Like Tree43Likes
Old 10-13-2015, 10:19 PM   #16591
Tc5 man,
Why would you like to change?
I think, there is no problem to use the stock silver/chrome shock shafts.
I do polish all my shock shafts a little bit and use the purple or blue TD, at the moment i have the white Revolution Design 3x2 mm shock o-rings and they run all buttery smoth.
If you run on dirt and you shafts get marks on it, it would be better to protect them with the TD shock boots, otherwise you are fin with the stock on.
Greetings from Austria
Cat K2 / DEX410V3 / DEX410V5 / DEX210 / DEX210F / Cougar SVR /
YZ-10 '94/'95 WCS/
Spectrum DX3R
micholix is offline   Reply With Quote
Old 10-13-2015, 10:56 PM   #16592
tc5 man's Avatar
[QUOTE=micholix;14222613]Tc5 man,
If you run on dirt and you shafts get marks on it, it would be better to protect them with the TD shock boots, otherwise you are fin with the stock on.[/QUOTE
Mostly because the stock ones get scratched easy and they get a notchy feeling until they get pumped up more than there smooth . I actually got the gold coated rear ones but not sure why they don't make the same for the Front shafts.
I actually dint know Durango made boots for this buggy .
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
Old 10-13-2015, 11:22 PM   #16593
Shock boots for the rear are #TD330017, and for the front are #TD330018.
If your shafts get scatched easily, you should change the plastic shock bottom cartridge as well, they have the #TD330011.
YZ-10 '94/'95 WCS/
Spectrum DX3R
Old 10-14-2015, 07:36 AM   #16594
Dino_D's Avatar
[QUOTE=tc5 man;14222652]
Originally Posted by micholix View Post
Tc5 man,
The gold ones were for the Dex410v3 buggy, also an option for the original dex210. The v4 uses black ones, still no idea why they didn't make coated ones for the Dex210v2 for the front.
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
Old 10-15-2015, 09:52 AM   #16595
Default Steering Modification!
Hello everyone,
Here is an update of my steering modification!
Bumpsteer is allready elliminated and the whole asambling works just fine.
I allso have allready an idea, how and where to mount the servo, but have to buy a sevo mount before i can work on further.
YZ-10 '94/'95 WCS/
Spectrum DX3R
Old 10-15-2015, 09:53 AM   #16596
... One more picture.
YZ-10 '94/'95 WCS/
Spectrum DX3R
Old 10-15-2015, 09:54 AM   #16597
... And the last one.
YZ-10 '94/'95 WCS/
Spectrum DX3R
Old 10-15-2015, 10:49 AM   #16598
Default I'm using 44 mm no problem
My son snapped the stock 42.5 mm front shock shaft first day out and all they had were the yellow TiN 44 mm V1 models in stock. I put those in with no problems, the shock body had plenty of room. If u are running shock bladders may not work.l?!?!
Also been using combo of purple and blue O-rings, firmer one on outside, can't remember but I believe purple. Has worked great for me.
Happy RC'ing
Originally Posted by tc5 man View Post
I noticed that the Durango V4 4wd Buggy has the Black coated shafts on the shocks . Will they fit on the Dex210 V2 ? I'm looking for coated Front shock shafts.
WallyRC is offline   Reply With Quote
Old 10-19-2015, 01:37 PM   #16599
Default Bent Almuminum Chasis
Anybody else having issues with the aluminum bending down at the Chasis where the rear droop screws hit in the rear. I just redid my rear shocks and added 3 mm of limiters. Mine would keep bending down and causing the droop to be unequal.
Anyone go to the Dimec20 Chasis instead of aluminum and like it? I race mainly indoor clay, med-high. Electrons or similar are good tires.
Old 10-19-2015, 04:43 PM   #16600
Default Ball cups and turnbuckles
Just curios what turnbuckles and ball cups are u using? Asking a few guys to get ideas.
Old 10-19-2015, 04:58 PM   #16601
Trader Rating: 101 (100%+)
You can use the stock turnbuckles with the associated 5 series ball cups and studs. I am running this on my dex210, and it takes the slop out that I had with the stock durango cups. Plus I have had zero issues with them popping off. Also, I noticed with the offset associated cups I have a stronger pull on the inside wheel to keep it tighter at full lock.
ricerscott is offline   Reply With Quote
Old 10-19-2015, 08:39 PM   #16602
Hi Wally, these are lunsford titanium tunbuckles, ball cups and titanium ball studs, actually it was a complete set for the dex210, i was lucky my lhs had them "for sale" for € 60,-! ;o)
Here is the link to the lunsford side:
http://www.lunsfordracing.com/mm5/me...e=CARS-DDEX210
YZ-10 '94/'95 WCS/
Spectrum DX3R
Old 10-19-2015, 11:04 PM   #16603
tc5 man's Avatar
Happy RC'ing
I just ordered a pair of the Gold Front 44mm shock shafts so they fit the Dex210 V2 Front shock bodies fine ? Do you need to switch to shorter shock rod ends since there longer ? I'm going to use the rubber stoppers on the shafts still on them .
I would think the ride height would need to be readjusted also.
Old 10-19-2015, 11:38 PM   #16604
The only thing the longer shaft will do is give you more droop, if your droop screws are adjusted where you want them now just leave them some, just leave it alone. Make sure you clean the shaft where the screw goes that holds on the piston, use a little dab of blue lock tite, and let it dry overnight.
Good to go..
Old 10-21-2015, 02:14 PM   #16605
Default Anyone???
Bump Anyone!!!
St Ives RC Club B4Bandit Australian Racing 16574 11-04-2017 02:55 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
