Like Tree24Likes
Old 09-22-2015, 09:44 AM   #16531
Kremzeek's Avatar
Originally Posted by micholix View Post
I'm not sure, i thought, it was always the front motor car?
We will see, what's comming up... ;o)
Maybe? I might have bought into the speculation that it was an LCG car..
Kremzeek is offline   Reply With Quote
Old 09-23-2015, 05:26 PM   #16532
tc5 man's Avatar
Can you use the B4.1 ball diff in the DEX210 v2 ? What mods are needed is it a direct drop in ?
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
tc5 man is online now   Reply With Quote
Old 09-24-2015, 06:19 AM   #16533
Super Moderator
Trader Rating: 17 (100%+)
what's the preferred method of switching to 12mm front hexes? Can someone give me a parts list? I'm doing some searching but haven't found the right answer yet.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 09-24-2015, 06:41 AM   #16534
Hi Bob,
Easyest way is with the DESC210 front hubs, TD330382, four bearings 5x10x4 mm and the exotek Ti front axels #1513!
You will need two 3x6 mm bottom head screws and 3mm washers.
That should be al...
Greetings from Austria
Cat K2 / DEX410V3 / DEX410V5 / DEX210 / DEX210F / Cougar SVR /
YZ-10 '94/'95 WCS/
Spectrum DX3R
micholix is offline   Reply With Quote
Old 09-24-2015, 07:01 AM   #16535
Trader Rating: 21 (100%+)
Use the Desc/Dest front hub with a b5 front axle...b5 spindle is $5-$6 compared to $23
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
kerby is offline   Reply With Quote
Old 09-24-2015, 07:05 AM   #16536
Super Moderator
Thanks for the quick reply!
Old 09-24-2015, 08:30 AM   #16537
Hi kerby, do you have the same off set with the b5 axes?
YZ-10 '94/'95 WCS/
Spectrum DX3R
Old 09-25-2015, 02:51 AM   #16538
I would be interested in, if the serpent srx2 slide drive set #500376 would fit into the dex210, as the length of the dogbones are identical to the dex210?
Does someone have both cars for comparison?
Edit: I know the internal ratios are different, as the dex does have 20/52=2.6, and the srx does have 20/51=2.55, but maybe the dex ball diff gear does fit on the serpent out drives!?
YZ-10 '94/'95 WCS/
Spectrum DX3R
Old 09-25-2015, 10:43 AM   #16539
MikeR's Avatar
Trader Rating: 15 (100%+)
The B5 axles will make the front width 2mm narrower than the DEX210 stock width. That is why we make DEX210 and B5 version axles.
Just fyi.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 09-25-2015, 10:50 AM   #16540
Super Moderator
I ordered my axles, rear hexs, and rear mm bulkhead.... so I think I'm good to go
Old 09-25-2015, 10:57 AM   #16541
Just fyi.
Mike,
Thanks for that information!
YZ-10 '94/'95 WCS/
Spectrum DX3R
Old 09-25-2015, 11:45 AM   #16542
You'll never know the difference except the cost... Maybe a little better with the B5 stuff but minimally....
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
Old 09-25-2015, 01:26 PM   #16543
tc5 man's Avatar
Anybody know ?
Old 09-26-2015, 06:04 AM   #16544
Anybody know ?
The B4.2 diff halves may fit, not exactly sure, I thought I read somewhere that someone did use those diff halves in their dex210,maybe on oople , not sure, but I do know the B5 Diff halves can be used, they need quite a bit of shimming to eliminate the side to side play in the rango diff case though. I know the B5 halves will work because I am currently running a B5 puck system in my 210. I had to run the B5 rear axles as well, and ideally you should run the B5 rear hubs as well. The 210 axles use a larger cva pin than the B5, the bones are identical in length, the larger pivot pin in the axle warrants the use of the B5 axles as well! I'm thinking the B4 Halves will work like the B5 ones with shimming, but I can't guarantee it.
WailinOnYa is offline   Reply With Quote
Old 09-26-2015, 06:13 AM   #16545
The only other issue that I'm not totally sure on is the dog bone pin in the diff cup, the pin on the Durango needs to be able to fit into the B4 diff halves slot!
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
