Like Tree23Likes
Old 10-10-2015, 09:40 PM   #16576
Originally Posted by Laker67 View Post
I've been runnin my v2 on carpet for a bit now and have a pretty good setup for high grip carpet. If you need any help just let me know.
Laker67, thanks for your offer about setup, but i will run a different layout on my 210, as i changed and will be changing quit a bit on my chassis, so i have to find my own one, just one question, do you think a gear diff is better for carpet?
Greetings from Austria
Cat K2 / DEX410V3 / DEX410V5 / DEX210 / DEX210F / Cougar SVR /
YZ-10 '94/'95 WCS/
Spectrum DX3R
micholix is offline   Reply With Quote
Old 10-11-2015, 04:32 AM   #16577
BYC
Hi Laker67, I would like to know your setup for carpet. Can you share please?
BYC is offline   Reply With Quote
Old 10-11-2015, 05:33 AM   #16578
Default What do you think?
Hi guys,
What do you think about that modification?
I still have to figur out, where and how to place the servo and about the high of the ackermann plate, to eliminate bump steer, but till there, it was a direkt fit to the dex210 mounting plate and it is now a fully ball raced steering asambling, without those bushings, that are running in the plastic armes and i have lowered the cg, because i will lay the servo down to the chassis and bring some weight away from the front, as the servo will go back by around 15-20 mm!
YZ-10 '94/'95 WCS/
Spectrum DX3R
Old 10-11-2015, 05:34 AM   #16579
Sorry, i can only upload one pic by post, with my ipad.
YZ-10 '94/'95 WCS/
Spectrum DX3R
Old 10-11-2015, 05:36 AM   #16580
... And one from the side!
YZ-10 '94/'95 WCS/
Spectrum DX3R
Old 10-11-2015, 09:46 AM   #16581
Kremzeek's Avatar
Me too.
Kremzeek is online now   Reply With Quote
Old 10-11-2015, 10:23 AM   #16582
Laker67's Avatar
Trader Rating: 61 (100%+)
I've got a few family thing to do today but ill get a setup sheet filled out and posted up in a bit.
Thanks to my sponsors: Maclan Racing, Addiction RC, Exotek, Jconcepts, Futaba, and Trakpower
Brian Jenkins
Local track: Addiction RC in Ogden, UT - AddictionRC.net
Laker67 is offline   Reply With Quote
Old 10-12-2015, 06:58 PM   #16583
Default Picture when done
Micholix,
That looks pretty interesting. Curious to see how it turns out. What rack is that from?
Post a pick with your step by step and one when its done.
Wally
WallyRC is offline   Reply With Quote
Old 10-12-2015, 08:21 PM   #16584
Kremzeek's Avatar
I made the mistake of picking up some DE Racing wheels for carpet racing. I didn't realize that the inner ribs were lower than the outer ones. When you put on narrow carpet tires, the outside sits higher than the inside so the tire surface is on a bit of an angle. I went back to the stock yellow wheels and everything fits fine.
Old 10-12-2015, 09:02 PM   #16585
Devin's Avatar
Petit RC setups for gear diff on carpet are mixed between 5 and 7 k oil. I am going blind into the exact carpet surface, would one be easier to drive than the other?
Devin is offline   Reply With Quote
Old 10-12-2015, 09:05 PM   #16586
tc5 man's Avatar
I noticed that the Durango V4 4wd Buggy has the Black coated shafts on the shocks . Will they fit on the Dex210 V2 ? I'm looking for coated Front shock shafts.
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
Old 10-12-2015, 10:29 PM   #16587
Originally Posted by WallyRC View Post
Micholix,
Wally
Hi Wally,
Up front, this is a steering set from the b5 #91391. The distance between the two steering arms/ steering bellcrank brace is exactly the same as dex one, so if things turn out good, you can use the aloy hop up steering from AE, or any aftermarket one.
I'm happy to do some step by step, if things go well...
YZ-10 '94/'95 WCS/
Spectrum DX3R
Old 10-12-2015, 10:50 PM   #16588
The rear shock shaft is the same length, as the 410 buggy one, but the front once will only fit/be the same as the 210v1 shafts, because the v2 uses shorter shock bodys and shafts.
Here's a little chart:
Rear shock bodys all 210/all 410: 31 mm stroke
Rear shock shafts all 210/all 410: 52 mm
Front shock body 210v1/all 410: 23 mm stroke
Front shock body 210v2: 21.5 mm stroke
Front shock shaft 210v1/all 410: 44 mm
Front shock shaft210v2: 42.5 mm
YZ-10 '94/'95 WCS/
Spectrum DX3R
Old 10-13-2015, 03:53 PM   #16589
tc5 man's Avatar
Ok so i can use the Rear shock shafts from the V4 4wd buggy on the Front Dex210 V2 shocks ?
Old 10-13-2015, 07:30 PM   #16590
ekt
ekt's Avatar
The DEX410 rear shock shafts will fit the rear of the DEX210v2.
The fronts are a different length, so no coated shock shafts.
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
banx
