Like Tree33Likes
Old 11-06-2015, 09:55 AM   #16666
tc5 man's Avatar
Originally Posted by ekt View Post
The gear diff is wide enough to not need them.
Oh ok thanks im running it on high traction clay and carpet .
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
Old 11-06-2015, 07:11 PM   #16667
Devin's Avatar
My MIP 1.3 mm wrench came in, winched up those gear diffs, looks good. No spacer shim on out drive feels correct, thanks for the tip guys.
Also, reading carpet setups on Petit RC, many mentions of max droop. Do you think they actually mean max droop or max limited I.e. Screw all the way in.
Devin is offline   Reply With Quote
Old 11-06-2015, 10:50 PM   #16668
tc5 man's Avatar
I'm not sure about max droop on carpet . But im assuming they are talking about limiting the droop just having the screws touch the plate pads will proberty work fine.
Old 11-06-2015, 11:41 PM   #16669
Laker67's Avatar
Trader Rating: 63 (100%+)
I run full droop on our carpet track. I think it helps since we run such low ride heights to help soak up the landings of the jumps. If you limit it to much and are running between 17-19mm ride height and over shoot a jump it will be very unsettled on landing.
Thanks to my sponsors: Maclan Racing, Addiction RC, Exotek, Jconcepts, Futaba, and Trakpower
Brian Jenkins
Local track: Addiction RC in Ogden, UT - AddictionRC.net
Laker67 is offline   Reply With Quote
Old 11-07-2015, 01:07 PM   #16670
Send a message via MSN to TurboT
Further to Chris Doughty's comments about the DEX210v2 being ahead of its time, I'm still running my 210v1 on carpet and it is still an amazing machine. The 3-gear/4-gear MM/RM tunability is an awesome feature. I found I was losing just a little too much steering with the 4-gear MM and switched it to 3-gear MM. Night and day difference. The car now stays very flat on-power, so I don't lose steering, especially in the slower sections. The adjustability is really second to none.
The 210F has me very excited, though. I can hardly wait to get one, as I'll be running carpet and turf until May, probably.
As for the 410v5, I'm still running an upgraded 410R, lol. It is pretty much a v4 except for the 19 degree hubs and u-joints, but it has been a rock-solid machine and still competes extremely well with all the current offerings. I'm more excited to get a 410v5 just so I can finally build a completely fresh car!
Awesome things coming for us all from TD!
Team Great Hobbies
Team Durango Canada
Exotek
TurboT is offline   Reply With Quote
Old 11-07-2015, 08:29 PM   #16671
Default Steering Mod?
Micholix ,
Did u ever finish the steering mod, did it work out? Just curious.
Wally
WallyRC is offline   Reply With Quote
Old 11-07-2015, 09:54 PM   #16672
Originally Posted by WallyRC View Post
Micholix ,
Wally
Sorry not yet Wally, but i will by the time!
I'll post some pics, when i do have time to work on further.
Greetings from Austria
Cat K2 / DEX410V3 / DEX410V5 / DEX210 / DEX210F / Cougar SVR /
YZ-10 '94/'95 WCS/
Spectrum DX3R
micholix is offline   Reply With Quote
Old 11-10-2015, 09:11 PM   #16673
tc5 man's Avatar
Originally Posted by micholix View Post
Hi darkdays,
Where exaktly does it leaking?
You can sand the diff housing with some 600-1000 sandpaper laying on a flat surface and try the purple, or blue 3x2 TD o-rings, instead of the stock red one, this schould help and Will give you a leakfree diff.
The Blue shock O-Rings for the Dex210V2 in the gear diff ? I been using the Black diff seals and my leaked a decent amount also.
Old 11-10-2015, 09:30 PM   #16674
Hi tc5 man,
Sorry, i did mean the shock o-rings from the 1/8 scale durangos, they have a diameter 4x2 mm!
YZ-10 '94/'95 WCS/
Spectrum DX3R
Old 11-10-2015, 09:40 PM   #16675
tc5 man's Avatar
Hi tc5 man,
No its the Blue shock O-rings for the Dex210 and Dex410 is that the ones you can use in the Gear diff ?
Old 11-10-2015, 10:05 PM   #16676
You cant us the shock o-rings from the 1/10 scales for the diffs, as they are 3x2 mm, they are to small.
YZ-10 '94/'95 WCS/
Spectrum DX3R
Old 11-10-2015, 10:58 PM   #16677
Default Need 4x2mm P4 for differential.
Micholix is right. Need P4 size o rings for the differential.
TDR330099 Orange orings work well too. I haven't tried the blue ones.
Old 11-16-2015, 01:01 PM   #16678
Kremzeek's Avatar
What's the best way to convert the DEX210 over to 12mm hexes? B5 front axles and Exotek hexes on the rear? Is there anything else other than the Exotek hexes? I have their 14mm hexes on my wife's buggy and I hate them.
Kremzeek is offline   Reply With Quote
Old 11-16-2015, 04:44 PM   #16679
tc5 man's Avatar
I actually just keep the Front stock axles one reason is i have a butch of the Durango Front wheels. On the Rear to 12mm hexes Exotek makes are fine they do make the wheelbase a little more narrower .
The B4.1 Proline Rear hexes are wider but it depends on the wheels you use though i noticed with the wheelbase on both hexes.
Old 11-17-2015, 02:30 PM   #16680
Default Other options
Look at the Dex210 setup pages on petit RC. Look for "front hexagon" modification, it shows step by step how to modify the front with Kyosho rb5/6 axles that are 12 mm. There is a link on page 729 of this thread Exotek also makes the front axle with hexes built in. Think they are titanium.
For the rear Jconcepts or Proline b4.1 hexes work from what I have read. I believe you need to cut the pin a little smaller to fit the 12mm modification. Might need a few shims. The B5 rear hexes I hear work as well. Was somewhere in this thread.
Good luck.
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
