Like Tree23Likes
Old 11-17-2015, 07:38 PM   #16681
Kremzeek's Avatar
Originally Posted by WallyRC View Post
Look at the Dex210 setup pages on petit RC. Look for "front hexagon" modification, it shows step by step how to modify the front with Kyosho rb5/6 axles that are 12 mm. There is a link on page 729 of this thread Exotek also makes the front axle with hexes built in. Think they are titanium.
For the rear Jconcepts or Proline b4.1 hexes work from what I have read. I believe you need to cut the pin a little smaller to fit the 12mm modification. Might need a few shims. The B5 rear hexes I hear work as well. Was somewhere in this thread.
Good luck.
Thanks for the info over at petitrc. It looks like you need to shim/spacer the heck out of those axles to get them to work. I thought I read over here that the B5 axles were a straight drop in? If not, I may just suck it up and order the Exoteks.
I should really find out what wheels the local foam tire supplier is using and whether or not he can glue up a set on Durango wheels.
Kremzeek is offline   Reply With Quote
Old 11-18-2015, 09:32 AM   #16682
Yes the B5 axles fit but the offset is a little different.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 11-18-2015, 11:50 AM   #16683
Laker67's Avatar
Trader Rating: 61 (100%+)
I ran the B5 axels on my last 210v2 and they worked fine. They make two different versions, one with the hex cast onto it and one that you use the slide on hex. I would probably make sure that I get the axle that has the built in hex this go around. Last time I used the slide on Jconcepts hexes and I went through a few front bearings by over tightening the front wheel nuts.
Thanks to my sponsors: Maclan Racing, Addiction RC, Exotek, Jconcepts, Futaba, and Trakpower
Brian Jenkins
Local track: Addiction RC in Ogden, UT - AddictionRC.net
Laker67 is offline   Reply With Quote
Old 11-18-2015, 07:47 PM   #16684
Hi guys,
I am planning to convert my v2 to a 3gear mid mount. I am running on a medium grip outdoor track, about an average of 25 secs per lap so I am guessing it's a small track compared to many of you here.
I understand that the v2 is able to mount the rear shocks either in the front or rear position. My question is, how would it affect the handling of the buggy with either settings?
darkdays is offline   Reply With Quote
Old 11-18-2015, 08:21 PM   #16685
303slowdown's Avatar
Trader Rating: 21 (100%+)
Originally Posted by darkdays View Post
Hi guys,
In my experience shocks on the rear of the arm give more rear traction compared to shocks mounted on the front .
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 11-19-2015, 11:39 AM   #16686
Default Crush tube
Guys,
Make sure if you are doing the front axle conversion to hex you put the crush tube between the bearings.
TDR712003 is the part number. Pack of two. One in each side. No more binding, wheels spin free and no damage to bearing. No more loose wheel nuts.
Wally
WallyRC is offline   Reply With Quote
Old 11-19-2015, 04:54 PM   #16687
Kremzeek's Avatar
Guys,
Wally
You'll probably want to jam a few 5x7mm shims in there as well. That's what people do with their DEST/DESC trucks.
Old 11-19-2015, 06:45 PM   #16688
Kremzeek's Avatar
I know this has been asked before, but does anyone have a good setup for carpet?
Old 11-19-2015, 08:47 PM   #16689
Laker67's Avatar
I have a good one that I'll try to compress and put in here tomorrow.
Brian Jenkins
Old 11-20-2015, 09:44 AM   #16690
Default Forgot to mention
Right on, forgot to mention that. Kyosho has a nice pack that has .1, .2, .3 shims. Start small work your way up. If you crank down your wheel nut and it doesn't spin freely, it's binding. Add more shim until it doesn't bind. Good to add a few shims to the rear as well. Read first page in DESC thread. It explains the whole process.
Happy Thanksgiving Everyone!!
Old 11-23-2015, 02:09 PM   #16691
Laker67's Avatar
Here is a link to my Carpet setup:
https://www.dropbox.com/s/8vdq4uik3d...210V2.pdf?dl=0
Brian Jenkins
Old 11-25-2015, 06:58 PM   #16692
Kremzeek's Avatar
Thanks Laker!
Old 11-25-2015, 08:14 PM   #16693
Come on Durango, Im starting to lose interest in your brand. All the other brand have released new cars (or at least images of what's coming and when) . You have till the end of the month and I'm jumping ship.
Ryan Borgheiinck
Old 11-25-2015, 09:13 PM   #16694
tc5 man's Avatar
You think that is bad try HB with releasing new cars lol.
Its been two years for them designing it and not coming out intill next year whenever that is .
Honestly though the B5M Champ Ed is mostly just the upgrades added no different chassis or anything .
22 3.0 looks the same as the B5M really but redesign from the 2.0 .
This buggy Dex210 V2 is still just as competitive though with the others pending driver i still do fine with it .
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
Old 11-26-2015, 04:08 AM   #16695
I think that there is coming dex210v3 and dex410v5 because those web addressed is reserved
So pages are there but you dont have permission to see it
http://www.team-durango.com/race-cars/dex210v3/
http://www.team-durango.com/race-cars/dex410v5/
Bigbearfin is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16563 Today 04:32 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
