Like Tree23Likes
Old 12-16-2015, 11:29 AM   #16801
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
Is tehre anyone else interested in ordering a +8mm Plan B chassis? Could be interested but as he said he needs 5 orders.
If not, I may just order the stock one.
Also, what are some of the common hop ups you guys are using for 17.5 blinky? seen a few things like aluminum axles, even a lightened motor plate that looks like swiss cheese lol.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 12-16-2015, 07:20 PM   #16802
I have the chassis he sells, whatever size it is, and it's great and it weighs in at 1505 with a shorty and nothing else to save weight. Just buy it, you will like it
Tim
Tdub77 is offline   Reply With Quote
Old 12-17-2015, 11:11 AM   #16803
Dino_D's Avatar
Sure you can spend hundreds getting all things aluminum and titanium. But aluminum is heavier than plastic.
Quickest way to lighten your car is to use a low-profile shorty lipo or super shorty lipo. Also you can move the weight around in the car to get more tuning as you need as these packs are 3200mah+ which is more than enough for stock.
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
Old 12-17-2015, 12:29 PM   #16804
Tech Legend
Cain's Avatar
True. I am thinking for thinking that are naturally lighter than the stock stuff, so for example, the top shaft and steel axles.
Old 12-17-2015, 03:50 PM   #16805
Kremzeek's Avatar
Looks like the DEX210v3 is in stock over at Tower. Only $220 with coupon code.
No new parts like the hexes and rear axles though.
Kremzeek is offline   Reply With Quote
Old 12-17-2015, 05:11 PM   #16806
Tech Legend
Cain's Avatar
went ahead and ordered the chassis. Looking forward to it!
What do you guy recommend for tranny setup, 3 gear or 4 for stock with it, assuming carpet for now. Also, gear or ball diff?
as for lightening parts, I am thinking the following:
- Exotek direct spur mount
- Exotek Flite top shaft
- Durango Lightweight gear diff outdrives
I was considering the aluminum axles as I have tons of durango wheels, but was wondering if they are worth getting for stock only or are they just not durable, seen some reports but curious if anyone heard anything recent.
Old 12-17-2015, 11:31 PM   #16807
I would recommend the molded cross shafts and gears for your gear diff. Part #TDR310290. They are very durable and lighten it up.
I only run 3 gear, and I heard that it is best for stock. I tried four but the car gets a little too much weight transfer. But if your on high traction carpet it may be worth trying.
The rest of your list sounds good.
Let us know how it all goes with the plan b. I'm really curious.
WallyRC is offline   Reply With Quote
Old 12-18-2015, 06:42 AM   #16808
I used to run my dex210 on ozite carpet... everyone was running 4 gear mid motor... Car was absolutely dialed on ion's in the rear and a carpet hook front tire.
chadhertz is offline   Reply With Quote
Old 12-18-2015, 06:52 AM   #16809
Tech Legend
Cain's Avatar
Thanks ordered!
I'll post what I find. The plan b owner is really cool, was willing to answer some questions for me.
Right now the big debate I am having is if I want to stick with my gull wing a-arms or go to the straight fronts. I have basically the V1 a-arm and shock setup here, but do have the V2 tower as well as a graphite tower but not sure what it aligns as.
Old 12-18-2015, 08:24 AM   #16810
The only difference between the V1 and V2 front towers is the V2 tower is offset a little more rearward. The shock bottom eyelets install in the arm with the longer side on the back on a V1. You just turn this around on a V2 so the shock sits slightly farther back on the arm. The problem with this is that at the extreme limits of steering, the inside link may come into contact with the shock. May, being the key word. You could run the V2 front tower with your current V1 setup. Just reverse the bottom shock mount on the arm. The V2 arms is one thing that I do personally prefer over the V1.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 12-18-2015, 08:52 AM   #16811
Tech Legend
Cain's Avatar
I run the V2 tower right now, rest V1.
what about V2 a-arms, still need to get the V2 shocks or do something else?
Old 12-18-2015, 09:35 AM   #16812
re-do73's Avatar
the only difference is the v2 front shock shafts are slightly shorter to make up for the flat arm.
PLAN B RACING custom chassis conversions and accessories
for more info visit:
https://www.facebook.com/planbrc
re-do73 is offline   Reply With Quote
Old 12-19-2015, 10:28 AM   #16813
Tech Legend
Cain's Avatar
cool thanks. so just order shorter v2 shock shafts or limit the downtravel of the v1 shocks I am assuming will do it.
Old 12-19-2015, 11:52 AM   #16814
The v2 shafts doesn't solve the problem, they limit just the maximum of droop/downtravel.
The main problem is the uptravel even with v1 arms, shocks and towers the uptravel is to low!
If you try it and push the front down to pottom out with the chassis und try to lift the weel from the ground, it would not, or just a tiny bit off of the ground.
I have a v1 and what i did, to solve the problem was, i swiched the stopper with an old shock o-ring, that gave me a fiew mm more lift off of the front weel.
Greetings from Austria
Cat K2 / DEX410V3 / DEX410V5 / DEX210 / DEX210F / Cougar SVR /
YZ-10 '94/'95 WCS/
Spectrum DX3R
micholix is offline   Reply With Quote
Old 12-19-2015, 02:28 PM   #16815
TRF415boy's Avatar
The V2 (and V3) have both shorter shock bodies and shock shafts.
TRF415boy is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 Today 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
Dopkal
