 a-arms then unless something becomes a prob.
Old 12-21-2015, 09:18 PM   #16821
Default What weight Diff oil?
For those of you running gear differential, for indoor med to high grip (electrons are good tire). What weight are you running. I'm running 7000 in my DEST, and 10000 in DESC. Going to switch over the DEX, thinking 5000?
Opinions?
THANK YOU!!
Old 12-21-2015, 09:44 PM   #16822
Laker67's Avatar
Trader Rating: 63 (100%+)
I run 10,000 in my 2wd cars on high bite carpet. I'm probably going to go down to 7,000 and see if it helps with my on power steering.
On a side note, I got the new V3 today! Gonna get it built when my parts order shows up this week. Im excited for a fresh car.
Thanks to my sponsors: Maclan Racing, Addiction RC, Exotek, Jconcepts, Futaba, and Trakpower
Brian Jenkins
Local track: Addiction RC in Ogden, UT - AddictionRC.net
Laker67 is offline   Reply With Quote
Old 12-21-2015, 09:52 PM   #16823
Thanks for info...
Love the V3 sticker instead of a new box..LOL.
Old 12-21-2015, 10:38 PM   #16824
Laker67's Avatar
Originally Posted by WallyRC View Post
Thanks for info...
Brian Jenkins
Old 12-22-2015, 03:06 AM   #16825
Trader Rating: 21 (100%+)
Going with the sticker is a bit odd. They could have at least put it over the V2....lol
AE B6
AE B64
kerby is offline   Reply With Quote
Old 12-22-2015, 07:24 AM   #16826
Tech Legend
Cain's Avatar
yeah, I wouldn't be surprised that when the v2 went discontinued they probably just needed to open up the boxes and chuck in the right packages.
honestly it doesn't give the feel of a new version. Might as well called it the V2.1 at that point.
Still love the car though.
Old 12-22-2015, 07:33 AM   #16827
Probably did it to use existing stock. Later runs will probably be V3 specific.
blankenj99 is offline   Reply With Quote
Old 12-22-2015, 07:39 AM   #16828
Tech Legend
Cain's Avatar
for those in the know, am I correct that AE's 69T spur gear is the same as the kimbrough ones that are mentioned to be used with the exotek locker? they look the same on towers site so I ordered some as they were cheaper than the official kimbrough ones. So curious if anything diff.
Old 12-22-2015, 08:21 AM   #16829
Laker67's Avatar
As long as its the spur for the TC3/4 touring car it should work the same.
Brian Jenkins
Old 12-22-2015, 08:23 AM   #16830
Laker67's Avatar
I think that I got one of the first to hit towers shelves. I'm sure they will revise the box later in the year. If not its what's in the box that matters.
Brian Jenkins
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
